Question about Canon PC-950 Black and White Copier
Canon PC950 Copier
Hi -- The springs at the 'feeder" door broke. Now the copier wont feed, are there replacement parts? A new door perhaps? Help!
  • lady_ne_ne Nov 07, 2008
    I can only use the single sheet bypass because the right cover door is broken. Is there any where I can buy a "Right Cover" door for my Canon PC-950 Black and White Copier?
    Please e-mail me at lady_ne_ne@yahoo.com
  • Carlos Perez
    Carlos Perez May 11, 2010
    you want part numbers? they are right there on the parts!
Hi -- The springs at the 'feeder" door broke. Now the copier wont feed, are there replacement parts? A new door perhaps? I have the same problem.. Need help or place to purchase parts.
Posted on Mar 13, 2010
My hitachi nv45ab2 roofing coil nailer misfires and only shoots every third nail
Hitachi coil roofing nailer will skip nails if the piston oring is worn, the feed spring is weak or lower bumper is cracked. Easy to check. Remove nails and air supply. With side door open point nose of gun up then down again. If the piston moves up and down in the cylinder, replace the piston oring. If piston does not move and is in the up position, check the feed spring for tension. With air supply removed and door open, slide feeder back and press on feeder from door side to check tension. It should spring back to position against rails.If is feels loose, replace spring and retainer pin if the pin is worn. If piston oring is good, and the feeder has good spring tension, suspect lower bumper and the plastic part below the bumper called the "sheet". Remove head and pull the cylinder to examine lower bumper. Parts are available at www.toolpartsdirect.com. Good luck with your repair
Aug 09, 2011 | Hitachi NV45AB2 Roofing Coil Nailer
The feeder in my office copier is not feeding the paper thru it. It only copies if you manually put it on the glass.
Hi, you need to open the adf cover, check for any leftovers of paper or clips, or... also clean the pick up and feed roller with alcohol by piece of fabric.
Also have on mind that the feeder is only for plain paper usage.
Sep 08, 2010 | Canon imageRUNNER 1023iF Black and White...
Document feeder does not feed documents separately. The documents stick together when trying to feed them to print.
hi u have problem with sepration roller just replace it or try to clean sepratin roller to solve problem
thanks
May 10, 2010 | Canon PC1061 Copier
Feeder not working, need spare part kit for Cannon copier ImageRUNNER 330S
I would try www.precisionroller.com or perhaps www.katun.com for aftermarket parts for the doc feeder.
If all else fails you can find your local Canon dealer and buy parts directly.
Hope this helps
TankMurdock
Feb 18, 2009 | Canon imageRUNNER 210S Copier
Canon pc 430 feeder problem
You may have to fabricate a new anchor for one end of the spring on the side opposite the control panel. There is a wimpy plastic tab that breaks off here, right next to a black Phillips-head screw. Remove this screw and bend a piece of light wire around it, leaving a small hooked end sticking out for the spring to fasten on to. Replace the screw and install the spring. When you install the spring, it must go over the top of the tiny white plastic wheel, in the U-shaped groove.
This is how I repaired my PC430 several years ago and it's still working fine.
Jan 27, 2008 | Canon PC-430 Color Copier
CANON PC 20 COPIER
I think the plastic broke that held the spring, so you need to figure out where it broke and drill a new hole for the spring, and sounds like you need a new cartridge, GOOD LUCK!!!
Jan 24, 2008 | Office Equipment & Supplies
Canon d660 imageclass copier
Hello himsmyboy!
Sikna says
The ADF separation pad is the cause. To remove it lift the cover fully up then use a knife to get under the black tape tab at the top right of the large white foam pad. Pull the tape and the white foam pad loose but not completely - leave the bottom attached. Now you can see the ADF separation pad from below. Use a small screwdriver or spring hook to remove the spring and you will be able to wiggle the ADF separation pad out. First take a good look at how it fits in so you can put it back! The problem is caused by the small black foam pad under the white rubbery tape on the ADF pad assembly. I carefully removed the tape from the back edge to expose the compressed black foam pad. I then cut a matching size of 1/16" foam I had in my shop which was actually HP 98A doctor blade seal foam and just stuck it on top of the old compressed foam. (other similar foam should also work) Then I replaced the white rubbery tape and rubbed the edge down well. I then reinstalled the restored ADF pad and the spring which holds it. Last I just pressed the large white foam pad back into position - being sure to pull it with a slight tension as I pressed into place. This fixed the ADF feed and it worked like new again...
Sikna out...
Jan 15, 2008 | Ricoh Aficio SP-C210SF Printer
Auto Document Feeder
has the feeder attempted to feed in the document ? Check to see if there is already a document on the copyboard platen
Apr 27, 2007 | Canon PC-980 Color Copier
Canon PC-950 Black and White Copier Logo
152 people viewed this question
old marine
old marine
