Can anyone tell me what the "function" button does? So far, it activates nothing. I am assuming that it works if hooked to computer via serial/parallel cable. (I do not have the cable or manual) Am I correct? Also, how does one move the pointer that is in the top window? How does this camera do in regard to battery usage?
The main thing I have found the function button to be used for is to be able to set the exposure compensation. Most of the rest of the controls are done with the ESC and SEL buttons.
If after you look at the links for the manual you have more questions just post them here at the forum. I am sure myself or someone else will be able to help you. The 750Z is great camera... enjoy.
By the way get yourself some NiMH batteries. Don't waste your money on feeding Alkaline to this or any other digital camera. Alkaline are for emergencies only.
I dunno where my manual is, but the only time I use that button is when reviewing pictures in camera. If I want to delete the image currently displayed, I press "function" and "esc" instead of having to navigate all the menus. As for pointer in top window, can you clarify? Do you mean along the left edge of the LCD display? The arrow there shows up when you activate certain features of the camera. Manual white balance mode will bring up "WB" indicator, higher sensitivity the "ISO H", continuous rapid sequence shot mode the "Cnt" indicator. As far as battery usage goes, this camera can be a hog. If you run it with LCD and backlight all the time, you'll run out of battery in no time. I haven't timed it, but maybe two hours. However, if you make judicious use of power, it's lasted me a day of travel snapshots. Always carry a spare set of batteries though. Nice thing is if you run out, easy to find emergency spares at a store. I've been more or less satisfied with this camera. Image quality is good, low light sensitivity pretty good, size not smallest, but manageable, ok zoom. Pretty good all around camera, although current cameras of same new price range are now much better. I've been having some problems with the switch, and don't remove the memory card with the power still on!
the flash wont pop up any more??? im trying to find a service manual ( for free of course) so i can...
(More)
the flash wont pop up any more??? im trying to find a service manual ( for free of course) so i can pull it apart to see whats wrong finepix s5700
Epson 750Z won't take pictures with new 2gb Sandisk ultra II compact flash card. When I press the...
(More)
Epson 750Z won't take pictures with new 2gb Sandisk ultra II compact flash card. When I press the button to take a picture, the green light turns to orange for a long time. With the Ultra card in the camera, the lens takes a long time to return to the Off position after turning off the camera. It will still take pictures using a Lexmar 32mb card.
i used this cam after long that was not in use i misplaced the charge battery so i used regular one...
(More)
i used this cam after long that was not in use i misplaced the charge battery so i used regular one last night i used it at night the battery signel show then it stoped i replace bettery the cap dose not turn on i looked at all the solution that were posted but non is to answer my problem thanks
Talula
