Question about Boating
OUtboard motor tilt not working
The electric tilt is not working and we have to remove boat from lake before winter sets in. Is there a manual tilt on the motor?
  • caligirl41 Sep 02, 2008
    The trim wont move up or down what could this be?
There should be a hydraulic bypass valve screw on the tilt assembly. Usually a large slotted screw driver is needed to loosen the valve. The motor can now be lifted manually, but not with ease.
Posted on Jan 26, 2009
    Scholar:
  • 157 Answers
Hello moose10 & caligirl41. I only know of electric tilts controlling a hydraulic pump and valves. There outboards and inboard motors with tilts controled by both, a mechanical manual lift as a backup in some cases. I suggest you check the level in your reservoir of hydraulic fluid. This chamber may or may not be available with the boat in the water. Watch for leaks. The other possibility is electrical. Check for the sound of the pump pumping when activating, if no sound check your switch, wiring and electrical power to the controls.I wish you the best in your indevor.
Posted on Sep 29, 2008
Cannot raise or lower 115johnson outboard with manual relief valve open
If, even with relief valve open you can't raise or lower the motor by hand, your tilt tube is stuck.
remove your steering cable.
Remove the 2 big nuts on the tilt tube;
unbolt the engine from the boat
unbolt the trim/tilt system from sb and pt bracket.
Remove brackets. Remove tilt tube from steering bracket
Clean everything
Replace the bushings
Use triple-guard grease everywhere on reassembly
Jul 31, 2017 | Boating
How to winterize 175 mariner outboard motor
Take a look at these instruction videos.
How to Winterize an Outboard boat, step by step guide in ...
9k=? 11:25 https://www.youtube.com/watch?v=x217iM77Qjc Oct 30, 2012 - Uploaded by Warren Hardy A detailed step by step guide to winterizing your outboard boat motor for ... most 2-stroke outboards ...
Winterizing Your Boat: Step 2 The Engine & Lower Unit ...
9k=? 10:01 https://www.youtube.com/watch?v=5kiOms2f4gg Oct 6, 2009 - Uploaded by West Marine How to Prepare Your Boat for Winter - Step 2 in the five step process on How to Winterize Your Boat: The ...
How to Winterize a Four Stroke Outboard Motor - YouTube
9k=? 2:44 https://www.youtube.com/watch?v=PRBnwYk8_Yk Nov 7, 2012 - Uploaded by boats.com Four stroke outboard motors are by far the most popular on the market. But there's a lot of confusion about ...
How to winterize your outboard
www.classicglastron.com/gl-outboard-winterizing.htm For smaller outboards, the simplest way to flush your outboard is by using a large ... water or purchase a set of "ear muffs" (available at your local marine dealer).
How to Winterize an Outboard Motor - Adventure
adventure.howstuffworks.com/outdoor.../how-to-maintain-a-boat4.htm ... the winter and prolong its. Learn how to properly winterize an outboard motor. ... Buy lubricant, oil, and fuel conditioner at a marine store. Time: about 2 hours.
Jan 09, 2016 | Boating
How do I winterized a 40hp evenrude 2stroke
There are videos all over YouTube that cover this subject quite nicely.
winterizing an outboard motor YouTube
Nov 15, 2014 | Boating
How to winterize an inboard/outboard boat motor
Flush the motor with fresh water, drain and refill drive gear with fresh oil , the same with the motor, remove spark plugs inject 10 ml of engine oil into each cylinder, turn engine over by hand so cylinder walls are coated, refit plugs. I then like to spray every thing WD 40. Remove the battery if you have a trickle charger connect it.
Oct 20, 2014 | Boating
I just got a new boat this summer and I live in Seattle, where I will use my boat year round. I have been told that I should winterize the motor so it doesn't freeze in the lower temperatures. What should...
I used to live in the Chicago area. We definitely had winter (below zero).I went thru extensive winterization for the inboards and stern drives. I fogged outboards and put Sta-bil in the gas. I also ran the gas out of the carbs or drained them but the boats would sit unused for 6 months. Does the boat stay in the water? If on a trailer, lower the motor so it is in the run (trim down) and the water will run out. If you tilt it up after this for storage, cover the gear case as it can fill with rain water and freeze.
Jul 24, 2014 | Light Outboard Motor Boat Bass Fishing...
How to remove tilt and trim motor
well you have to remove it from the boat first . then remove the side plates to get to the trim tilt unit .
Jul 10, 2014 | Boating
I had my lights and tilt working before realizing I had a kill switch at ignition. got my motor starting and running good now but now I have no tilt working or my lights. wondering are they a kill switch...
First check fuse box, look for one that is blown. also look for a loose or disconnected wire . It also may be that the lights and tilt are on the same circuit . if it is a blown fuse, replace it with the correct same fuse. Also check that connections at the battery are tight.
Jan 05, 2018 | Boating
Boating Logo
1,371 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
