Question about Hummingbird Humminbird 1155C GPS Receiver
Hummingbird gps ns25
Gps will not turn on
  • 76 Answers
Hi!
here's a user manual/installation manual for your sounder:
NS25
If the depth sounder portion works, I would suspect the settings are off (check first) or the gps circuit needs repair.
Best of luck!
Mike
Posted on Sep 26, 2009
Gps ns25
Please check the mount and the wiring throughly as its a loose contact issue nothing else.
Aug 07, 2008 | Humminbird NS25 GPS Receiver
Is the transducer for a hummingbird 386ci the same as for the 688 ci?
Hi Cliff
I believe your best bet here would be to contact Hummingbird directly. There's the contact page. Hope this helps you out.
-Steve
Contact Us
Nov 10, 2014 | Hummingbird GPS
Plugged humminbird ns25 gps antennae to my 898cxi humminbird but no gps signal
The NS25 uses a much different god receiver than what is available now and will not work with your 898. What you will require is a AS GRP receiver. https://www.humminbird.com/Products/AS-GRP/
Source: mikesreelrepair.com & Humminbird.com
Jan 11, 2014 | Humminbird NS25 GPS Receiver
In the start up mode as not connected can any body help
What happened since then. Have you solved it somehow? I have the same problem..
Apr 02, 2012 | Humminbird NS25 GPS Receiver
I have a hummingbird matrix 67 gps chartplotter fish finder. It developed a problem with the screen. The outer edges are legible, but the center is damaged. Is it worth repairing. Are there any other...
Hummingbird will refurbish that one for around 150US dollars, better then 500+ for a new one. If the screen is subjected to direct sunlight and heats up it can go out. This is why they discontinued the 67 model and replaced it with the 767.
Apr 21, 2009 | Humminbird MATRIX 67 GPS Receiver
Older HUMMINGBIRD DEPTH SOUNDER LCR-3D . WAS WORKING FINE WHEN I PUT IT AWAY, NOW WONT POWER UP. HAVE CHECKED THE INPUT POWER AND IT IS OKAY. I DO NOT SEE A FUSE IN THE UNIT. ITEM IS OLDER UNIT BUT IS...
We have an old Hummingbird Depth Sounder (Wide 100, 94 model) and it turns on but must be on test mode or smething cause we can not get it off. Does anyone know or have a manual to solve this problem. Please help.
Aug 07, 2008 | Hummingbird GPS
Gps ns25
The wiring within the Screen unit seems to be very poorly done, there are 4 cables to the GPS side of things and these can contact each other as there is a portion of the wire where it enters the connector that is bare, and if these touch one another then you will get nothing.
Dismantle the head unit and check the cables, i would be inclined to shrink wrap the bare portion of each cable.
Hope that this helps, it might not be the answer, but it is worth checking.
adrian.
Humminbird NS25 GPS
This is a common problem on lots of boats with any brand of electronics. Most likely it is being caused by a bad crimp in a wire connector, or by having too many connectors on a terminal in the power supply bus. Start at the power supply source and ground and replace any butt or terminal connectors with high quality heat shrink connectors (such as Ancor). Make sure that the connector is the right size for the wire.
On Humminbirds the problem could also be in the swivel mount that holds the power and data cables. The cables should be held in place by a metal bracket which is located under a panel held onto the swivel bracket by to small philips head screws. If any of those components are missing, the plug may be loose in the socket which could cause it to disconnect temporarily when the boat hits a wave. While you have it apart check the plug and the socket for corrosion.
I hope this helps. Please contact me if you have any more questions.
Feb 10, 2008 | Humminbird NS25 GPS Receiver
Hummingbird Humminbird 1155C GPS Receiver Logo
188 people viewed this question
Top Hummingbird GPS Experts
Mike Marcotte
Mike Marcotte
Steve
Steve
Are you a Hummingbird GPS Expert? Answer questions, earn points and help others
