I have a windows installer prompt that keeps reappearing on the screen. i have windows xp sp2. how do i get rid of this.
    Scholar:
  • 152 Answers
You need to repair your operating system. Install your OS once again and choose repair.
Posted on Sep 02, 2008
I can't install Windows Xp Sp2 For Compaq Presario Cq60 Model. a blue screen error occured after completing the files from cd to ram before entering lience agreement
You need to check your system ram or memory. If you have 2 system ram or memory unplug the other memory and install the windows xp sp2 again. If still having a blue screen try the other memory then run the setup again. Also if you have an extra hard disk drive you can test it that or plug your hard disk drive to the other laptop and run the windows xp sp2 using your hard drive. If you can install the windows xp sp2 on the other laptop that means your hard disk drive are good. If your memory and to the other laptop are compatible plug it and run the windows xp sp2 installer to see and to diagnose what are really causing problem. Have a nice day.
Apr 02, 2011 | Computers & Internet
Screen goes blank after booting with WinXP SP2 CD.
Hi, your will need to delete your windows XP re format that part of your hard drive, then re install XP
Jul 04, 2010 | Microsoft Windows XP Professional SP2
How to installation windows xp in hindi lenguage with picture
  1. Step 1 Open Windows Update (located in the Windows XP Control Panel), and see if SP2 is on the list of available updates. If you don't have Windows Update installed or turned on, visit the Windows Update website in order to get the latest Windows Update software.
  2. Step 2 Select the Windows XP SP2 item from the list of available updates, and click the "Install" button. Windows Update will begin downloading Service Pack 2 (a process that may take up to 20 minutes or longer, depending on how fast your Internet connectionmag-glass_10x10.gif is), and will then launch the installation program once downloading is complete.
  3. Step 3 Follow the on-screen prompts to complete the Windows XP Service Pack 2 installation. You will be asked to accept the terms of the licensing agreement before the actual installation takes place. Installation may take up to 20 or 30 minutes, after which you will be required to reboot your computer in order for the changes to the operating system to take effect.
  4. Step 4 Should you have problems installing XP Service Pack 2 through Windows Update, download the stand-alone executable from Microsoft in order to install the software update manually. The Service Pack executable is designed to make it easier for IT professionals to update multiple computers without having to download the Service Pack onto each one. Run the installer program once you've finished downloading it, and follow the on-screen instructions as mentioned above.
May 30, 2010 | Microsoft Windows XP Professional SP2
MICROSOFT WINDOWS XP PROFESSIONAL BLUE SCREEN
Only ever trust Microsoft updates. You could try doing a system restore to a point before this happened if that doesnt work i would boot PC from XP Home CD and choose the repair install option. You wont lose any programs or documents by doing this but no updates will be installed which in yourposition is a good thing. If all above fails its down to a format and complete reinstall. If you have anything i would backup before doing anything just incase. Good luck from Scott
Mar 15, 2010 | Microsoft Windows XP Professional With...
Cyclic boot and reboot after installing SP2
If you have the Windows XP recovery disk you should boot into the disk and do a repair install of the Windows OS. You can also press 'F8' before or right after the Windows XP splash screen comes up and tell it to either boot into Safe Mode or "Boot with last configuration that worked". If you boot into safe mode, go to control panel and programs and uninstall the sp2 installation. Please comment back if you need further assistance. I will be providing a How-To on how to recover a system using system CDs today.
Good Luck,
NOLA Tech
Jan 27, 2010 | Computers & Internet
UNABLE TO INSTALL SP2 ON XP OP.SYSTEM
Try the following steps to install the update successfully.
Stop the services pertaining to Windows Update.
1. Click Start, click All Programs, click Accessories, right-click Command Prompt, and select Run as Administrator.
2. If you receive a notification from User Account Control simply click Continue.
3. At the command prompt, type the following commands and then press ENTER after each command.
net stop wuauserv
net stop bits
net stop cryptsvc
4. Please do not close the Command Prompt window.
Rename folders pertaining to Windows Update
At the command prompt, type the following commands and then press Enter after each command:
ren %systemroot%\System32\Catroot2 Catroot2.old
ren %systemroot%\SoftwareDistribution SoftwareDistribution.old
Start services pertaining to Windows Update.
net start wuauserv
net start bits
net start cryptsvc
Close the Command Prompt window.
Regards,
Om
Oct 01, 2009 | Microsoft Windows Xp Home Edition Sp2...
Re-installed XP Pro + SP2 + SP3 - but have black screen
reinstall xp and dont install sp2 go to microsoft update and let it install sp3 for you
Sep 23, 2009 | Dell Latitude D600 Notebook
W200 cause a blue screen
First of all: If you install SP2 you don't have to install SP1 over it. It already did. Secondly, don't install SP3, it destroys Windows XP.
Try reinsalling the PC with SP2, install the drivers and do nothing else, see if that helps.
If not, by all means post back here,
Yannick.
Jun 16, 2009 | HP WLAN MultiPort W200 802.11b Wireless...
Window Xp Pro Setup Hangs at Logo Screen after reboot
You can try also to do reformat your hard drive as fresh unallocated one before doing formatting again to install windows. And check your installation disk for scratches.
May 07, 2009 | Microsoft MS Windows XP Professional SP2
Recovery CD-Image Error: Installing windows xp Home SP2
hope your 4 cd is error....plz ask your near vender or microsoft.com about to your sp 2 .
Mar 18, 2008 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
