Question about Compaq Presario 1200XL104 Notebook
Laptop hinges my hp laptop hinges became too tight how to loosen it up
  • bsnrao123 Mar 10, 2009
    I have a HP Pavilion DV5 1004nr laptop. The hinges have become tight. As a result, the screen closes with jerky movements. I am scared that one day it may break 1
The screen is floppy on my Compaq Presario CQ70 and needs tightening can you inform me on how I can resolve this please ?
Check the screen mounting screws on the back of the laptop near the hinges, make sure they are tight.
If these screws ar tight and the screen is loose then the hinges need to be replaces because there are no adjustments available to tighten them.
Replacement hinges may be available from one of these WEB sites.
LAPTOP PARTS
http://www.nylaptopparts.com/
www.laptoprepairco.com/
www.laptopparts.com.au/
www.laptopking.com/
www.lappy.com.au/
www.excelcomputerinc.com/
www.laptoprepairparts.com/
www.lapzone.com/servlet/StoreFront
www.laptoppartsexpert.com/
www.sparepartswarehouse.com/
http://www.sparepartswarehouse.com/
Jul 14, 2011 | HP Compaq Presario CQ70-120US Laptop
Screen hinges are too loose. how do I tighten the hinges and thus take out the play.
Unfortunately, you can't tighten the hinges. All you can do is replace them if they lose their grip and loosen up. They aren't expensive (here's one source on eBay as a sample, and there are others), and it's not too difficult to change them. HP has a document here explaining the procedure. Good luck with the repair, and thanks for using Fixya!
Nov 15, 2010 | HP Compaq nx6310 Notebook
Solve IBM Laptop LCD Hinges Question
make shure the hinges are free from dust and debris. if too tight loosen the screws up a little.
May 23, 2009 | IBM ThinkPad T20 2647 Notebook
Tightening HP Pavilion DV9000 17'' LCD Hinges
you may find the hinges parts from eBay which is cheaper price:
http://shop.ebay.ca/?_from=R40&_trksid=m38&_nkw=HP+Pavilion+DV9000+hinges&_sacat=See-All-Categories
how to replace your laptop hinges:
1) take out the screws at back of laptop under the hinges base
2) or take out the screw at side of laptop near the hinges base (if you find any screw there)
3) there are two cables connect between LCD lid and laptop base
you do not need disconnect those canbles. just careful them
4) take out all scews on the front of lid cover( the scews is covered by thin plastic cover), then take away front lid cover.
5) take out the screws at beside hinge base and side of LCD panel(2-4 scews at one side), you need check the back of lid cover can separate to LCD panel a little., be care replace only one at one time .
6) put back all screws step by step.
hope help you fix it, please take a rating let me know how much you are helped, thanks! any question please let me know!
May 18, 2009 | HP Pavilion dv6000z Notebook
Both hinges of hp dv9000 broke now no displAY SEEN TOO
HP has a recall on the Pavillion lappys
if you call them and be persistent they will send you a box and all you have to do is send it in for a FREE FIX...
My DV9310us has been back to HP 5 times
Happy Fixing =)
Apr 06, 2009 | HP Computers & Internet
My husband tried to fix my machine
It sounds to me that your husband may have loosened one of the cables while repairing the hinge, i would suggest you take it to a local repair shop, you shouldent get charged more then 200$ at the very most (I would charge less then 150$ for this type of repair at my shop, but i cant speak for jacksonville).
Most likely nothing needs to be replaced but HP will overcharge you for typically sub par work.
Jan 19, 2009 | HP Pavilion dv9000z Notebook
UNABLE TO CLOSE LAPTAP NO FREE MOVEMENT ON LEFT SIDE
I believe that's the hinge screws on the computer that's too tight. If you have screwdrivers that can fit into the hole of the left hinge, you can just loosen them up & that should fix it. If you're not sure what to do, just take it to a local store and have them loosen them up.
Hope this helps.
Oct 03, 2008 | HP Pavilion dv9000z Notebook
Tight laptop lcd hinges
dont turn to hard they will break only solution i know is to look on ebay for new ones man
Sep 19, 2008 | Computers & Internet
Toshiba Satellite 2450
It sounds like the hinge itself is broken. I have a relative with exactly the same problem, her laptop screen became floppy and didnt stay in the upright position. The hinges for the screen are complicated in that they appear to come as a top/bottom part already joined together, and need to be replaced as such. The metal used for the hinges is really flimy and easily snaps. this sounds like what has happened to yours. The problem is that is appears to be not econimcally viable to repair, and your probably better off scrapping it or buying another with say;.. a cracked screen and doing a swap-over of parts to get one fully working one (thats what I did)
Feb 25, 2008 | Toshiba Satellite 2450-401 Notebook
Compaq Presario 1200XL104 Notebook Logo
509 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
