Question about Ricoh Aficio 1035 Copier
Connecting ricoh 1035 to pc
I have completed the download desktop binder V2, as requested. Please provided assistance on how to perform wire connection to pc
  • Ricoh Master
  • 2,794 Answers
Connect your copier to a switch or router.
Goto user tools/counter. Select interface settings. Enter the IP address of the copier, enter the gateway address to the router. Press file transfer. Turn the deliver server on. It will take a few seconds but it should populate the IP address to the computer that desktop binder is installed to and insert the users assigned to the scanner program.
Posted on Sep 04, 2008
  • 2 more comments
  • Tim Babcock
    Tim Babcock Sep 04, 2008
    Make sure the firewall isn't installed on your computer. If you need a firewall, use the one on your router if they provided one for you.
  • Tim Babcock
    Desktop Binder Version 2.0 will not work on Vista computers. I just tried installing it here at work and it doesn't see the IP address at this time.
  • Tim Babcock
    Here is a PDF of what is needed to run Scanrouter PRO.
    Our office is going to use and ftp server instead. I don't know if that option is available on a 1035. It is on 2045.
  • Tim Babcock
    Correction Desktop Binder will work on Vista but Scanrouter won't work on Vista.  Your are limited to network scanning, printing, and faxing using the network TWAIN, Fax, and RCPS drivers.  Tiff file format is only the format supported by 1035.
    New Friend:
  • 3 Answers
How to attech the ricoh 1035 to pc
Posted on Feb 24, 2013
Sc690 for ricoh 1035
That is not an easy task...
From what the manual says you have a BICU defective. Looks like a bad connection or somethings.
I advise you to call your provider. I think there is nothing you can do
Mar 05, 2011 | Ricoh Aficio 1035 Copier
I have ricoh 1035 & eror sc990. without hdd ,i can print and copy one side and by hdd i have error. i do . & # toghter for 10 second for soft reset and nothing happend. in code menu: 5801 - 2109 -...
If you use Katun OPC drum in your machine and is work more 80000 copies you need to replace the OPC drum and the drum cleaning blade.After replace the drum perform the process comtrol and the SC990 disipaire.Whenever use other genuine parts and not original Ricoh parts appair SC codes to refer HDD parts.100% this method is working.
Nov 21, 2009 | Ricoh Aficio 1035 Copier
Do i need any driver if i connect Aficio 1035 to my pc. n wat do i need for it to be connected to my pc. tq
Does your machine have the Printer Option installed? Or the Print / Scan Option installed? If so, there would be a NIC input on the left hand side of machine towards the back....and print and scan buttons on the left side on your control panel. Type 1045 Printer option is what needs to be installed for the machine to be able to print. Drivers can be downloaded from this link to Ricoh.
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/x1035_45/x1035_45en.htm
Just choose your operating system.
Oct 22, 2009 | Ricoh Aficio 1035 Copier
Ricoh aficio 1035 error code SC121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
Jun 15, 2009 | Ricoh Aficio 1035 Copier
Networking at Ricoh 1035
does your 1035 have either a printer or printer /scanner option. If it does just hook s line up to the network connector on the back of the controller. hit user tools, system settings, interface settings, network settings and then select auto obtain. now exit from the user tools to the regular screen. wait about ten seconds to let the settings take effect. Now hit user tools , printer features, lists and hit configuration page. Take this page to the computers with you. Go to start, add a printer add a local printer, deselect auto detect, hit next. Now hit add port select tcp/ip from drop down button. in location where is it says printer name or ip address enter the printer name located on the bottom right section of the configuration page you printed. now go to ricohs website www.ricoh.com, americas, then at the top you will see downloads. then a screen will apper that says drivers and manuals. select black and white, 1035 and windows vista. create a folder on your desktop called printer. once in the folder, open it double click and unzip it into the same folder.now back to page after you have typed in the printer name and hit next. go to have disc, browse to the folder on the desktop and follow the prompts form set up, drivers, vista, pcl 5, english and the select if this is your default printer, do not select sharing and ask it to print a test page. once this has printed go to the properties tab on the drive itself and select accessories. and add whatever options your copier has ie. sorter, duplex or extra paper drawers. Now do this to all your copiers on the network. doing this allows you to print from any computer regardless if any other computer goes down
Dec 11, 2008 | Ricoh Aficio 1035 Copier
Scanning on Aficio 2232c from Windows Vista PC
goto www.ricoh-usa.com and download desktop binder.  Restart your computer.  Then use the setup options to link the copier to desktop binder.
Another way to do it is to skip the twain software altogether and use  a shared folder on your computer.  Your 2232 can link to that folder if smb is installed on your copier.
The way to find out is to press the user counter/tools button.  Select key op tools.  Go to address book management.  Select new program.  See if folders appears.  If it does press the button and select the browse button to see if it can find any computers on your network.
Your computer should have a shared folder with no restrictions to it.  Windows firewall should be turned off.  You copier must be connected via ethernet cables.  Firewall protection should only be on the router.
Nov 08, 2008 | Office Equipment & Supplies
How to connect ricoh 1035
First, check on the left side of the machine to see if it has either a USB or RJ-45 receptical to plug your computer into. If not, the machine lacks the hardware needed to print from your computer. A Ricoh technician must install it at extra cost. If you DO have either of these recepticals, go to:www.ricoh-usa.com/downloads, to download the manual and drivers you need.
Sep 02, 2008 | Ricoh Aficio 1035 Copier
I'm trying to register my new router which was preset at the store. I provided my name and email address online, but can't complete registration. I eceived an email, but no confirmation number came.
I've never heard of a router being pre-set at the store and show me a quote of the email please. I've also never seen a confirmation # when registering a piece of hardware online. Confirmation #s are normally used when requesting assistance to show they are acknowledging your request for assistance and the requested assistance lies in specified range so they are serve you in order of request.
Aug 26, 2008 | Computers & Internet
Ricoh 1035 - Tray 4
There is a wire harness that connects the two bottom trays to the main machine. The connector might be loose or have a break in the harness. The main machine is not seeing the bottom two trays. Let me know if this helps.
Sep 15, 2007 | Office Equipment & Supplies
Ricoh Aficio 1035 Copier Logo
573 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
