Question about Sony SNCRZ25N Network Camera
SNC-RZ25 No Video
I can ping the IP address, but when I go to pull the GUI up on an internet browser nothing happens
  • JUANTA Jan 09, 2009
    The camera do not turn on; and I am connecting a 12Vdc
    Regards
  • Anonymous Mar 23, 2014
    Is there a fuse Inside SNC-rz25?
    Champion:
  • 232 Answers
ADD THE SOFTWARE MANUALLY TO THE FIREWALL LIST, CHECK UR ROUTER SETTINFG FOR FIREWALL
Posted on Sep 02, 2008
Belkin f9k11009v1, Macintosh unable to connect
First see if you are able to connect to the internet wired to the router,
-If you are able to connect using the wire connection then I suggest to turn off the wireless security settings for the time being and see what happens.
Wireless
See if you are able to ping your router.
Ref: http://www.wikihow.com/Ping-on-Mac-OS
-Make sure that the TCP/IP settings are set to DHCP and make sure that it is getting an IP address and Default Gateway.
If you are able to ping the router then see if you are able to ping google by name and by IP. (An IP address for google,com is 74.125.141.100)
If you are able to ping both then you should be able to access the internet.
If you are able to ping only the google's IP address then you have a DNS issue.
-See if you can set your DNS address manualy to 8.8.8.8 and 8.8.4.4. Ref: https://developers.google.com/speed/public-dns/
If you are able to ping only google by name then see if you are able to access google by typing in the replied IP address in the address bar of your web browser on a computer that is working fine.
-If you are not able to access google with the address then you may have something stooping you on your machine. Check for firewalls and antivirus to see if they have any network configurations.
Dec 18, 2012 | Belkin F5D7234-4 Router
I forget a pasward air live 5400cpe now what i do
you would need to directly connect your computer ( Laptop ) and access point.
check ip address of your access point in Command prompt = ipconfig
once you have your access point's ip, pull up a browser ( Internet Explorer ) and place ip address on the address bar and press enter. once your inside the GUI (Graphic User Interface ) of your AP, click wireless security so you can see your password.
May 31, 2011 | Computers & Internet
Internet connection problems
Troubleshooting Internet Connection Problems The purpose of this section is to give general tips
on troubleshooting your Internet Connection
While there are many possible configurations, I'll try and cover the most common ones.
Making Sure You Have Correct IP Information
Basic PING Tests
Browser Configuration
Making Sure You Have Correct IP Information 1. Make sure you have the correct IP scheme for your network. This would include the:
  • IP Address
  • Subnet Mask
  • Default Gateway
  • DNS Servers
2. There are a few ways you can see what IP addresses are being assigned.
But generally for:Win9x - Start / Run / command
Windows2000/XP/Vista - Start / Run / cmd
The run IPCONFIG /ALL. A sample where a router is used is in the following graphic.
ipconfig.jpg 3. IP Address:
If you have a router, common examples would be:
192.168.0.x, 192.168.1.x or 10.0.0.xIf you are directly connect to your DSL or Cable Modem, you should have an IP address that would correspond to something from your ISP.
What you don't want to have is something like 169.254.x.x. This means you are not getting and IP address assigned and needs to be resolved first.
4. Subnet Mask:
Also make sure you have the correct Subnet Mask. Most commonly this would be 255.255.255.0 5. Default Gateway:
Make sure you have the correct Default Gateway IP address.
With a router, this is typically the IP address of your router. 6. DNS Servers:
Make sure you have the correct DNS Servers. Sometimes this is the IP address of your router, so it would be the same as the Gateway IP.
Sometimes (as in this example), it is the actual DNS servers used by the ISP.
7. Possible causes for not getting an IP address assigned are:1. Defective cable, network card or port on the router. Make sure you are using all known working components.
2. Your router is not configured for DHCP (which would automatically be assigning IP addresses).
But you need to have this correct before proceeding.
Basic PING Tests 1. This and can be done from that same command prompt you used to run IPCONFIG 2. Try pinging the router's IP addresse.g. ping 192.168.1.1
If you get a reply, then your connection to the router is working.
If you don't get a reply, then you need to double check your network card, cable, port on the router. You might also see if any other computers on the network can do the same.
3. Try pinging an external site by IP address e.g. ping 4.2.2.1
If you get a reply, then you have a connection to the Internet.
If you don't get a reply, there are several things you can try:
1. Double check that the router is connecting to the Internet. Typically you can access the router through your web browser and check it's status.
2. Take the power off your DSL/Cable modem and Router. Plug the modem back in a wait a minute or so. Plug the router back in and wait a minute or so. Then restart your computer.
3. Winsock Fix - It is possible that the Winsock Registry entries have gotten corrupted. This is getting to be a more common problem. See WINSOCK FIX for clean ones you can download
4. Try pinging an external site by Namee.g. ping www.yahoo.com
If you get a reply, then you have a connection to the Internet and DNS is working
1. Double check your DNS entries
2. You many need to use the same DNS IP address that your ISP or Router is using.
3. On rare occasions your ISP has problems with their DNS servers. But that is rare in comparison to misconfigured computers.
If your PING tests work but you are having problems browsing sites on the Internet 1. If you could ping external sites by both IP address and Name, but cannot browse the web, likely your web browser is misconfigured. 2. Double check that you don't have an incorrect or not needed Proxy server assigned.For the Internet Explorer - Tools / Internet Options / Connections tab / LAN settings button. Uncheck both Automatically detect settings and Use a proxy server for your LAN.
Mar 28, 2010 | HP Pavilion dv9720us Notebook
I cannot access my router's configuration page at the ip address 192.168.0.1 nothing comes up, but it does say i am connected with limited connectivity. I didnt make any adjustments, the internet was...
the reason is the password on the GUi and in your computer is not match. You need to access the GUI by opening a browser then type the ip address of your router. You need to contact your ISP to assist you in configuring your wireless account.
Nov 26, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Cant see snc rz30n, appear ip ip setup window, won't load page
Enable network and then give ip in the address bar of browser the home page will be browse.
Jul 11, 2009 | Sony SNC-RZ30N Network Camera
I need to be able to ping the SonicWall TZ190 wan ip from the Internet for tracert puposes. There is no ping response to that IP address. The manual says. Click Objects, and then Services. Verify that...
Saibrains is correct unless your firmware is of earlier version. you might have to upgrade your firmware. Also you can not use a port #
No ports required for Ping as it uses icmp packets
It needs to allow icmp 'echo-request' (type 8) packets out and icmp 'echo-reply' (type 0) packets in
to allow ping request. On earlier versions of the sonicwall firmware it only absorbed Ping request as to stop hackers from ping attacking pass the firewall.
check the manufactures website for your model and see if they have newwer firmware.
The GUI should have a place where you can set it up
Apr 09, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
Cant connect to SNCRZ25N via browser.
SNC-RZ25N Sony Network MPEG4 Pan-Tilt-Zoom Color Security Camera ... the SNC-RZ25 is the perfect MPEG-4 PTZ network camera for your remote ..... Sony Security - IP SNCRZ25N network ptz camera with 340 degrees pan, ... 1 2 3 next ... they do not reflect our opinions and we have no responsibility for their content.
Mar 27, 2009 | Sony SNCRZ25N Network Camera Snc RZ25N
Getting a router signal, but no internet
Have you check if you have a valid IP address? You could run IPconfig in the DOS window to verify this. If you have a valid IP address, try pinging the default gateway (You should be able to ping it.) Then, try to ping a website. If you could ping a website or URL but still can't browse check your firewall settings and optimize your browser.
Please post here what happen.
Thanks and regards,
BeHar
Jan 18, 2009 | Linksys (WRT54GC) Router
Http 400 bad request
download latest expoyer 7 ok and update cam software and windows driver if any
Jan 24, 2008 | Sony SNC-RZ30N Network Camera
Sony SNCRZ25N Network Camera Logo
197 people viewed this question
Top Sony Home Security Experts
JonSnell Electronic
JonSnell Electronic
The Los Man
Level 1 Expert
Nitin Khatri
Nitin Khatri
Are you a Sony Home Security Expert? Answer questions, earn points and help others
