Question about RCA RT2300 System
Roaring on start up
So should this whole system be returned or is there a way to get around tearing it all out??? I don't understand amps. obviously.
  • RCA Master
  • 19,396 Answers
First ensure it is not a disturbance from TV or any nearby device (eg. power adapters).
Generally , if the noise raise up in volume anthen goes it is a faulty amp.
If the problem goes as you whack (gently) or move the unit then it is a bad contact or connector inside.
If you just bought the item I would replace it, even if problem disappears by moving the device or whacking it, it means the machine has a fault that can come back in time.
If product is not brand new, but covered with guaranty take in for repairs.
Posted on Sep 02, 2008
Mahindra tractor diagnostics
You are going to have to disconnect belt and try to turn pulleys on drive system to locate the excact location. It sounds like a belt tension or bearing problem to me.
Jul 19, 2013 | Husqvarna Garden
01 highlander abs at all speeds
Is it not obvious to you, that you have a possible
system malfunction in the ABS Braking System?
The light is on & you should be giving us what ever
codes you have,if you have a question.
Any light on the dash of any vehicle,you need to have it
checked out ,diagnosed & repaired in a few days, or don't
continue to use any vehicle with problems.
And don't clear the light,you need the codes to find
out where to start on solving the issues
May 29, 2012 | 2001 Toyota Highlander
My car runs for awhile then tac starts bouncing around & car dies, won't start back up for awhile. What could this be?
First inclination is a fuel delivery problem. Several causes for this are:
  1. Clogged fuel injectors
  2. Air in fuel line
  3. Leak in fuel line
  4. Bad gas filter
  5. Bad fuel pump
Nov 12, 2011 | 1993 Lexus Ls 400
I was asked by a family member to look up 2001 toyota highlander for troubleshooting code P1135 and tell them what it says. but i can't find it can u help me?
That is because it is a manufacture code & not a generic code
That is where having the factory powertrain & emission manuals
come in handy, if you want to spend a couple hundred dollars
Without them your not going to even have a place to start on
todays vehicles
I do not have that code, but it appears to be an O2 sensor Code
The front O2 Sensors,the ones closest to the engine before the
converter, get replaced on all vehicles around 80 to 100,000 miles
Other than that, you need repair shop help, so you don't throw
parts at a problem, without the diagnostic knowledge
If you have studied OBD2 Systems, you will understand that
check lights on your dash, do not always mean replace something
No code tells you what is wrong. Just where to start in a system
to figure things out & look for a problem
Sep 20, 2011 | 2001 Toyota Highlander
Steering on my 2004 Lincoln LS 6 is tight, it stays in place and is not quick to return after I make a turn. Put new power steering pump and rack and pinon. Still same problem.
Have to have alignment done after any
front end work
Most repair shops don't have that capability
That is why you don't go to them
Still same problem?
Then the whole rack & pump was a questionable
diagnosis & repair
Any thing else you can add
I have a 2004 V8 LS
Aug 02, 2011 | 2004 Lincoln LS
Rca home theater system makes a roaring noise. It has sound when trying to play dvd. However there is no picture. Help
Unnamed products lacking details don't take us to specific answers.
Roaring Noise could be an undecoded DTS digital bitstream. Look in the manual(s).
Jul 15, 2011 | Audio Players & Recorders
Toshiba 27A45 picture and colors began to get darker and darker until whole screen is black. Sound still good. After a minute or two the picture returns fast.
Sounds like horizonal output transistor could be over heating. There could be other problems. But I would start there. You can find the part number on the schematic inside the set. If you change it yourself don't forget to use the included insulater. Part should cost between 15 & 20 dollars. You will need make & model # of set at electronic parts store.
Diagrahm inside set will show you location of transistor
Jun 07, 2011 | Toshiba 27A45 27" TV
Roaring is heard from front end when going speed
I have a 98 Ponitac Grand Prix GT. Soon as you start going it starts roaring. Gets loader the faster you go till 70 mph. When I am turning to the right a little while going 60 mph the sounds quiets down. Only to the right. I have replaced both wheel bearings, got brand new tires, new brakes. Didnt stop the roaring. Would it be cv axles, rack & pinion, transmission, etc?
May 19, 2010 | Cars & Trucks
Repairing 1/4inch tear in foam around sub
click the picture for product website
I used this stuff to repair a tear in the rubber surround on a kicker solobaric 10", it has held up for 10 years, seal the front and back if possible and allow to dry/cure completely. good luck :)
Feb 14, 2010 | Car Audio & Video
Excessive running noise
yes there is. i take it that it is an oil fired pressure jet.
the fuel pump pressure needs to be set at 9 bar. run it for 10 mins and fit gas analizer to flue. ajust air to return 11% co2 and lock off you will find that the roaring has gone.. it needs a service by an oftec chap
Feb 03, 2010 | Kitchen Ranges
RCA RT2300 System Logo
41 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
