Question about Kenmore Elite 45986 Front Load Washer
Chenging the rubber gasket attached to kenmore H2e front load washer
I have a tear in the gray gasket in my front load washer.This is the gasket attached to the machine that fits into the door gasket when closed.My machine is a Canadian model 11047512600.
Can you advise the steps to replace this rubber seal?
  • van709 Sep 22, 2008
    I think there is something between the steel tub and the plastic it is encased in. How do I get to it??
  • mktzach Feb 19, 2009
    tear in rubber sela model 110.45862402
  • 5,911 Answers
The following link provides you with step-by-step instructions on how to change the door bellow:
This is not a difficult repair. Just follow the steps provided. If you have any questions, please let me know. I hope you find this information helpful.
Posted on Sep 02, 2008
Remove the rubber gasket around the door of my Kenmore front load washer to replace the door switch?
its not glued - probably just stuck - if it does rip on you, it's cheap and easy to replace
Jan 03, 2015 | Kenmore Washing Machines
He5t tearing clothes
Are you sure that the clothes are not getting caught on exposed zips.
Why not load some things like towels sheets (without zips/buttons etc) in the washer and see if the issue repeats itself. You should also be able to see if there are any sharp edges or loose sharp items in the drum (mind your fingers)
Dec 14, 2013 | Kenmore Elite 45986 Front Load Washer
Rubber seal and wire has come off the inside of my washer, how do you fix or do you need repair service?
Wire and bellows repair.Check to see if the rubber gasket bellows has a tear. If it loooks good the bellows goes over the front lip of the washer ,than place the wire that should have a spring attached over the lip. you will need a extra set oh hands to help hold the wire in place as you use to butterknifes to slde the spring over the lip.
Dec 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My LG front loading washer is leaking at the door.
carefully check gray door gasket fot tears/waves/stretching on outer edge. if so, replace gasket. be sure gasket and door glass are clean where surfaces meet.
Apr 28, 2010 | LG WM2688H Front Load Washer
Rubber ring ripped
You can buy and fit a new door gasket if you have the required mechanical knowledge
Take the power off , the top off remove the fitting band take off the old gasket and re-assemble in the reverse order
Jan 03, 2010 | GE WSXH208A Front Load Washer
Kenmore HE 2t washer is leaking from the front
thats called a bellow. from a scale of 1-10 id say a 9. front assy of washer needs to come apart to be able to get to gasket rear. that is why it leaking just a small tear or bend on the gasket bye the door will cause it to leak. ive done about 50 of those and it takes me about 1 hr. good luck .if u need furthur assistance let us know. thank you.
Oct 07, 2009 | Kenmore Washing Machines
Kenmore HE 3t Front Loading washer, rubber seal torn
fix it your self and save big,,im going to talk you through..and give you the part number...what you need is the bellows part # 8182119...ok vack unplug the door,,now you see the front lip of the bellow theres a wire with a spring stick a srew driver and pull off,,wire off ..ok now look in the unit right behind the front panel and in front of the tub in the upper right hand corner of tub font or bellows backside there a nut take screwdiver and losen pull bellows off,,easy to put back just reverse but open clamp a bit on back...onthejob
Jan 27, 2009 | Kenmore Elite 45986 Front Load Washer
HE4t kenmore washer rubber drum gasket not attatched.
Removed the top and Front reinstalled the counter balance. the rubber gasket has a 1" tear in it which I patched with a rubber tire patch for now. Two of the locking nuts for the leveling of the machine were loose it went out of level causing the machine to rock and probably caused the counter balance to loosen up. My daughters come in from collage and over load it on weekends which adds to the machines demise. All have been warned.
Jan 17, 2009 | Kenmore Elite 45986 Front Load Washer
Washer is leaking
Check the rubber bellow (gasket) around the door. This is the symptom of a door gasket that it starting to leak. Pull the rubber folds back and check the area where the gasket attaches to the wash tub. You may have a crack or tear. If the gasket is worn please replay back to this post and I can give you advice on how to replace it and where to get a replacement gasket.
May 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
How do I Replace the bellow on a Kenmore 4646
There is a spring that holds the gasket on .Pop that spring off and the gasket should come very easy.
Oct 29, 2007 | Kenmore 46462 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
822 people viewed this question
Sal De
 Brian Main
Brian Main
