Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Freezer working but not top part of fridge. please help. thanks much. I have a Kenmore elite trio bottom freezer bought in June 05. Freezer works but top refrigerator does not. Reset alarms, unplugged it and restarted it with no luck. Overnight on rapid cool frig temp is only 54.
WHAT IS WRONG WITH YOUR FREEZER?
For a detailed Freezer illustration, click below.
Chest
Upright
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
It doesn't work at all
It's not cooling
It cools poorly or it's all iced up
It's noisy
It doesn't cycle off
Hope this may help you;
Regards,
VOTIT
Posted on Sep 02, 2008
Have you check if the fridge has a leaks?
If the freezer does not work it is often the thermostat starting the cooling process that is faulty.
Try first to defrost completely, to see if this unjam the thermic sensor, if it does not work you will need to replace the thermistor.
Check the evaporator fan , freezer must have a fan to avoid ice
formation, if evaporator does not work, thermic sensor jams up and
freezer stop working. The fan is located behind the panel in the
freezer.
Check the back of your freezer, If there is frost or ice, then the unit is not defrosting.
This is often caused by problems with evaporator system.
Sometimes you also need to check the defrost timer, located at the top of the FFC on the Top freezer.
Check also the defrost thermostat, which is on the evaporator inside
the freezer.
If
it isnt defrosting, change first thermostat , then check fan motor.
Sep 01, 2012 | Kenmore 22 cu. ft. TRIO French Door Bottom...
This will help. Thanks.Helpmech.
Aug 07, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Sep 24, 2009 | Kenmore 24.8 cu. ft. Trio French Door...
Jun 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
May 04, 2009 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
May 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Oct 22, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Oct 06, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Feb 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Sep 03, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
264 people viewed this question
