Question about Konica Minolta DiMAGE Z3 Digital Camera
What is the type of LCD monitor? - Konica Minolta DiMAGE Z3 Digital Camera
    Master:
  • 425 Answers
The DiMAGE Z3 has a 3.8cm (1.5 inch) digital-interface TFT color LCD Monitor, which displays approximately 78,000 pixels.
Posted on Sep 13, 2005
Vertical line in monitor
theres no way to fix vertical line on lcd the only way is to replaced lcd panel with same panel type
Feb 28, 2014 | Philips 17" LCD Monitor
Will my hp pavilion a 420n support a 19" flat screen monitor
I have to assume you are currently using the larger size called a tube type monitor and would like to have an LCD or flat screen type monitor connected to your computer.
To connect to new LCD flat screen monitor to your computer would be exactly the same connection as what you are currently using.
The only problem you could run into is the connector itself. Some of the flat screen LCD monitors do not have the older style connector called VGA, usually blue called DB15, because it has 15 pin connector. They may have only have the newer style called a DVI type. Some do have both types.
Please be sure the LCD you want has the older style DB15 connector to connect to the rear blue VGA input of your compter.
Good Luck
Aug 30, 2011 | HP Pavilion a420n PC Desktop
Rehow could fix the sreen on wall?
Remove the LCD monitor stand, purchase a wall mounting bracket. There are several types, one is on an articulated arm which allows you to left, right, up and down. Another type mounts flat to the wall with limited up and down adjustment.
You need to check the mounting holes on the wall brackets so it matches the mounting screw holes on the LCD screen.
Nov 26, 2010 | LG 22" FLATRON LCD Monitor
I am unable to get MAG Innovision 14" LCD monitor
You need laptop-type 12V, 2.5A (minimum) adapter plugged into back of VGA plug
Nov 13, 2010 | Mag Innovision lt456s 14" Flat Panel LCD...
Flatron L1919S (Black) LCD Monitor: Is my LCD monitor, LG Flatron L1918S, good enough ...
You should google this. After looking myself i have seen that it should play HD movies without a problem.
May 18, 2010 | LG Flatron L1919S LCD Monitor
Line across lcd screen
Try the following steps:
  1. On the monitor, press Menu, and select Factory Reset.
  2. If the monitor has more than one type of connection available such as VGA, DVI, or HDMI, try a different type of connection.
  3. Connect the monitor to another computer. If the line appears when the monitor is connected to the second computer, the monitor might be damaged or defective.Otherwise, the video card and driver is causing the problem from the computer. let me know if this resolved ur issue.. regards, guru
May 03, 2010 | HP 22" Widescreen Flat Panel TFT LCD HD...
Hyundai L70 N 17 inche LCD monitor
It depends on what type of monitor it is, but you should be able to purchase a DVI to whatever type of input the monitor has most anywhere.
Jan 17, 2010 | Apple Mac Mini Desktop
Monitor not working
If this is LCD monitor, The power supply of you LCD need to be repair.Ask technician to fixed this power. LCD monitor need to epen and replace defective parts
Jul 26, 2009 | Computers & Internet
Philips 190B8 LCD monitor running under Win 2000 Prof OS
You need to get the inf file for your monitor to tell windows which monitor you have. did you get a cd with the monitor?
Apr 01, 2008 | Gateway FPD2275W LCD Monitor
Konica Minolta DiMAGE Z3 Digital Camera Logo
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
