Question about Konica Minolta DiMAGE Z3 Digital Camera
What is the distance range at macro-photography for the DiMAGE Z3?
    Master:
  • 425 Answers
Macro: Wideangle: 0.1m to 1.0m (from lens front) / Telephoto: 1.2m to 2.5m (from lens front) Wideangle: 0.185m to 1.085m (from CCD) / Telephoto: 1.285m to 2.585m (from CCD) Super Macro: 3cm to 100cm (from lens front), 9.5cm to 109.5cm (from CCD), focal length: 10.45 mm (equivalent to 63mm in 35mm format)
Posted on Sep 13, 2005
Turn on camera and system error screen comes up and you cannot do anything to camera.
1st you need to update the firmware to 1.3u
download firmware here
http://ca.konicaminolta.com/support/americas/digital_cameras/dimage-z/dimage-z3/software_drivers/index.html (this allows 2GB cards)
instructions are here
http://ca.konicaminolta.com/support/americas/digital_cameras/dimage-z/dimage-z3/software_drivers/firmware/installation_guide.html
(instructions are a little vague on where macro mode button *flower button* is)
Also, you might have a bad SD memory card. format the card (erasing all data/pics on card)
and take some picks and try again.. if you can
If still a system error try a different SD card to get past error then update firmware with THAT SD card.
IF that don't work.... your hosed... ;(
Nov 17, 2010 | Konica Minolta DiMAGE Z3 Digital Camera
I have a FUJIFILM Finepix S1500 digital camera and I love it! But i find it hard to use the macro settings and how to get really clear shots! Any help? :)
Macro photography usually requires a steady camera. This means you need a tripod for really clear shots and you need to be within the distance range as outlined in the owner's manual.
Oct 28, 2010 | FUJIFILM Finepix S1500fd Digital Camera
Trouble focusing with sigma 70-300 DL macro super lens
It will not focus on anything closer than 5 feet.
(From Sigma lens literature)
Capable of macro photography, this lens has a 1:2 maximum close-up magnification at the 300 mm focal length. It's the ideal high performance lens for portraits, sports photography, nature photography, and other types of photography that frequently use the telephoto range. It also has a switch for changeover to macro photography at focal lengths between 200mm and 300mm with a maximum close-up magnification from 1:2.9 to 1:2. The minimum focusing distance is 1.5m / 59 in. at all zoom settings.
Dec 25, 2007 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
What is the Direct Manual Focus (DMF)?
With DMF function selected, focus can be manually adjusted after it has been once confirmed using camera's AF system. It is useful for Macro photography and Portrait photography. DMF cannot be used in continuous AF mode.
Sep 15, 2005 | Konica Minolta DiMAGE A200 Digital Camera
What is the distance at Macro mode?
In wide-angle macro mode, the minimum focus range is as close as 30cm from CCD (21cm from the lens front.) At this point, the magnification is 0.03x (equivalent to 0.12x in 35mm format).(Focal length is 7.2mm. At maximum magnification 283mm x 213mm of the subject can be captured.) In telephoto macro mode, the minimum focus range is 25cm from CCD (13 cm from the lens front) and the magnification is 0.18x (equivalent to 0.7x in 35mm format). (Focal length is 42.7mm to 50.8mm. At maximum magnification 52mm x 39mm of the subject can be captured.)
With DMF function selected, focus can be manually changed after it has been once confirmed using camera's AF system. It is useful for Macro photography and Portrait photography. DMF cannot be used in continuous AF mode.
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
In wide-angle macro mode, the minimum focus range is as close as 30cm from CCD(21cm from the lens front.) At this point, the magnification is 0.03x (equivalent to 0.12x in 35mm format). (Focal length is7.2mm. At maximum magnification 283mmx213mm of the subject can be captured.) In telephoto macro mode, the minimum focus range is 25cm from CCD(13cm from the lens front )and the magnification is 0.177x (equivalent to 0.7x in 35mm format). (Focal length is42.7mm to 50.8mm. At maximum magnification 50mmx37mm of the subject can be captured.)
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
What is the camera sensitivity range of this model?
The DiMAGE Z3 sensitivity can be set to Auto, ISO 50, 100, 200, and 400. When Auto is selected, one control in the range of ISO 50-200 is assigned accordingly
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Is it possible to use the built-in flash on condition that the wide converter is attached?
Yes, it is. Please note the following: *1: It is not recommended to use the built-in flash in the macro mode because vignetting appears. *2: When the focusing range (from the front of filter to the subject) is within 36cm, vignetting appears. Test recording is recommended.
Accessories lenses
Olympus offers the following add-on lens accessory options: MCON-35 Macro Extension Lens (equivalent to 1/4 life size, subject size that will fill the frame is approximately 1.4" x 1.9" f2.4 Tele/f2.0 Wide, 72mm filter size) minimum focusing distance - 4.75 inches. WCON-08B Wide Extension Lens (equivalent to 28mm f2.0 in 35mm photography, 105mm filter size) minimum focusing distance - 3.6 inches TCON-14B 1.45X Tele Extension Lens (equivalent to 200mm f2.4 in 35mm photography, 86mm filter size-tentative) minimum focusing distance -1 ft. TCON-300S Tele Extension Lens (equivalent to 420mm f2.8 in 35mm photography, 49mm filter size) minimum focusing distance - minimum focusing distance - 3.9 ft.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Konica Minolta DiMAGE Z3 Digital Camera Logo
83 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
