Question about Westinghouse LCM-19v5 Monitor
Westinghouse lcm 19v5 won't power on period
My monitor will now power on period and it will not even recognize a signal from the computer. There is absolutely no power
  • GaryGG Feb 03, 2009
    Same problem with mine. It started flickering when I'd fire up the computer a couple of years ago. Most of the time. the machine is on. Lately, when restarting, the monitor would not come on, even thogh the light is green. If I hit the power button it blinks on for a second (kind of dark when it does) then goes right back off. Will attempt the capacitor soldering mentioned here and get back with you on whether it works or not.
    Problem Solver:
  • 5 Answers
I have a Westinghouse LCM-20v5 that would have problems powering on, and then it would power on for about 1/8 sec and lose the picture. It died 1 year and a few months after purchase. That sucks. LCD screen problems are often caused by the internal power supply. A new power supply unit can be ordered, but they run about $100 - hardly worth the gamble if you don't know for sure.. Since mine was as good as garbage, I figured that there was no harm in taking a look-see at the innards. When I did, I found some power-supply capacitors that were obviously in distress.
The 19v5 is probably almost the same, so maybe this will help.....
If you know how to solder, or know someone who does, you may be able to fix the whole thing in an hour or two.
I replaced 5 capacitors in mine ($7.86 for all from Radio Shack), and I am now using it to write this.
1 - Put the screen face down on a nice soft relatively flat surface (carpet or bed will work fine) and crack off the back plastic piece (I literally cracked it, as 2 of 4 plastic "claws" broke). It turns out that there is a trick. I think that pushing in really hard from the sides AND pulling at the same time might get it off cleanly.
2 - Remove the (now obvious, after removing the plastic cover) 4 screws that hold the stand onto the unit
3 - Remove the 3 screws that hold the main plastic back of the screen on. After that, it's a matter of careful prying. Remove plastic cover.
4 - The power supply cover is now in view. It is held on by a crafty arrangement of screws and those hex screws that the monitor cables plug into, plus two regular screws for the power supply cable.
5 - four small double wires go into the power supply cover from two adjacent sides. Pull these out - there is no trick, just pull. Mark these with a sharpie to make sure that upon reinstallation, they go into the right sockets and right side up.
5a - You can now slide the cover up and off and remove the power supply board (the one the power cable goes into). 4 screws hold that on, and you have to sort of pull it off sideways and jiggle, as it mates with another board. Be careful - there is one relatively big cap on the power supply board, and you don't want to shock yourself. Short it with something metal to discharge, or at least don't work on your screen RIGHT after unplugging it from wall power. Mine had been off for a couple of weeks, and the big cap registered nothing when I checked it with my voltmeter.
6 - for me, on the 20v5, I looked for capacitors that had "swelled" tops. I saw 5 that were swelled upwards. Caps are supposed to be flat on top - swelling means that they are messed up or close to death. The deceased/suspect capacitors were 2 1000uF and 3 220uF radial-type, all 25V max.
7 - ripshack has these in stock, but they have 35V max ones. If anything, replacing the 25V ones with 35V ones is a good idea, as the old ones couldn't handle the job. Unfortunately, 35V ones are bigger in size. It required a bit of shoehorning, but the larger ones fit. I had to solder one about 1/4" off the board and bend it over a bit to make room for one of the other ones that I was replacing.
8 - solder very carefully, it's tight in there. Work the old cap out side to side, melting the solder joint, pulling, going to the other side, etc. Put the new one in (with the polarity CORRECT) - white stripe on side of cap is "-", other side is "+". You should see the "+" sign written on the circuit board, too, but just pay attention ahead of time - it's easier.
9 - Make sure that all caps are close enough to the circuit board that they do not go above (heightwise) the larger caps that HAVEN'T failed. Otherwise, you won't be able to get the power supply cover back on.
10 - slap everything back together and power up! If it doesn't work, then you blew $8. Big deal.
Posted on Oct 09, 2008
  • 148 Answers
Does the LED light turn blue? Try plugging it in to a different outlet.
Posted on Sep 02, 2008
    Problem Solver:
  • 16 Answers
Http://www.fixya.com/support/t2576306-two_westinghouse_20v5_monitors_also_just
this with silly bit take apart notes is all u need
Posted on Nov 07, 2009
My Westinghouse LCM 19v5 will not powerup
Look for bad caps with bulging tops, similar to the 19" version as shown here:
http://s807.photobucket.com/albums/yy352/budm/WESTINGHOUSE/Westinghouse%20LCM-20V5/
Make sure to use correct type caps for switching power supply.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 21, 2011 | Westinghouse LCM-19v5 Monitor
My monitor Westinghouse Mod# LCM-19v5
The most common thing that causes no power or a blinking power light and no picture is a failure of the power supply board. The board can be repaired and the monitor will be as good as new. To repair the board you just need to replace a few parts called capacitors. Here is a link to repair information on the Westinghouse LCM-19V5
http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-19v5/
I hope this helps, if so please rate my solution.
I picked up a used westinghouse monitor, LCM-19v5, and it works fine as a plug and play. I was wondering if there might be a driver for it to download that might make it even more crisp and sharp.
This monitor only uses plug and play drivers and unfortunately there does not appear to be much support for them on Westinhouse's support site.
Jul 10, 2011 | Westinghouse LCM-19v5 Monitor
Power light flickers green, no image
Check the capacitors in the power supply, see pictures here for a guide so you know what to look for.
http://s807.photobucket.com/home/budm/allalbums
I believe the 19v5 uses the same chassis as the 20v5.
Post back what you find so we can guide you further.
Apr 05, 2010 | Westinghouse LCM-19v5 Monitor
Does not power up freind thinks it's a blown capacitor
Yes, it can be that and other components.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed WESTINGHOUSE (LCM-20V5 may be thesame chssis as yours) and monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | Westinghouse LCM-19v5 Monitor
Screen goes black after fraction of a second
More likely to be bad capacitors in the power supply, see LCM-20V5 (almost the same chassis as used in LCM-19V5) example: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you further.
Mar 15, 2010 | Westinghouse LCM-19v5 Monitor
I have a Westinghouse LCM-19v5 monitor. When I start the computer, after the startup screens, the monitor goes black and I get a red bar with the message "Out of Range." I am in safe mode right now, the...
in the safe mode you have to change the resoulution and the frequency to 60 hz you can get it by fright click on the screen and then choose properties and then choose settings and adjust the resolution to 1280 to 800 and then choose advanced then choose monitor then choose the frecuancy to 60 hz ok and apply ok and insa every thing will be ok conntact me for more if you still haveing the same problem
Nov 14, 2009 | Westinghouse LCM-19v5 Monitor
Westinghouse LCM-19v5 Monitor Logo
690 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
