Question about Sony Cyber-Shot DSC-S85 Digital Camera
Power Lever Unoperational
Hello, My S85 has developed a strange fault. The spingy power lever no longer turns the camera off, it just 'resets' it, ie, turns it off for a second and turns it back on again. The same happens with auto shut off. after three minutes of inactivity, the camera switches off and straight back on again. Because the power is always on, i can no longer charge the battery through the AC port. The only way to shut it off is to remove the battery. Does anyone have any ideas? Please help, i love this camera. Best wishes,
  • sunesd Dec 29, 2007
    same problem here....
Sent my dsc-s85 to Sony 2 times. Both times it was returned "fixed" but the problem still exists. It's been that way since I pulled it from the package and I just use it plugged in ALL the time! I wish someone really knew what the problem was. I'm gonna try another battery, since that's about the only thing that I haven't tried yet!
Posted on Dec 29, 2007
    Sergeant:
  • 255 Answers
Take it to the sony service, or if they charge to much to some experienced electrician.
Posted on Sep 13, 2005
I cannot start my Celebrity X mobility scooter. Drops into free wheel when I apply power lever.
After a fault has accorded with the scooter and you have reset the fault. Turn off the scooter with the key and count to 10 then switch on again. This will reset the fault in the system. If still have fault, try moving the lever in and out a few times in case the brake micro switch does not make circuit properly.
Mar 21, 2015 | Health & Beauty
Light is blinking a 7 fault code, what does this fault code mean.
According to the owner's manual for this scooter, flash code 7 indicates a speed control lever fault. This is the lever that you push to go forward and reverse. The lever is attached to a throttle potentiometer to control the speed of the scooter. The lever has to be in the middle or neutral position when the scooter is turned on, if not, you will get a 7 flash code. If the throttle potentiometer is damaged you will also get a flash code 7.
You can try to adjust the throttle pot or try manipulating the neutral position and turning the scooter on and off until the computer sees neutral. This is a potential work around and will cause the scooter to creep forward when running with hands off the throttle lever because there is no zero setting. I usually just replace the throttle potentiometer and this solves the problem. I hope this helps.
Oct 23, 2014 | Drive Medical Spitfire Travel 4-Wheel...
Fisher and Paykel IW609 Intuitive Washer powers up then dies
SOLVED!! The sequence described in the original posting is of course exactly what the unit does on power-up anyway. The problem turned out to be a power button that was non-functional, because the small plastic lever that actuates it from the front panel had slipped off the side of the button spigot and was jammed beside the spigot. Unscrewed the PCB behind the front panel to free the lever and put the PCB back. 5-minute fix!.
Aug 18, 2012 | Fisher and Paykel Washing Machines
How do I use the self timer on my Pentax K-x?
You aren't supposed to leave the timer cocked for long periods, probably because it could wear out the timer spring (similar to the reason you aren't supposed to store the camera for long priods with the shutter cocked).
I thought that you set the timer by rotating the timer lever 90 degrees or more counter clockwise (when looking at the front of the camera). The further you rotate the timer, the longer it will run. Moving the timer lever exposes the start lever underneath the timer. Pulling the timer lever counter clockwise (it starts out pointed straight up) will start the timer, and putting the start lever back in it's original position will stop the timer.
Once the timer is stopped it is possible to take a picture by releasing the shutter normally, the timer can be restarted, or the timer can be reset for a longer time. After the timer is stopped it should be restarted and allowed to count down to zero before the camera is stored. I'm almost certain that the timer can only fire the camera if the shutter is already cocked, so it is safe to release the timer and let it run down any time that the camera is not cocked.
Good luck and do rate the solution if helped
Nov 27, 2010 | Pentax Cameras
HP3800 has blurry text. Changed cartridges, transfer belt, high volt power supply, lever locks, formatter, dc controller
Hello sir; Sound like you change a lots of things but only one important item you missed it that is developer, try again!
Oct 27, 2009 | HP LaserJet 3800n Printer
Nikon fm10 cannot get shuuter release button to depress or film advance lever to work. is there a lock on shutter release ?
The film lever is also a switch. If you had advanced the film lever, **** it outward a little. You will feel the detent click somewhat when doing so. Leave the lever outward and see if the shutter will work. The detent is for appling an closed circuit for the light meter. When the lever is fully pushed back in it shuts the power to the meter on off to conserve battery power
Oct 13, 2009 | Nikon FM10 35mm SLR Camera
Samsung S85 problem
I have had similar symptoms that seem to be due to battery power.
Using and OHM meter I find that the Samsung S85 eats batteries. If the charge drops to 1.4 something volts from a 1.5+ volt battery, the camera does not function properly.
The camera is nice an compact ... but I need to carry the same volume in batteries to make sure I can use it.
Jun 17, 2009 | Samsung S850 Digital Camera
How do I turn this camera off ????
Hi there. The power off lever is on the shutter release button. (the button you press to take a picture).
There are 3 positions for this lever, they are:
Power off is the middle setting while Power on is the top setting and the Self-timer as the bottom setting.
Replace your battery and remember to move the lever to the middle position to turn it off when your done. Don't forget to rate my solution, and have fun with your camera!
Rob
Mar 03, 2009 | Canon EOS-AE-1 35mm SLR Camera
Flaky zoom
Are you are sure that the problem is in the lever?
If it is so, I have a solution!
We used to play that trick on the old Machine of 80-90s. Just put 1-2 drop of kerosin oil into the contact of the lever after opening that for a while.
Thats all.
Play that lever for number of times before turn that on.
You will get benefit for at least 1 year!
You can use non lubricated machine oil instade of kerosin oil also!
Hope for the best!
Ekram, from Bangladesh
Nov 15, 2007 | Sony Handycam DCR-DVD505 DVD Camcorder
Hung up
check the power supply section for faults. If you need any spare parts,we can help.
Nov 26, 2006 | Sony Cyber-Shot DSC-S85 Digital Camera
Sony Cyber-Shot DSC-S85 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Syzys
Are you a Sony Camera Expert? Answer questions, earn points and help others
