Question about Adobe Photoshop 7.0 for PC
Morphing i want to do morphing with the help of vector mask.so,what can i do?
    Problem Solver:
  • 18 Answers
Try this
http://in.youtube.com/watch?v=kgiq-Jqw4OQ
and plz rate me
Posted on Sep 07, 2008
Fanta morph error
The password trouble is not difficult to handle but it can hamper your work very much. The solution is there on the login page itself in the form of the forgot password link. Those users who are not interested with the solution link can get the help directly from the experts at the Yahoo Call Centre Number.
More Info :- http://www.livetechnicianhelp.com/yahoo-toll-free-number.html
Nov 22, 2017 | Nova Development Photo Explosion Deluxe...
My dell optiplex 740 hdd is locked service tag number is 585hw2j
Dell Beep codes
Code
Cause
1-1-2
Microprocessor register failure
1-1-3
NVRAM read/write failure
1-1-4
ROM BIOS checksum failure
1-2-1
Programmable interval timer failure
1-2-2
DMA initialization failure
1-2-3
DMA page register read/write failure
1-3
Video Memory Test failure
1-3-1 through 2-4-4
Memory not being properly identified or used
3-1-1
Slave DMA register failure
3-1-2
Master DMA register failure
3-1-3
Master interrupt mask register failure
3-1-4
Slave interrupt mask register failure
3-2-2
Interrupt vector loading failure
3-2-4
Keyboard Controller Test failure
3-3-1
NVRAM power loss
3-3-2
Invalid NVRAM configuration
3-3-4
3-4-1
Screen initialization failure
3-4-2
Screen retrace failure
3-4-3
Search for video ROM failure
4-2-1
No timer tick
4-2-2
Shutdown failure
4-2-3
Gate A20 failure
4-2-4
Unexpected interrupt in protected mode
4-3-1
Memory failure above address 0FFFFh
4-3-3
Timer-chip counter 2 failure
4-3-4
Time-of-day clock stopped
4-4-1
Serial or parallel port test failure
4-4-2
Failure to decompress code to shadowed memory
4-4-3
Math-coprocessor test failure
4-4-4
Cache test failure
Oct 08, 2012 | Dell OptiPlex 740 PC Desktop
What is vector masking ? how can use it?
Using Vector Masks Let's look at the different ways that a vector mask can be used, created, and/or edited:
· Add a vector mask that shows or hides an entire layer
· Add a vector mask that shows only the content inside the shape that has been created by a path
· Edit a vector mask that is already created
· Remove, disable, or enable a vector mask
· Convert a vector mask to a layer mask (rasterize the vector data)
Additionally:
· To add a vector mask that hides or shows an entire layer, select the layer from the Layer palette that you want to add the vector mask to. Choose Layer>Add Vector Mask>Hide All or Reveal All. (If these are grayed out, make a copy of the layer first.)
· To add a vector mask that shows the contents of a shape, select the layer to apply the mask to in the Layers palette, select the path from the Paths palette, and choose Layer>Add Vector Mask>Current Path.
· To edit a vector mask, click the vector mask thumbnail in either the Layer or Paths palettes. Edit the mask using the Shape or Pen tools.
· To delete a vector mask, select it and choose Layer>Delete Vector Mask.
· To enable or disable a vector mask, select it and then choose Layer>Enable Vector Mask or Layer>Disable Vector Mask.
· To convert a vector mask to a layer mask, choose Layer>Rasterize>Vector Mask.
Feb 21, 2011 | Adobe Photoshop CS5 Upsell from Photoshop...
How to change valves in topeak mountain morph
Unscrew the ring at the front of the valve adapter. You will pull out an assembly consisting of a plastic piece and a rubber ring. When you take these two pieces apart and put them together by turning them around. the rubber section goes in the front.
Hope this helps,
matthew
Oct 21, 2009 | Topeak Cycling
Re-assembling a portable bike pump
Thanks so much for this opportunity. Soon after contacting you, I found a site, complete with video demonstration. Just by seeing the pump in its dormant position, I was able to deduce how to reassemble it. You can see the link below.
http://video.google.com/videosearch?client=safari&rls=en&q=%22Topeak+Road+Morph+Bike+Pump%22,+manual&oe=UTF-8&um=1&ie=UTF-8&ei=qU7WSpLyEpKZtgeaufGJBw&sa=X&oi=video_result_group&ct=title&resnum=4&ved=0CCUQqwQwAw#
Oct 14, 2009 | Topeak Road Morph Bike Pump
Picture distortion
check the settings on the dvd as if you set the dvd to 4:3 format for instance, the picture will be "squashed" to a letter box format and when you play on wide screen it will become "morphed" and mishaped. also if the tv is set to wide all the time, then this will cause a stretching effect. set the tv to auto picture size or "smart" as it is on sony's, with auto 16:9 on.
Oct 07, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Company contact???
contacted a business/website that carried multiple items by wild republic and just asked for the info/contact #.
Dec 31, 2008 | Magna Wild Republic Medieval Morphs Brown...
Illustrator to photoshop
Here is everything you will need. I hope you will find this worthy of a FixYa rating.
Import Illustrator CS2-CS3 artwork into Photoshop CS2-CS3
What's covered In Adobe Photoshop, you can import Adobe Illustrator artwork in several different ways, each of which offers a different level of control. When you open or place AI, EPS, or PDF files created by Illustrator, Photoshop rasterizes vector artwork and removes the ability to edit transparency, fonts, layers, and paths. To retain more control over imported Illustrator artwork, Adobe recommends that you drag or paste it into a Photoshop image or export it in Photoshop format.
Drag Illustrator artwork into Photoshop Dragging Illustrator artwork is the quickest way to import it into Photoshop. By default, Photoshop creates a new layer for the dragged artwork and imports the artwork as a Vector Smart Object. (For more information, see "Smart Objects" in the Photoshop Help.) You can import dragged vector artwork as a work path, however, by holding down Control (Windows) or Command (Mac OS) while dragging. To center imported artwork in the Photoshop image, hold down Shift while dragging.
Note: To import dragged type as a work path, you must first convert it to outlines in Illustrator. For more information, see "Modifying letterforms as graphic objects" in Illustrator Help.
Paste Illustrator artwork into Photoshop When you copy Illustrator artwork, you can paste it into Photoshop and retain many Illustrator features. To do so, however, you must properly configure Clipboard preferences in Illustrator.
The Illustrator Clipboard supports a variety of formats including: PICT, PDF, and AICB. Though Illustrator always copies PICT data to the clipboard, you can configure Illustrator so that it also copies PDF or AICB format. These two formats allow you to retain Illustrator features in artwork pasted in Photoshop. PDF retains Illustrator transparency, while AICB format retains Illustrator paths.
You should only select the AICB format by itself if you are going to be pasting paths in to Photoshop. In all other cases, select the PDF format or the PDF format in conjunction with AICB. The PDF format retains transparency and other features in Illustrator such as extended support for spot colors.
To configure Clipboard preferences in Illustrator:
  1. Choose Edit > Preferences > Files & Clipboard (Windows) or Illustrator > Preferences > Files & Clipboard (Mac OS X).
  2. In the Clipboard section, select the desired format.
  3. If you selected AICB, select either Preserve Paths or Preserve Appearance.
  4. Click OK.
Paste options in Photoshop
When you use the Paste command to import copied Illustrator artwork, Photoshop provides the following options in the Paste dialog box:
  • Paste as Smart Object: Pastes the art as a Vector Smart Object that can be scaled, transformed, or moved without degrading the image before it's placed into the Photoshop document. As the art is placed, its file data is embedded in the Photoshop document and the art is rasterized on a separate layer.
  • Paste as Pixels: Pastes the copied artwork in a new layer and rasterizes it at the resolution of the Photoshop image. Use this option when pasting raster objects.
    Note: When you use this option, clipping masks for raster images are not retained as paths. These masks still clip images, however.
  • Paste as Path: Pastes the copied artwork as a work path.
  • Paste as Shape Layer: Pastes the copied artwork in a new vector shape layer. Compound Illustrator shapes retain their attributes and remain editable. Multiple copied paths and clipping masks are pasted as multiple paths that use the unite attribute .
    Note: When you use this option, pasted objects use the foreground color in Photoshop, not the fill color they use in Illustrator. Likewise, transparent objects become opaque.
Export Illustrator files in Photoshop format Exporting Illustrator documents files in Photoshop format gives you the most control over Illustrator artwork in Photoshop. With this method, you can specify resolution and enable anti-aliasing for rasterized artwork. You can also retain the following Illustrator features:
  • Editable text
  • ICC profiles
  • Layers, including nested and hidden layers
  • Masks
  • Transparency
  • Compound shapes
  • Slices and image maps
Note: A compound shape must have either no stroke or a stroke with a round join that uses whole integers for the stroke weight. However, the compound shape can reside on a layer with other objects. In that situation, Photoshop places the other objects on a separate layer in the same layer set.
For more information about exporting Illustrator files in Photoshop format, see "Photoshop export options" in Illustrator Help.
Open Illustrator (AI) files in Photoshop You can open AI files in Photoshop if you save them using the Create PDF Compatible File option.
To save an AI file using the Create PDF Compatible File option:
  1. Choose File > Save As.
  2. Choose Illustrator (*.AI) as the file format, and click Save.
  3. Click Create PDF Compatible File in the Illustrator Options dialog box, and click OK.
Thanks,
Lee
Jun 18, 2008 | Adobe Photoshop 7.0 for PC
Adobe Photoshop 7.0 for PC Logo
65 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
