Question about IBM FRU POWER/RESET CARD 73P6310 Power Supply
Reset and order of downloads
(1) My iPod nano 8GB is stuck between the name of the story to be played and the story. I can't turn it off. Reset? If so, how?
(2) I like 1books on CD. So I download Disk 1. I get, say, say 17 tracks. They are listed Track i, Track 2, etc. When I download Disk two, I get.say, 11 tracks. The iPod then reads Track 1, Track 1, Track 2, Track 2. The result, of course is that every 2 or 3 mins, the playback skips from the same track number on disk 1 to the one n disk 2, etc. It seems to me that earlier, the list was 1a, ...11a,,, 1b, ... 10b, etc
Help, please.
Danny Kohl
SOURCE: CD / DVD player not listed as device on Windows Explorer
I also have the same problem. I've tried all the above plus some added info. The floppy still works when I swap it with the DVD. Occasionally it works for a short time right after a hard boot but soon after it appears to uninstall. I have searched the net for answers to this problem without success. I tried the registry correction without avail. There has been some online comments that the problem appeared after an auto update from uSoft. I believe the problem is software or firmware related.
Posted on Dec 28, 2007
colyn25
  • 22 Answers
SOURCE: iPod nano 8gb problem. Just hangs ........ Shanni
hi
turn your hold button on
press and hold menu + select (center) buttons at once until the ipod goes off, so it will restart with the ipod logo. if it that is done successful it will work without any problem.
If the problem persists scan the ipod for any viruses.
if that doesnt work you wil have to use itunes to restore it but with this you will loose all your data.
wish you luck
Posted on Jun 19, 2008
SOURCE: R40 Thinkpad CD drive
I also have an IBM R40 with a combo drive that showed the same symptoms. I switched the drive with two another two which I can assure that work 100% correctly, and the same problem happens. First the drive wasn't detected some of the times, or it got randomly "disconnected" while the laptop was on. Nowadays (about 1 year ago), the drive never gets detected, not by the BIOS or by the operating system (Linux, but also tried on Windows), even so, If I don't keep the drive disconnected, when the laptop boots the BIOS hangs for a long time like it was trying to detect the drive, but it doesn't. It turns out that is a system board problem. Hope this helps you on finding the solution. Regards
Posted on Aug 25, 2008
  • 17 Answers
SOURCE: xseries 346 wont boot
You don't say whether or not your os is on the RAID 5 partition. Assuming that it is (for performance reasons, this is not recommended) then you should check to see if you have the option of configuring a separate raid configuration on your raid card (e.g. do you have a card with more then one RAID channel?) If this is so, I would create a separate RAID 1 array and install the OS just on that. Then you can mount the RAID 5 array with your data intact. Once you're up and running, you can remove the old OS partition, as it's no longer needed.
Posted on Nov 06, 2008
  • 105 Answers
SOURCE: new install scsi hard disk no detect in ibm x3400 server
you will need to add the new drive to your array bbfore it will how up to be formated do this throught the array configuration util
Regards Al "alstech"
Posted on May 26, 2009
How to reset my ipod nano 8gb in factory settings
To reset iPod nano:
1 Toggle the Hold switch on and off (set it to Hold, and then turn it off again).
2 Press and hold the Center and Menu buttons for at least 6 seconds, until the
Apple logo appears.
Sep 09, 2010 | Computers & Internet
I received an Apple IPOD from a friend, and I would like to download my music to the IPOD, but the IPOD is registered in her name and will not let me download any music to it. Is there anyway to...
If it's recognised by iTunes you can restore it.This erases everything and resets it back to factory presets.You can then rename it and put your music on without problems.Apple doesn't allow any form of file sharing but doesn't care how many different people use the same iPods.I have 3 -8GB iTouchs',3 -30GB iPods,1 shuffle and 1 nano.All from Pawn Shops,you can get them for 25 cents on the dollar.
Oct 05, 2009 | Apple iPod shuffle MP3 Player
Ipod nano 8gb scroll pad is stuck. only works with remote on ihome.
try a hard reset... hold the home and play/pause buttons together at the same time until the ipod goes blank... keep holding until you see an apple logo and you ipod should reset and fix the problem
Aug 04, 2009 | Audio Players & Recorders
My 8GB ipod nano froze stuck in the middle of a song. It isn't being recognized by my computer, won't charge, reset, or turn off. HELP!!!!!
Try a hard reset:
Press and hold the Center button, and the Menu button for ten seconds.
This should force a reset, and show you the Apple logo for a few seconds, while it reboots.
Mar 19, 2009 | Apple iPod nano 3rd Generation
Apple iPod Nano is stuck on pause
Mary
Switch the hold on and then off again and then hold the menu and select button at the same time until you see the apple logo.
This should reset the Ipod.
Dec 30, 2008 | Apple iPod nano 3rd Generation
The apple symbol is stuck on screen
Try connecting your IPod to your computer and try the reset process again
It has to work now
Dec 27, 2008 | Apple iPod nano 8 GB Pink (3rd Generation)...
Ipod nano 8GB waiting and frozen problem
ok i'm guessing that you're software is corrupted and you don't know about the resetting of the ipod when it turns on hold menu and the center button at the same time it should reset the ipod and this might work.... if it doesn't hold play and the center button at the same time until you get a screen saying disk mode when you do download a program named idump it allows you to save your music off your ipod as long as you can get it to read on your computer ok once you have all your music downloaded restore your ipod in itunes... this should work it worked everytime my ipod did something funky like this trust me my nano gave me the sad ipod face for weeks and i'd let it sit for about 30 mins then turn it on again and it would be fine so i decided to restore it and i haven't had a problem since i hope this helps
Oct 25, 2008 | Apple iPod nano 3rd Generation
Ipod nano 8gb
First thing to try is a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Oct 21, 2008 | Apple iPod nano
Ipod nano 8GB 3rd generation FROZEN!
You need to reset your ipod. Flip the hold switch on then off, then press select button and menu button at same time. Hold for 10 seconds or so. Ipod should shut off and reboot to apple screen. If this doesn't work first time try again. This should solve any stuck screen problems. Mine was stuck on pioneer screen and this operation fixed it.
Aug 09, 2008 | Apple IPod nano Second Generation MP3...
Ipod nano is hunged in power on
again use the warrenty and trade it in but make backup files of your songs first.
Jul 27, 2008 | Apple iPod nano 3rd Generation
Computers & Internet Logo
41 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
