Konica minolta bizhub 162 photocopier paper jam problem
Sir,
i have a probelm of paper jam with konica minolta bizhub 162 photocopier.
the moment i try to photocopy the document it says there is paper jam and open the side cover first but there is no bit of paper when i open it. Instead i find one of the rollers is heated to burnt. The temperature of roller becomes as high as 70 to 80 degre celsus in few seconds of power connection.
caould any one help me out to solve this problem >?
thanks
jigme
  • jwangchuk Sep 02, 2008
    sir
    the moment i try to photocopy the document it says there is paper jam and open the side cover first but there is no bit of paper when i open it. Instead i find one of the rollers is heated to burnt. The temperature of roller becomes as high as 70 to 80 degre celsus in few seconds after giving power connection.
    is any thing i need to change?
    jigme
    New Friend:
Tenho um problema de paper ja open 1st side cover,m o que fazer
Posted on Nov 29, 2013
  • 3 Answers
Clean all internal m/c it's a small paper part
Posted on May 10, 2012
Konica minolta bizhub 162 not install. USB Port not install but LT port install. Plz Solve this problem.
Posted on Nov 17, 2009
  • 2,794 Answers
That machine needs to be serviced. Something is seriously going on with that. Could be a power supply issue or a few other things. It needs a Konica/Minolta tech to look at it.
Posted on Sep 06, 2008
Adf konica minolta bizhub 350. theres adf working good but no printout. a few minute machine says jam paper at adf. actualy original it was throw out.. help me please...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - Am working on a Magicolor 2300 DL that sometimes fails to lift the paper tray ... good afternoon I have a konica minolta bizhub c550 when I open the ... I'm no printer tech, but in most other lasers (HPs, etc) the paper tray lifts, .... It seemsthere is a "waste toner sensor" which only lets the printer print out a few ...
Konica Minolta paper jam adf scanner Questions & Answers ...
www.fixya.com > Forum > Tags > paper jam adf scanner
Question about bizhub 350 All-In-One Laser Printer ... Konica Minolta bizhub 250 jammed but no paper ... Good luck. ... ...paper is there if the switch is working the adfboard is fualty or the cable between the machine and adf broke from all the ...
Konica Minolta bizhub document feeder not working ...
Jan 23, 2016 | Konica Minolta Office Equipment & Supplies
Loud knocking sound when copying on a bizhub 162, why?
replace the drum and developer and sounds like the fuser need to be replaced
Apr 10, 2014 | Konica Minolta Office Equipment & Supplies
Misfeed detected
have the rollers been replaced, misfeed means the rollers cant grab the paper not a JAM
Jan 30, 2014 | Konica Minolta Office Equipment & Supplies
Jam paper
Sir/Mam, does tray two work? if so use that mite need to have the rollers replaced in draw one.
Dec 13, 2013 | Konica Minolta Bizhub 600 750 Image...
My copier is konica minolta bizhub 210 have problem error code M1. please help me solution.
My Friend You must do general service in your photocopier and then you must program your machine.
Sep 29, 2010 | Konica Minolta bizhub 180 All-In-One...
Bizhub 162 autoshuts before photocopying
1-turn the machine off, 2-press the "STOP" button, 3-Turn the machine "ON" 4-keep the "STOP" button pressed. 5-wait until the main display shows. 6-release the "BUTTON"
Machine will not disturb you again
Best of Luck.......
Jun 04, 2010 | Konica Minolta bizhub 161f All-In-One...
Looking for Konica Minolta Bizhub 162 driver for Mac OS X
please send me a link for driver for bizhub162 driver for mac
Oct 23, 2009 | Office Equipment & Supplies
Please check the sensors and actuators ,open & close front door to reset nisfeed.Clarification Top feed = Automatic Document Feeder?If YES,please verify misfeed paper beetween coverplaten and feedbelt(Yellow).Is necessary disassembly the ADF.Good luck.You will find a little paper.
Jul 31, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
DP-300U revB and KONICA MINOLTA bizhub 163
I have just setup DP-300U rev.B1 with my Konica Minolta Bizhub 162, the thing is that it doesn't work with USB port connected (paper out), then I tried connecting Bizhub 162 to LPT port, and it works just fine...
Jul 17, 2008 | D-Link DP 300U (DP-300U) Print Server
1,263 people viewed this question
jasbo
jasbo
