Question about Lands Phones
My Philips CD135 hand set keeps flashing "searching" and I cannot stop it flashing.
  • 2 more comments
  • filmerfarms Sep 03, 2008
    My phone still comes up with the word searching!!
    I have tried the advance settings formula,but to no avail.The phone is still flashing at me.
    I have taken the batteries out-no good!
    I have tried to unregister the hand set,but when I reach unregister and press the menu key I just get 3 beeps.If my phone has been subjected to alot of power failures,would this have had any effect.
    Brigadier General:
  • 6,966 Answers
The handset flashing "searching" could indicate either:
  • handset is defective, it is not receiving;
  • base is defective, it is not transmitting.
Proposed course of action:
  • revert to factory default as other have posted, reset, unplug base from mains, remove batteries, wait for a couple of hours;
  • borrow a similar handset, if the 2nd handset locks to the base, then the 1st handset has an electronic receiving problem;
  • if the 2nd handset would also start searching, then the base has an electronic fault in its transmitter section.
Further diagnosis and repairs require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional. Additionally, you may want to consider the cost of repairs, in some instances, purchase of a new unit may be to your advantage.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 03, 2008
    Master:
  • 763 Answers
Sir did you try to see your manual about the configuration of this? it has to be a settings about this.
cheers
CHARCOIS
    Brigadier General:
  • 5,158 Answers
Put the phone in the stand ... watch for the light to flicker... take it out ...
  • Lands Phones Master
  • 6,487 Answers
Try to reset the base and the handset of this phone and just re-register it again the user manaul will be helpful to you , the way to reset is on page 32 , this is the link http://www.p4c.philips.com/files/c/cd1352s_79/cd1352s_79_dfu_eng.pdf
Hope that helps...........
  • Mark Gil
    Mark Gil Sep 03, 2008
    Try to reset the base and the handset of this phone and just re-register it again the user manaul will be helpful to you , the way to reset is on page 32 , this is the link http://www.p4c.philips.com/files/c/cd135...
  • Mark Gil
    If you already reset the phone and still the same , you can try checking if there's any software update for this unit if there is try to update the software, But there's really a possibility that its already defective top be honest...
    Good luck.......
    Sergeant:
    Champion:
  • 310 Answers
Hello
Remove the battery from the hand set for five minutes.
  • 1,879 Answers
Peeps that have the same problem as yours
check the suggested solutions here
Posted on Sep 02, 2008
  • 3,037 Answers
Try the following and let me know if it works
First press page button on home station for 5 seconds. Then go to advance settings on the phone. Go to register/connect. Put in pincode 0000.
  • 19,396 Answers
Try unplugging power cord for five minutes or so, this should clear the error.
I have phillips cd135 no instructions on how to set it up
Hi! This is a link that allouds you to read and download for free the user guide manual (in a PDF format) for your mobile device: ( http://www.p4c.philips.com/files/c/cd1351s_79/cd1351s_79_dfu_eng.pdf ).
I hope this will help you! Have a nice day!
*please don't forget to rate my services :)
Sep 02, 2011 | Cell Phones
After power cut the phone will not connect,it just keeps reading searching in the screen no dialing tone,the line appears ok as a normal plug in phone works ok can you help many thanks. I cannot find the...
I think if you switch off by holding down the 'exit' key for about 10 sec, then switch on again (same key) it might recover. Mine did, but seems to need the process repeating from time to time. When switched on again it still has to search for about 5 minutes.
Jan 07, 2010 | Vtech Digital Cordless Telephone VT-2568
CD135 will not stop searching
Clicked and hold down the ringer buton, followed by registering the phone.
Aug 23, 2009 | Philips 2252 Twin Cordless Phone
Cd135 philips.
The handset is not ‘registered’ with the based unit.
By default, the Master PIN is 0000.
  1. On the base station, press and hold The paging key for approximately 5 seconds.
  2. On the handset, press Menu key,
  3. scroll : to ADVANCE SET and press (Menu) OK,
  4. scroll : to REGISTRATION and press (Menu) OK.
Note: If no action is taken on the handset within 10 seconds, the registration procedure will be aborted. If this happens, repeat Step 1.
  1. Enter the Master PIN when prompted and press (Menu) OK to confirm.
http://www.p4c.philips.com/files/c/cd2452b_05/cd2452b_05_dfu_eng.pdf
Mar 18, 2009 | Philips 2252 Twin Cordless Phone
Just bought a Philips Digital Phone Model No.CD135. Is THERE NO BACK LIGHT on this phone as it is difficult to read screen even in daylight. I would not have purchased it otherwise. If not do you have a...
Hi
I contacted Philips by phone and the told me that there is no back light on Model No CD135. I think that is stupid as you can have a back light on the cheapest mobile phone. All handset phones should have a light so it can be used in bad light.
Frank
Sep 26, 2008 | Lands Phones
Philips model cd135
Hi there Fred
Here are links to user guides for your unit. Good luck, thanks for using FixYa
http://www.p4c.philips.com/files/c/cd1302s_73/cd1302s_73_qsg_eng.pdf
http://www.p4c.philips.com/files/c/cd1353s_05/cd1353s_05_dfu_eng.pdf
regards
Graeme
Mar 15, 2008 | Lands Phones
Philips CD135 Twin Cordless Phone
Disassembly the battery pack, and power on after that.
Oct 28, 2007 | Philips DECT 2252S Cordless Phone
Lands Phones Logo
431 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
