Question about Epson PhotoPC 650 Digital Camera
Epson 650 digital camera
I just bought an Epson 650 digital camera. I know, it's not new and fancy, but it's all I could afford right now. I bought this one (from ebay) mainly because my daughter has the same one- she bought several years ago, for around$350. I've noticed what big, clear, detailed pictures it takes (she sends to me). She resizes the pictures smaller, but the resolution on hers is 144. she uses one of the "better" settings, not the standard and not the BEST. What I've noticed with mine is, the resolution is 75 and the pictures don' tseem as clear and detailed. This might be partially because the scenery ones I've taken are of SNOW. I've tried using all the settings, even the very best, which only takes 3 pictures. The resolution is still 75. The picture size is big, 15"X 11". They are JPEG. I tried using he HotShots software that came with it, and now use Paint Shop Pro 7, with AQUIRE (Twain). I tried using the memory card in the USB cable that came with it, but it seemed to be clashing with my CD burner, which is in the other USB port. It's just as easy to use the camera and serial port and PSP. My daughter doesn't know much about it, she just takes the pictures and then takes them off. Hers have always been 144 resolution. I'm not saying the pictures on mine aren't good, and they're better than the Kodak DC 3200 I've had for over a year. Just that they don't seem as good as my daughter's, and it's the exact same camera. Could it be the memory (flashcard) that sets the resolution of the pictures? I have the original 8 MB one that came with the camera and my daughter once bought a bigger one. I know I can change the resolution in PSP to something higher if I want. I've been trying to find out what decides what the resolution of the pictures (when taken off the camera) might be? I can't find anything in the directions book about the settings for this. Just the "standard, better, best and extra fine". But, they all take pictures with 75 resolution.
5 Suggested Answers
Quack
  • 542 Answers
SOURCE: Epson 850Z and ibm microdrive
It may not neccesarily be the microdrive. I had the same thing happen twice while using a new Sandisk 15Mb CF card. The only batteries I've used are the Epson ones that came with camera, but the manual says that the time may need to be reset sometimes after changing the batteries. This happened to me NOT after changing them though. let me know if you figure something out. If it happens again to me, I'm going to talk to support.
Posted on Sep 13, 2005
Quack
  • 542 Answers
SOURCE: USB connection to computer
Go to 'add new hardware' and say somewhere driver from disk... Then goto epsons driver CD (provided with cam..) in the directory 'epson/winPNP/ There is the PNP driver for the Epson camera USB.. It took for me a while before i found it. And epson installation doesn't install it by default ... strange That 'click' what you hear.. Goto setup and then to 'camera setup' there you should see somewhere something with 'beep'... switch it off.
pishta68
  • 593 Answers
SOURCE: EPSON PHOTO PC 500 DIGITAL CAMERA
Serial meaning 2.5mm stereo headphone looking jack to DB9 or "atari joystick" looking plug? I had one on my first Toshiba PDR-M1 camera but that was like 9 years ago. You can probably find the pinouts online for that cable, I believe it is a standardized cable.
The stereo plug is wired to the PC serial port as shown in the following diagram:
tip ring sleeve +---------------------------------+
| RxD | Gnd | TxD | 2.5 mm Stero Plug |
DB9*: pin 2 pin 5 pin 3 +---------------------------------+
DB9*: Optionally short together pin 4 (DTR) to pin 6 (DSR) and
pin 7 (RTS) to pin 8 (CTS)
The following table also describes the camera cable's wiring: Camera PC's
Plug DB9* Signal Name Direction
- 1 Carrier detect (CD) input to PC
tip 2 Receive data (RxD) input to PC
sleeve 3 Transmit data (TxD) output from PC
- 4 \ Data terminal ready (DTR) output from PC
ring 5 | Signal ground (Gnd) -
- 6 / Data set ready (DSR) input to PC
- 7 \ Request to send (RTS) output from PC
- 8 / Clear to send (CTS) input to PC
- 9 Ring indicator (RI) input to PC
* Note that the cable's D-subminature DB9 RS-232 serial port connector is female. This connector also goes by the historically more correct name of "DE-9J".
Posted on Feb 22, 2008
LongPockets
  • 1177 Answers
SOURCE: I recently purchased an Epson Photo PC 3100Z
It is probably having trouble with the capacity of the memory card. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards.
You don't say what type of memory card you have. "SD" cards larger than about 1GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
Posted on Jan 22, 2011
I used the wrong charger
Sorry about that, it sounds like you have definitely burnedout the mother board and as these cameras are Vvery sensitive to over voltage, swapping the one board may be an expensive way to fault find. I would recommend contacting Epson and getting a repair through them. Get a quote first, as it may be cheaper to buy another came there are lots on the market now with much higher specs at very affordable prices.
Sep 15, 2012 | Epson PhotoPC L400 Digital Camera
I have an epson 500 picturemate. Bought new camera which uses sdhc card . Do i need to buy a new printer.
No you don't have to buy a new printer :-) for a few pence /cents you can buy an adapter from eBay.
Mar 29, 2012 | Epson Cameras
I have Epson Photo PC 650 digital camera. It is not working. Power is not on.
To be honest I think the camera, although great in its day has given you good service, unless changing the batteries or gently pulling on the camera contacts to make them give better contact with the batteries works I think that it is what is known as 'beyond economic repair' I. Even. Time to buy a new camera. Sorry to be the bringer of bad news.
Sep 15, 2010 | Epson PhotoPC 650 Digital Camera
One day it was working and literally the next it stopped altogether. I changed the batteries and the memory card to no avail. Epson suggested a power failure but no solution. Can anybody help please
I'm afraid that it sounds like a fatal fault. I had one many years ago and enjoyed using it immensely. I seem to be saying this to a lot of people at the moment, but I think it's time for a new camera. I doubt that epson have any spares left to fix it for you. Sometimes they can be picked up on eBay for a song.
Jan 25, 2010 | Epson PhotoPC 800 Digital Camera
Epson Photo PC Mini Cable
you can use the same serial cable for the model photopc 500 600 700 it is 8pin NOT 5pin
you can see the specs here for your camera
http://files.support.epson.com/pdf/phpc__/phpc__sl.pdf
and it it at ebay just type the right name
EPSON PHOTOPC SERIAL CABLE 8 PIN
Oct 08, 2009 | Epson PhotoPC 650 Digital Camera
DSC-F707 camera cuts off after 10 second , just bought a new battery.
I also bought an aftermarket battery for my F707 on Ebay and got the same "for info...." message.
I contacted the seller and they sent me a new one and it worked, don't see a way around it.
Oct 26, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
Polaroid a300
I think you're looking for something like this:
http://cgi.ebay.com/USB-2-0-A-Mini-B-5-Pin-PC-Digital-Camera-MP3-Data-Cable_W0QQitemZ110265688402QQihZ001QQcategoryZ42322QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
or
http://cgi.ebay.com/6-Feet-USB-2-0-A-to-4-Pin-Mini-B-Data-Cable_W0QQitemZ350074273471QQihZ022QQcategoryZ42322QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
They're both the same kind of cord..just wanted to give you a selection. I have the A300 as well so I know what the cord looks like.
You can get it on Ebay or go to a computer store(or a Wal-Mart) and buy it...make sure to look for "Mini USB"(the small end of the cord)..and make sure the other end looks like a regular USB(USB 2.0).
Jun 04, 2008 | Polaroid a300 Digital Camera
CompactFlash storage card
Make sure you're using an ATA-compatible CompactFlash memory card. Other cards may not work with PhotoPC 650.
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
Image on screen is too dark.
Adjust the brightness of the screen using the Camera SETUP menu. See page 3-14 for instructions. In direct sunlight conditions, you may need to shield the LCD display monitor with your hand.
Windows NT 3.51
No, Windows NT 4.0 is the minimum NT operating system requirement.
Epson PhotoPC 650 Digital Camera Logo
82 people viewed this question
Top Epson Cameras Experts
Steven Wander
Steven Wander
Thomas Stauber
Thomas Stauber
Tony Parsons
Tony Parsons
Are you an Epson Camera Expert? Answer questions, earn points and help others
