Question about Dell Axim X5 Pocket PC
Is it a problem with Axim -- automatical reset !
I just got my axim. it works well in the begining, but later i find it would power off when i don' touch it for a while. I think it is power protection at first, but it annoys me because i am in the process of installing program from desktop pc to axim. then later i find out even when i in the process of playing games, it will be reset! Does Anybody meet this problem?
    Master:
  • 852 Answers
There are two different power conservation options that you want to look at. The first is in Settings -> Backlight and can control having the backlight turn off if the device isn't in use. The second is in Settings -> Power which has a setting to turn off the device after x minutes. That could be on, and that is what you are seeing. If the device is actually resetting itself (all running applications close), then you could have a bigger problem and you should contact Dell support.
Posted on Sep 13, 2005
I forgot my password
Hi, Once you forget the Password, your only option is to perform a Hard Reset on the device and reset back to Factory defaults. You data will be lost, as this is in place to protect you in case the device has been lost or stolen. If you have backups, or sync the device with Outlook, you can run a restore or re-sync the device to populate the data back into your device. To do a hard reset:
  1. Press the Power button to turn the Axim unit On.
  2. Press and hold the Power button down while using the Axim stylus to press the Reset button at the same time.
  3. Release the Power button and the Reset button. The To clear all data in the memory screen appears.
  4. Press the Contacts button on the Axim to delete all of the data in the memory of the Axim handheld.
  5. Press the Mail button on the Axim to cancel the operation without losing data.
  6. THANK YOU
Dec 23, 2010 | Dell Axim X51v Pocket PC
Dell Axim x51 v
Hard Reset
NOTICE: When you do a hard reset, you lose all the data stored in your device
Flash memory, and any programs that you installed on your device.
Do a hard reset if:
  • You want to restore the device to factory default settings.
  • You forget your password and need to reset it.
  • Your device is experiencing severe operational problems and you have already attempted a soft reset.
NOTICE: It is strongly recommended that you back up your data before you do a hard reset.
To do a hard reset:
Sep 13, 2009 | Dell Axim X51v Pocket PC
I have a dell axim x51v I made a password change and entere it into a digital rape recorder the recorder died on me and I do not remember the password as it happened 2 day after de change my cuestion is...
Hard Reset:
Do a hard reset if:
To do a hard reset:
Sep 03, 2009 | Dell Axim X51v Pocket PC
MY DELL AXIM X30 WILL NOT TURN ON
My Axim X30 would not turn on using battery power but would turn on when connected through charger adapter.
Solution:
1. Connect AC adapter directly to the charger adapter and then to the Axim X30 and to the electrical outlet.
2. Charge battery until power button is solid green.
3. Press the power button to power on.
4. Remove cable from cable connector leaving the cable connector connected to the Axim X30. The Axim X30 will remain powered on.
5. Turn the Axim X30 off.
6. Turned the Axim X30 on using battery power.
7. Remove cable connector from Axim X30.
Apr 07, 2009 | Dell Axim X30 Pocket PC
Set password on my dell axim X51v pocket pc and forgot it
Hard Reset -
Do a hard reset if:
To do a hard reset:
Mar 16, 2009 | Dell Axim X51v Pocket PC
Dell Axim X51
Have you tried hooking it up to the cradle or power plug? That should automatically kick the display on.
You don't say if the Axim crashed. If so, try hitting the reset button with a pen point on the back of the Axim. That should reboot it. Post back with how it goes.
Jan 04, 2009 | Dell Axim X51 Pocket PC
My Dell Axim X5 pocket PC reverts to wrong date
Duh... I figured out that my PC had the date set a month ahead! Not sure how that happened. The Axim was dutifully synching up w/ the wrong date, and so the November appointments didn't register. Thanks for checking.
Nov 27, 2008 | Dell Axim X5 Pocket PC
Dell axim x3i problem
Press and hold the reset on the back and press and hold the power button. This will reset to manufacturing settings.
Sep 21, 2007 | Dell Axim X3i (400 MHz) Pocket PC
Axim X50 locked up during boot up process
May have to do a factory reset on your device.
Nov 02, 2017 | Dell Axim X50 Pocket PC
AXIM Disconnecting
Go to Start Settings System Power Control Uncheck (On external power) or set it to what ever mins you want
Sep 14, 2005 | Dell Axim X5 Pocket PC
Dell Axim X5 Pocket PC Logo
42 people viewed this question
Clive
Clive
Alun Cox
