Question about Dell Axim X5 Pocket PC
How to connect Axim to internet?
I am thinking about getting one of the new axims but does it have a modem? If not, then how do I connect it to the internet(modem, ethernet, or WI-FI). Thanks in advance.
    Master:
  • 852 Answers
It doesn't come with one, but you can use the CF slot. Just pick up a CF Modem, ethernet card or wireless card (for a wireless network) and you are ready to go.
Posted on Sep 13, 2005
SOURCE:
I cant connect to the Internet with my Axim x51v
You should download a new browser for the Internet
May 13, 2011 | Dell Axim X51v Pocket PC
We have a Dell Axim X5 that we are trying to connect to a PC. Have obtained a USB data/power sync cable, the Dell appears to charge from this cable however, ActiveSync on the source PC doesn't recognise...
I use AS 4.1. I think the Axim will use up to AS 4.5. I had no problems with sync until SP3 came out. Now I must resart the computer with the Axim connected to sync. If the computer goes into suspend it will no longer connect until restarted.
Attempt a restart with it connected.
I have known others with no ability to get the Axim and other devices to be recognized. Unaware of a solution in that case.
Jul 13, 2009 | Dell Axim X5 Pocket PC
No wifi, how do i get on internet
This model of the Axim X30 does not have built in wi-fi capability. You need to purchase a 802.11 b/g Wireless SDIO card.
IMPORTANT: DO NOT INSERT SDIO CARD INTO AXIM X30 BEFORE INSTALLING DRIVERS.
1. Connect the Axim X30 to your computer.
2. Establish a connection between the two devices using Active-Sync.
3. Insert CR-ROM which ships with the SDIO card in your computer.
4. Follow instructions for installing Driver an Utility.
5. Install SDIO card into the SD slot on the Axim X30.
May 16, 2009 | Dell Axim X30 Pocket PC
Internet and Bluetooth Problems
The issue you have is that the Axim does not have any built in connectivity for networking. In order for the Bluetooth to connect you, you would have to first pair the Axim to a Bluetooth enabled phone that can support Internet connections. Bluetooth on its own can't connect to the Internet, it is a protocol to link devices together.
The easier way would be to buy a wireless 802.11 compact flash card that will support PocketPC and then use a wireless access point to connect to the Internet.
May 11, 2009 | Dell Axim X5 PDA Snap-On Thumb Keyboard...
Want to connect to internet through a desktop with my dell axim
u hav to download da internet server software to pc............. thn u hav to do some settings............
Mar 04, 2009 | Dell Axim X5 Pocket PC
Connectivity/activesync and network issues
When using wireless lan with PPC, there are some experience shere with you. 1. You must do an "Reset" after the first time of installing wireless driver into your DELL AXIM. Otherwise, the driver would not work. 2. Microsoft Pocket PC 2002 only can allow one source to access the internet. It can't access internet via the USB and wireless at the same time. Thus, it is more batter way to leave your AXIM alone instead of insert on cradle when you try to access internet via wireless lan. 3. Some of the wireless's CE driver are based on StrongArm, 206MHz, not PXA250, 400MHz. It will got problem when the wireless try to initiate the link between base station and PPC. Try the following step: (i) Make sure you have been install the wireless driver. (ii) Remove your wireless from CF slot. (iii) start->setting->power->processor select "PowerSave" mode and apply it. (iv) Plug wireless into CF slot (v) If you can get an dynamic IP or access internet, you can repet step 3, but select "Auto" mode. Hoping these information can solve your problem.
Sep 19, 2005 | Dell Axim X5 Pocket PC
Can Axim import Palm data?
Yes, Palm data like calendars and contacts can be transfered various ways including through Outlook or via infrared.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Modem for Axim
any type I or Type II compact flash modem card should work. give it a try and let us all know
Secure Digital Wireless card?
No. The secure digital on the Axim only supports memory cards. If you want to use anything else it will have to be for the cf in the Axim. Devices for wifi, bluetooth, and modems are more readily available for cf and are lower priced at the moment too.
Can the Axim connect to a mobile phone thorugh the IR sensor to connect to the Internet. If not what would be the recommended way to connect through a mobile.(
I can connect my Axim X5 to the Internet using my mobile phone via infrared without a problem. You need to create a new dial-up connection using "Generic Infrared" modem in the setup. The number to be dialled is a function of your mobile phone. On my Nokia 6230i the "number" is *99# for creating a GPRS connection. Your mobile phone has to be correctly set up for Internet access and obviously you have to have a data plan.
Dell Axim X5 Pocket PC Logo
221 people viewed this question
Clive
Clive
Alun Cox
