Question about Forfex FX 785 Hair Trimmer
Supply cable to the trimmer seems to have a loose connection, but i cant remove the cover to repair it. The cover only has one screw to undo but cover does not seem to come off. was wondering if anyone has encountered this problem before. Many thanks for your help.
You have unscrewed the first screw. take the blades off the clipper then pull the black plastic cover away from the silver section undo the two screws at the top and slide the silver section forwards then lift off the black cover shorten wire by cutting and soldering. T he problem was and allways will be broken wire . Maybe I should stop cutting hair and fix clippers
regards
Dave
Posted on Sep 11, 2008
Mine's a bent shaft. I guess only Victa agents can replace/repair the centrifugal clutch or internal broken cable?
not necessarily--- the broken drive cable can be removed /replaced by removing the trimmer head from the shaft at the bottom
undo the clamp and if there is a small screw/ bolt into the shaft undo that as well and pull the head off
the flexible drive cable will slip out
check the ends and they should be square in form
Mostly the cable breaks but occasionally that square section will wear round
slip in a new cable and reassemble
Oct 16, 2015 | Garden
Cant remove screen seems glued on hp pavillion dv5 1007
ummm, i'd doubt that it is glued unless you had the screen repair previously by a shoddy repair shop. First of all normally the screens are held in place by screws that are hidden by little rubber bumper covers or some type of covering on the plastic that is around the screen. Use a safety pin or small flat head screwdriver to remove the covers and expose the screws. Then use a phillips head screw driver to remove the screws. Once all the screws are removed use your fingers to slide along the inside of the plastic around the screen and pry it loose from the screen.
Mar 10, 2012 | Computers & Internet
Removing bell housing
hello sir, ryobi trimmers and other models removal of the bell housing,removal of the metal bell housing,or clutch drum, on models 780R & 790R, here is what you do. after removing the trimmer & shaft assembly.remove the spark plug insert a screwdriver in the cylinder to keep piston from moveing. to remove the bell housing twist off the spring and using a T20 TORX screwdriver unscrew the retaining screw in the center of the bell housing (normal r/h thread) . push down firmely try not to strip screw head . you should be able to remove clutch housing.remove clutch using a pair of channel locks,works for me, (normal r/h thread) you should be able to remove front engine cover to repair what you need to.coil,pull stsrt, hope this works,. this solution applies to all trimmers with clutch removal~~~hope this helps,,any comments welcome,thank you. ``
Feb 10, 2012 | Daihatsu Rocky Cars & Trucks
Ups no displya
The older versions of the PW9120 UPS systems have a problem with the inside ribbon cable connection. Remove the front plastic cover plate by sticking each of your little fingers to push up the 2 plastic tabs on the underside of the front cover. Pull forward at the bottom of the front cover and carefully tap the top of the plastic cover down to undo the inside plastic tabs. Let the front cover swing on the ribbon cable.
You will need a Torx screwdriver to remove the side cover screws - 2 at the back and 4 on each side. Lift the steel case up and forward. Follow the ribbon cable to the connector on the top PC board of the UPS. If the ribbon cable is loose, push it back up into the connector, scrape off any silicon glue, then apply new silicon glue or black automotive silicone(holds better).
If this does not seem to be the problem, check the ribbon cable at the front cover plate end to see if the plastic cover for the ribbon cable anchor and its 2 screws are still locking it in place.
If you still don't have a display, the top PC board for your UPS is not working. It will have to be replaced and since these units are discontinued you may have to try to get a unit from you local recycler, or you could contact Gruber in the US to see if they will sell you a part.
Jan 07, 2011 | Powerware 9120 UPS System
Cannot undo nut on bottom of Strimmer
Make sure you are turning the nut to the right to loosen, if you are already doing that but cannot hold the line head still to loosen the nut some feature a hole to insert a screwdriver or pin (supplied with the trimmer) or if yours does not have that: use a nylon strap or even a leather belt to wrap around the head, and then clamp the loose end in a vise or quick clamps and it will hold it in place well enough to loosen the bolt.
Jun 16, 2010 | Homelite Mighty Lite Lawn Trimmer
How do you get underneath the keyboard
You don't need to remove the keyboard to access the ram. Just undo the single crosshead screw on the removable cover in the middle of the laptop from beneath. I you do ever need to remove the keyboard there are 2 screws underneath this cover, which are marked with a keyboard symbol. Undo these and then slide the 4 small lugs at the top of the keyboard and it will lift up
Jan 04, 2010 | HP Compaq nx6325 Notebook
Replace recoil starter for Homelite trimmer Model UT21546
My UT21546 has 2 springs, the regular recoil one and a what I'll call a anti kickback one. the top of the anti kickback spring kept coming unsecured and finally I just deleated it alltogther and screwed the 2 plates tightly togehter and the near new unit works better than new now.
Apr 29, 2009 | Homelite Mighty Lite Lawn Trimmer
Starter cord has detached internally and I cannot get to it
Depending what make and how old the machine is,usually there is a torx screw in the middle of the clutch drum(metal part that rotates).you will need to use a piston stop,to stop the engine turning while trying to undo the torx screw. i am assumig the starter is in front of the engine not at the back. once the screw is undone the clutch will come off and so will the starter cover. neil
Sep 28, 2008 | Troy Bilt Tb70ss Gas Trimmer
Right speaker stops working
A couple of years later, but maybe this will be useful to someone:
1. Disconnect the cables (input, power, 2nd speaker).
2. Undo the two screws on the base of the casing.
3. The two knobs can be pulled off. Underneath there are two nuts that hold the spindles to the casing. Undo these.
4. The fabric cover is a push fit. Prise it off the front. If needed, use a (non-metal) tool that won't damage the plastic casing.
5. Under the cover, the two top holes contain screws - undo these.
6. Four screws hold the actual speaker to the casing. The two lower ones are slightly longer and also hold the casing together. Note this for reassembly.
7. You can now gently part the front and rear parts of the speaker housing.
8. To completely separate the parts, you need to disconnect the red and black wires that go the the speaker. The are push fit 'spade' type connectors - a tight fit, but removable.
My problem is similar - loss of left channel. I think the problem is in the headphone socket as wobbling it or inserting non-conducting objects can temporarily restore the channel. These sockets switch off the speaker when you plug in the jack, so I think the switch is faulty. I plan to desolder this part to inspect, repair, replace or bridge the connection and do without the socket.
Hope that helps.
Aug 05, 2008 | Harman Kardon HK19.5 Computer Speakers
Forfex FX 785 Hair Trimmer Logo
119 people viewed this question
Top Forfex Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Forfex Health and Beauty Expert? Answer questions, earn points and help others
