Question about Sony Cyber-Shot DSC-P5 Digital Camera
Memory Card Problem
Hi I have a Sony DSC-P5 3.2MP which has been a good enough camera for several years. Now, I am having problems. I insert an empty memory stick and it tells me there is no memory space, and this happens with 4 different sticks, one of which is only a few months old. Is this a camera problem or a memory stick problem? Can I do anything to fix it? Thanks!
    Sergeant:
  • 255 Answers
Put your camera in setup mode and find the menu option for formatting the Memory Stick, and format one of them. See if that gets you back in business. You say you know the Memory Sticks are empty, so when you format them you're not losing pictures (formatting a memory device like a Memory Stick wipes out the data that keeps track of stored files, effectively erasing the memory... although formatting usually doesn't actually overwrite and blank out all of the stored data it will cause your camera to "see" the Memory Stick as a nice, new, empty critter.) This may help you troubleshoot the problem. If formatting the Memory Sticks fixes things, you're all set. If it doesn't fix any of your four Memory Sticks, the logical suspect is a fault inside the camera's memory access circuitry. If formatting will fix some but not all of the Memory Sticks, you will have identified "bad" sticks and will know which one(s) to toss out. Be careful with "canned air" around electronics. It's important to read the directions and pay attention to the orientation of teh can. If you discharge the canned air in a downward direction you might also discarge some of the product in supercold liquid form, which can mess up cosmetics of camera finishes and can have unpredictable (as in: not good) results on electronic bits. Used with care it is okay stuff. But we do hear on these forums the occasional "oops, oh dear!" story about canned air. A blower brush works just as well for most things, and will last for years, and is available for a few dollars at any good camera store. Hope that helps. Be well,
Posted on Sep 13, 2005
    Sergeant:
  • 255 Answers
You probably have some other card reader device to get data off your Memory Sticks... does THAT device read the cards properly, and are the cards in fact all full? Also, check for lint or dust in the slot inside your Sony digicam. It could be blocking one or more of the contact pins.
    Sergeant:
  • 255 Answers
Have you (or can you) formated the memory sticks when they're in the camera?
SOURCE:
Hi - I am getting an error message when i switch on my Sony Cybershot dsc t9 saying access and then it flashes format error C13.01 - can you advise how to resolve?
It might be due to a bad contact of the placed memorycard.
1. Pull the memorycard out and in the camera several times and retry.
2. If not OK, format the card in the camera. If that does not work, format it in the computer.
3. Try another memorycard and recheck.
Sep 04, 2011 | Sony Cyber-shot DSC-T9 Digital Camera
Sony Cyber Shot DSC-H9
The camera may display a MEMORY STICK ERROR or C:13:xx message (xx can be any random number) on the LCD screen for the following reasons:
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  1. Remove and re-insert the Memory Stick® media several times.
  2. The inserted Memory Stick media is not compatible with the camera. Check your instruction manual for information regarding Memory Stick media compatibility.
  3. The inserted Memory Stick media is not formatted. Format the Memory Stick media using the FORMAT option in the camera menu. WARNING: There is a risk of data loss. Formatting will erase all stored data, images, movies, etc., from the Memory Stick media.
  4. The terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
  5. The data on the Memory Stick media or the Memory Stick media itself is damaged. Try using a different Memory Stick media in the camera.
Thanks
Proton
Oct 02, 2008 | Sony Cyber-shot DSC-H9 Digital Camera
I have Sony DSC H7 camera and when i insert my Scan Disk 4GB memory card it gives me error as "Re-insert memory stck", please advice
Your Sony camera is designed to use only memory stick PRO DUO with maximum memory 8 GB. It will not accept other memory cards. If you have been use memory stick pro duo and still request you to re-insert card. Remove your card and re-insert firmly. Regards
Dec 13, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
Problem with memory card
Have you tried using the software that came with the camera? Sometimes that might be able to format your memory card or maybe the card died.
Apr 13, 2010 | Sony Cyber-Shot DSC-T5 Digital Camera
Nikon D40X quit working - memory card access lamp flashing??
As per the Samsung digimax range, internal memory seems to be faulty. Insert an external memory card and try to power up the camera.....
Oct 08, 2008 | Sony Cyber-shot DSC-S730 Digital Camera
DSC F707 Error C:13:01
Can't use Memory Stick PRO's on the DSC 707, they won't format. The technology of the PRO's postdates the 707's.
Aug 10, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
Sony DSC-W80 Digital Camera Problems emptying memory card
You should format the memory stick. This can be done from your camera.
Jun 16, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
DSC H9 Memory stick
Try formatting the memory card with your PC and an external card reader and then try again.
Mar 27, 2008 | Sony Cyber-shot DSC-H9 Digital Camera
Sony Cybershot DSC S650 Memory stick not formatting
Well I have the same camera.
And mine won't turn on.
Suggestion dont trust this camera.
Or maybe it just can't hold that much memory.
Mar 15, 2008 | Sony Cybershot S650 Digital Camera
Sony Cyber-Shot DSC-P5 Digital Camera Logo
89 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
