Question about Acer Aspire 5600 Series 5630-6951 Laptop
At the bottom right hand corner, the monatior lcd scree has been cranced i need a nes 154 in crystalBrite WXGA monitor. and how instuctionnos on how to replace it
Failure predicted on hard drive disk 0
A predict failure is just that. There is a good chance it fail. Make a backup and replace. You can also turn the SMART monitoring off in BIOS if you don't want the warning.
Dec 24, 2012 | Acer ASPIRE 5610Z2273 COMPATIBLE LAPTOP...
Lines in screen of lap top (Toshiba satellite a100)
Plz connect your laptop to external monitor. If it is working fine, it should be the problem with the LCD. Need to replace...
thanks & regards
Anas K A
Jun 28, 2011 | LG PHILIPS LP154W01(TL)(A2) COMPATIBLE...
My laptop benq r56 work with wierd coulours white screen
Here are some steps which you can try.
- Plug in an external monitor and check if you get the same colors on the external display.
- If you get the same display, install an updated driver for your video card. But if still the same, your video card needs to be replacement (if dedicated) or your motherboard needs to be replaced (if integrated).
- If you external display works fine then the problem is narrowed down to the LCD. Either the LCD inverter or the LCD cable is failing and needs to be checked/replaced.
Hope this helps.
May 27, 2011 | BenQ JOYBOOK R56 154 WXGA CCFL Glossy LCD...
On an Acer Aspire 1640z I get blue screen and lines. lines move with track pad movement. nothing readable. replaced lcd cable and inverter. thinking either lcd or motherboard
Hook it up to an external monitor. If the display is fine on the external then your gpu on the motherboard is fine and the LCD is bad. No external display means bad board. Both cost roughly the same but an LCD is much easier to replace than the board.
Apr 07, 2011 | Acer ASPIRE 1640Z COMPATIBLE LAPTOP LCD...
Model: Packard Bell Easynote GN45 - Display has "shifted" to the left; thick black chunk down the right hand side of the screen. Display at top of screen also appears at the bottom of the...
Test the laptop using an external monitor
If this works fine, then the issue is with the screen, or possibly the vga cable. I notice this is referred to as a compatible screen, was this obtained new, or is it 2nd hand. Although most 15.4 screens fit most 15.4 laptops, some do not display correctly, this might be your problem. If you know the screen to be good I would suspect the connection at the back of the screen
If this still shows issues with an external monitor, you have a problem with your graphics chip on the motherboard
Jan 22, 2011 | Packard Bell EASYNOTE GN45 COMPATIBLE...
I want 15.4" WXGA Acer Crystalbrite LCD (8ms/220-nit) monitor.
my acer crystalbrite lcd 8ms 15.4 is no longer in my laptop and i need a software so i could download a new one
May 26, 2009 | Acer Aspire 5315 Notebook
Have an Acer 5315-2153 with 15.4 screen went black
Cheack your video with and external monitor, if you have video then you will need replace your inverter or backlight or both, if your lcd it is nor cracked this is a common problem with the lcd.
You need to remove your frontal plastic in order to see your inverter, if this didnt work replace your backlight.
\this is a heavy job if you didnt have the experience or tools, we can replace your inverter/backlight for $75 usd
10001 buckwood ave 79925 El Paso Tx.
Contac us if you are interested
Thanks, please leave feedback
Vcrtech
support@vcrtech
vcrtech@hotmail.com
www.vcrtech.com
Apr 29, 2009 | Acer Aspire 5315 Notebook
Spilled Liquid
sorry now way to fix it you must change the monitor
Jul 28, 2008 | Acer WXGA AL1916WASD (Silver) LCD Monitor
Acer Aspire 5600 Series 5630-6951 Laptop Logo
83 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
