Question about Canon FAX-L800 Plain Paper Laser
Is there a fuse inside the L800
My fax L800 seems to be dead although the phone keeps ringing there is no activity from the machine nor are there any lights or display showing. Have change fuse on the plug but no luck.
Is there a fuse inside the machine?
    Genius:
  • 2,120 Answers
You probably have a dead low voltage power supply.
There might be a fuse on it, but a blown fuse usually indicates a bad power supply.
Posted on Sep 05, 2008
Canon mf4150 -- fax has a mind of its own?
Hi ...
The problem is with receive mode settings ... Following the below instructions and you can change the receive mode settings which will resolve the problem.
Setting the Receive Mode
  1. Press <Additional Functions>.
  2. Use <la.gif> or <ra.gif> to select [5 FAX SETTINGS], then press <OK>.
  3. Use <la.gif> or <ra.gif> to select [3 RX SETTINGS], then press <OK>.
  4. Use <la.gif> or <ra.gif> to select [3 RX MODE], then press <OK>.
  5. Use <la.gif> or <ra.gif> to select the desired receive mode, then press <OK>.
    round_note.gif - For [AnsMode], make sure an answering machine is connected to the machine. If [AnsMode], [FAX/TEL], or [DRPD] is selected, you can select some settings as below:
    [AnsMode]
    --- [AnsMode CHK TIME] (select time from 10 to 30 seconds for the answering machine to start playing outgoing message after receiving a call)
    --- [FAX DETECT TIME] (select the duration from 10 to 70 seconds for the fax to detect)
    [FAX/TEL]
    --- [RING START TIME] (select the time from 0 to 30 seconds for the phone to start ringing after receiving a call)
    --- [F/T RING TIME] (select the duration of ringing from 10 to 45 seconds)
    --- [F/T SWITCH ACTION] (select the action the machine will take after the ringing ends, Receive or Disconnect)
    [DRPD]
    --- [NORMAL RING]
    --- [DOUBLE RING]
    --- [SHORT-SHORT-LONG]
    --- [SHORT-LONG-SHORT]
    --- [OTHER RING TYPE]
  6. Press <Stop/Reset> to return to the standby display.
Jul 17, 2009 | Canon imageCLASS® MF4150 All-In-One Laser...
Have a Canon FAX-L800 that we want to use on a Telstra Duet line, is this possible? Can't see any mention in the manual.
I'm not sure what you mean but if you are referring to a dual line then no. You cannot have two lines coming into the L800.
Jul 04, 2009 | Canon FAX-L800 Plain Paper Laser
How to accept a fax document
eigher program it to accept afax in the functions menu or push start when it rings
Jun 06, 2009 | Canon FAX-L800 Plain Paper Laser
Canon Fax L800 dead?
there are fuses on the power supply board
Sep 02, 2008 | Canon FAX-L800 Plain Paper Laser
Cannot receive faxes, but can send
I can send faxes from my HP Fax 1010, but cannot receive them. I can dial the number from another phone but it will keep ringing and the machine never picks up. We have tested the phone line and all seems well. Is there some setting on the fax machine itself that I need to change in order to receive? Any assistance you can provide would be greatly appreciated.
Aug 25, 2008 | HP 1010 Plain Paper Inkjet Fax
Setting personalized ring
Its called distintive Ring. This is the instructions from the manual -
VERY IMPORTANT
If you have Voice Mail or a TAD (Telephone Answering Device) and want to keep
one of your phone numbers dedicated only to fax calls, you must leave the fax machine
in MANUAL mode at all times while using the distinctive ring feature. Here’s why:
Manual mode will never pick up a call by itself, since it is «Neutral ». When the fax
machine is in this « neutral » mode, the Distinctive Ring Feature can be activated. The
distinctive ring feature is actually an answering mode. So, do not activate FAX ONLY
mode or FAX /TEL mode while using distinctive ring; otherwise, the fax machine will
answer calls for all the numbers.
Registering the Distinctive Ring Pattern
Set the fax machine to MANUAL mode.
2 Press Menu/Set, 0, 1.
3 Press to select DISTINCTIVE:SET?, and then press Menu/Set.
4 Press to select the prestored ring pattern you want to assign, and then press
Menu/Set. (You will hear each pattern as you scroll through the four patterns.)
Be sure to choose the pattern assigned by the Telephone Company.
5 Press Stop/Exit.
and a link to the manual if you need it -
http://static.tigerdirect.com/pdf/brother-IntelliFax-775-Manual.pdf
Feb 21, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Canon L800 FAX
ENTER SERVICE MODE AND SET SERVICE SOFT SWITCH 25 , BIT 0 TO 1
Dec 05, 2007 | Canon FAX-L800 Plain Paper Laser
Won't stop ringing
on the left side panel near the top there should be a slide bar, his lets you increase/decrease ringing/beeps volume. it doesnt stand out as is only a small one and same colour as the rest of the machine Hope this helps Cops Pete@wedotoners.com
Oct 10, 2007 | Canon FAX-L800 Plain Paper Laser
How to set ringtone when receiving fax Canon Fax L800
RINGER IS SET TO SILENT MODE,PLEASE CHANGE IT HAPPY FAXING OMNIPRESENT
Sep 19, 2007 | Canon FAX-L800 Plain Paper Laser
Fax ring tone or ring leader
im sorry to say the machine you have does not have DRD distinctive ring detect.
Jan 21, 2007 | Panasonic Workio DP-2330 Printer
Canon FAX-L800 Plain Paper Laser Logo
88 people viewed this question
old marine
old marine
