Question about Cameras
My camera (sony) doesn't work. The lens won't go in and out.
  • 169 Answers
Commonly problem of the sony camera with retractable lens is the gear is been broke..you will notice a sound that to noisy...it have to repair that gear or replace that if the gear is been damage..
Posted on Sep 02, 2008
3 Suggested Answers
Kensolutions
  • 455 Answers
SOURCE: Hi. I have a Lumix
I'm sorry to know that the Camera Lens is not focusing and retracting. I'll be glad to assist you with this. I suggest that you perform a power reset of the Camera and check if it helps.
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
If you're able to access the Menu of the Camera, then reset it back to factory reset and check if it helps. Press the MENU button, press the Right Arrow button and select the SETUP Menu of the Camera. Now press the down arrow button to select RESET. Resetting the Camera will change all the settings to factory default.
Performing the steps should resolve the issue.
Thanks for using FixYa.
Posted on Jun 26, 2011
  • 11967 Answers
SOURCE: My SONY Cypershot DSC-W55 lens
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 30, 2011
My camera lens won't close when you turn off the camera
I hit mine agaist a desk a couple times and the lens closed and it's working fine now
Nov 14, 2012 | Sony Cybershot DSCW370 Digital Camera
Camera lens won't shut
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error" (older Canons), "ACCESS" error (Sony), "Zoom Error" (Fuji), "Lens Obstructed" (Kodak), "lens error, restart camera" or just "lens error" (nearly all camera makers lately use this variation). Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Jul 28, 2012 | Samsung Digimax S500 Digital Camera
New Canon EFS 18-135mm IS lens failed to auto focus on EOS Rebel XTI and shutter won't release to take photo. Lens over a few months has worked without a problem. What is the problem?
Make sure both the lens and the camera are switched to af (auto focus). If that doesn't work remove the lens and replace it to make sure it is mounted properly. You can also check the camera with a different lens to make sure it isn't a problem with the settings on the camera. If all of that fails take it to a camera or electronics store that does service work to make sure it hasn't been damaged.
Jul 30, 2011 | Canon Cameras
Some stupid person has dropped and then kicked my brand new Samsung camera and now it won't turn on and the lens is stuck out :( When I try to turn it on it makes a weird beep and won't turn on and...
You should try to get that stupid person to buy you a new camera if the following doesn't help. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Jul 09, 2011 | Samsung Digimax S730 Digital Camera
Lens stuck out and won't turn on. When I try to turn it on it flashes a red light but it doesn't turn on.
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 01, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
My Sony Cybershot DSC-W150 camera won't turn on and the lens are still out.
Here is a tip that I wrote about How toget a Digital Camera Lens to work again
Steps toRepair a Digital Camera Lens
heatman101
May 21, 2011 | Sony Cameras
Sony Cybershot DSC-W150 camera lens are out and won't turn on
heatman101
May 21, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
Message: Lock lens aperture ring at minimum aperture (largest f-number) I think I'm doing this but the message won't go away and the camera won't work.
You must lock the aperture ring to f/22, so the camera can engage the aperture adjustment lever on the lens. Then, you can change the aperture with the command wheel.
When you change the aperture with the command wheel the aperture ring on the lens doesn't move when the camera actually adjusts the lens aperture.
Take the lens off and locate the aperture adjustment lever on the lens mount.
Unfortunately, this won't work with older AF lenses. So if you are using an older lens, the only thing you can do is change the camera setting to M (Manual) to adjust the aperture on the lens yourself.
May 16, 2011 | Nikon D60 Digital Camera
MY lens on my camera wont go down and now my camera wont work
If I recall correctly, there was a recall for this issue and alot of people had this problem in the past. We contacted the manufacturer and they refunded our money. Here are some other things you can try. Hope this helps.
Here are some simple things to try first for a camera that won’t power on. They won’t work for every case, but they’re worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
If you get it to respond, and if next the lens doesn’t want to retract:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 26, 2009 | Polaroid T730 Digital Camera
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
