Question about Lexmark E240 Laser Printer
Printer doesn't like new cartridge
Up until yesterday our printer worked well with no problems. Our manager put a new cartridge in our E240 yesterday. Now the 2nd and the 5th orange LEDs flash constantly and nothing can be printed. We put the old cartridge back in. That doesn't cure the problem.
  • bigbbk Sep 02, 2008
    followed advice as per advice given to Bill and still lights 2 and 5 remain on.
  • 300 Answers
It means you need to replace the photoconductor kit (the bit the toner fits into)
To reset this error, open the front door then press the cancel button for 3 seconds - all lights will cycle, close the front cover. The counter is now reset
Posted on Sep 02, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Lexmark Master
  • 1,362 Answers
Open front door and push on the start button it should go into a sequence of flashing lights, close and turn on and off.
Hp 7410: Error msg: Remove and check color cartridge. Is this a deathnell for this machine? I cannot seem to get past it even after removing and replacing.
There are several possible issues causing the problem. The color cartridge could be faulty. The contacts on the cartridge and the associated contacts inside the printer may be dirty. Finally, the cartridge chute may be damaged or printer may need service.
You can try a new HP cartridge. Next try cleaning the contacts with distilled (or bottled water) and Q-tips or lint free cloth. With the printer on, open the lid and remove the cartridges when they stop moving. Disconnect the power cord from the printer to stop the machine in the open state. Clean the cartridge contacts and the matching contacts in the machine. Dry the contacts with a new Q-tip or wait 10 minutes before replacing the cartridges. See http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01423559&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=391194 for pictures. Then close the cover and reconnect power cord. You can repeat the cleaning step if it doesn't solve the problem.
If this doesn't work, look at the cartridge chute area to see if the spring is dislodged or the tab is broken. Again see the link above. In that case, the unit needs service. If it is under warranty, contact HP. Otherwise, decide if it is worth the repair cost.
I hope this helps.
Aug 17, 2012 | HP OfficeJet 7410 All-In-One InkJet...
My printer display says cartridges appear to be missing or damaged
Either the cartridge is malfunctioning, if you used refilled cartridges this common, or they came unseated. Check to make sure they are seated correctly by removing them and putting them back. If that doesn't work try replacing them with new, not refilled, cartridges and see if that resolves the issue. If it doesn't the problem is a circuit problem that will need to be repaired by a technician.
Oct 26, 2011 | HP Officejet 6500 Wireless All-in-One...
The lexmark e240 second and bottom light are staying on do i need a photo conductor unit
This may be a toner cartridge region mismatch. Replace the toner cartridge that matches the region of the printer. Or you can also try restoring the printer to factory defaults by following the steps below:
Jul 13, 2010 | Lexmark E240 Laser Printer
I need to reset my ink levels on my lexmark s305 after refilling cartridges
I managed to successfully refill the black cartridge for the S305; I did it when the printer warned of 'very low black ink' (although it didn't print very well - i.e. grey - until the following day). It kept displaying 'low ink' but printed fine for a few months.
I think if you can catch it before the printer decides it needs an 'official' refill or replacement then it works (although when exactly this is is a mystery, as it always displays 'low' for black ink).
Yesterday, the printer decided it wouldn't print until the cartridge was changed.
Refilled; waited for half a day;replaced several times; turned the printer on and off 5 times with no cartridge in (to see if it would wipe the printer's memory of the cartridge); and spent about 4 hours online trying to find a solution.
If it starts working tomorrow, I'll let you know. I don't want to mess about with software that may reset the ink levels. (If anyone finds some that works, please post!)
It looks like Lexmark have ensured they can pile in the cash with their original cartridges.
I've heard about generic cartridges that are chipped to avoid the above problem - I'll visit my local refill store soon.
There must be a way round this!
Cheers, Fronter
Mar 08, 2010 | Lexmark X3550 All-In-One Printer
New catridge's blak ink not functioning
your print head dirty. so tyr clean with wet close until recavered. if not better soak bottom print head with wram water until all dry ink gone.
Aug 10, 2009 | HP DeskJet F380 All-In-One Printer
New cartridges - printer not printing
Align your cartridges to solve print quality problems such as: • Characters are not properly formed or are not aligned at the left margin. • Vertical, straight lines are wavy. 1 Load paper in the paper support. 2 On the control panel, press Copy. 3 Press Options until Maintenance appears. 4 Press the right arrow until Align Cartridges appears, and then press Select. An alignment page prints. Once this page prints, your automatic alignment is complete.
Please rate this solution.thanks and good luck.
Jan 22, 2009 | Lexmark X6170 All-In-One InkJet Printer
Have put in new cartridges (4) now red ink light willnot go out
I have a epson stylus printer but not cd to download to my computer. and ican find it on add printer .what can i do?
Jan 10, 2009 | Epson Stylus C60 InkJet Printer
Disconnected printer
If the lights are solid -
The error is caused by a defective cartridge, an unsupported cartridge, an invalid refill, or a cartridge meant to be used in another geographic region.
• If the print cartridge is not installed, install it.
• If the print cartridge is installed, remove it and install a new print cartridge.
If the lights are flashing
This means the photoconducter kit needs replacing
Sep 07, 2008 | Lexmark E240 Laser Printer
Hp c5280 printer
Its the cartridges...... you will have to get more or new ones. I changed mine after a week of fiddling around - and printer worked perfectly. Wish the error message had been specific, then I would not have wasted all my time. The cartridges that didnt work were brand new HP 350 and 351 cartridges - straight from the packets, but the printer "didnt like them"..... A waste of money but Im going to try and put them back into machine tomrrow and see if I can fool it!!!
Jun 08, 2008 | HP Photosmart C5280 Printer
Printer will not work
I have a kodak 5100 it worked fine until I changed the black ink then it would only print 1 line called kodak yesterday at 9 am and they said they would send new printer head and new ink..it arrived this am and now printer is working fine. I think they know there is a big problem and need to do a recall.Did not think they would act so fast but they did.
May 20, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Lexmark E240 Laser Printer Logo
675 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
