If you take a jeweler's lupe near where the arrow is you will see the word "reset" in the plastic. There is a deep hole in the plastic with contacts below. That is the reset, and that is why you must use very sharp pointed tweezers to make contact with the back of the battery.
I think if you do not have sharp tweezers, you can probably put a sewing pin down the hole, and then connect with a small screwdriver to the back of the battery..
If you don't have the proper tools I recommend that you not do this yourself. You could scratch the case or damage the movement if you don't know what you're doing. If it's a water resistant watch the gasket also needs to be replaced once it is opened. DO NOT reuse a gasket! For about $8 any watch or jewelry store can change the battery and renew the gasket for you.
This watch will have what is called and "AC" or All clear to reset it. There should be a white sticker with very small print on the back lid that will walk you through doing this procedure. It typically involves pressing down a tiny lever onto a small metal pad that will reset the watch.
You will find them on the module itself.
So after replacing the battery look on the PCB (printed circuit board) for the letters"AC" and "VSS". Adjacent to these markings there should be little contact points (probably gold or silver looking in colour)
Use a paper clip or similar and bridge (short) these two points simultaneously. Please rate my solution.
Hello RLOWE803, While I was looking for pictures specific to resetting this watch, I came across your post and thought to reply. I recently replaced the batteries on my watch, which I have owned for nearly 7 years. It is an Ironman Triathlon 100 Lap watch. When I replaced the batteries this time, I forgot to reset, in essence reboot the system, by using a metal needle point tweezers to briefly connect the positive side of the battery to the "AC" pad on the small circuit board for at least 2 seconds. I remembered to do this with at all the other times I had replaced the battery and did not have any troubles after it. This time I forgot and now have the same issue you described. I am not sure where the "AC" pad is on the back of the module. But, it should be apparent if I did it correctly in the past. Give that a try before sending it off to be repair and wasting time, money and trouble. Good luck, CAZ
Hi All,
I received an email from Timex customer tech support to take it to a jewler which pretty much means buy a new one. Not worth the cost of the battery and repair. I have the tools so I might as well try it myself. Either way, I will either fix it or buy another watch.
I have a Timex Digital Heart Rate Monitor 585 (product code T5C351F5)m, which has the same Short AC Pad and battery +ve message. There is an arrowhead pointing to the pad. It's a raised metal platform - a bit different to some of the Ironman's mentioned above. Here is a pic...
