Question about Kenmore Washing Machines
Leaking Washing machine
My Kenmore 90 Series washing machine leaks during operation. Not sure which cycle but it leaks. Should I call a repairman or is there and easy fix?
  • 5,911 Answers
I would recommend you inspect the washer with the exterior cover removed, so you can actually see where the leak may be coming from. The following link explains how to replace a drain pump on a Kenmore. I submit this to you, because it not only explains how to remove the exterior case of the washer, but in the event that the pump is leaking, it gives you the necessary steps required to install a new one. The pumps are sealed units and not servicebale. If they leak, they need to be replaced:
http://www.fixya.com/support/r397094-replacing_water_pump
When you remove the exterior case, the washer will not operate without the lid switch by-passed. You will need to do this in order to fill the wash tub to see where the leak may be coming from. To by-pass the switch, you will need to unplug the washer and jumper the two black wires together at the lid switch connector on the timer. Use aligator clips on the connector pins to do this. With the lid switch by-passed, you can plug the washer back in and start a cycle.
Look for signs of leaking around the drain pump (located in the front under the wash tub) and all hoses. Also inspect the entire perimeter of the wash tub for any possible leaks. Generally, if you have a leak in the front of the washer, its a drain pump or drain hose connection. If you have a leak under the tub you may have a worn tub seal or cracked tub.
I hope you find this information helpful. Hopefully, you will not need any repair parts. If you have any questions, please let me know.
PS Use caution when operating the washer with the case removed. There are exposed electrical components and moving parts.
Posted on Sep 02, 2008
Kenmore 80 didn't drain during the spin cycle and leak underneath machine. Makes buzzing noise in the wash cycles.
The pump is likely damaged if it was leaking. Look for a ring of melted plastic on the face side of the pump. Check to make sure the hole is not rounded where the motor shaft enters the pump.
I'd replace the pump just to make sure the washer doesn't flood some time in the future even if the pump turn out to be ok now.
Vlad,
First Choice Appliance Service. Sacramento, CA
Jul 05, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My Kenmore 70 Series is leaking out of the front
Good day,
It sounds very much like the pump, which is located front center behind the cabinet.
I'm going to add a link. It isn't about the pump, but it shows you how to access that area.
Be aware that the screws that hold the top console may be different than shown.
They may be exposed on the front ends, covered by plastic covers which have to be unclipped, or as shown.
http://www.youtube.com/watch?v=WLPGs2UMUJc&eurl=http%3A%2F%2Fappliancejunk.com%2Fforums%2Findex.php%3Ftopic%3D67.0&feature=player_embedded#t=15
Thank you for using FixYa
Jan 15, 2010 | Kenmore Washing Machines
We have a Kenmore 90 Series Washing machine. We
You have a leaking dishcharge pump. Not too hard to replace.
Nov 08, 2009 | Washing Machines
Kenmore series 70 tip loader washer is leaking
your just seeing the water that is leaking dureing the wash cycle unplug washer there will be 2 screws on the header panel 1 on each side take them outgently pull header panel to you then flipupunplug wiring harness thas to the cabnet there will be 2 clips 1 on each sideuse a flat screwdrive and pry back they will come out tip cabnet back to you the whole thig will come off look at the pump in the front it has a weep hole in it see if it has been leaking from there
Jun 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Hi MPT,
Don't take the back panel off!!!
Watch this video to learn how to access the machine.
Generally on a Whirlpool built Kenmore like yours, the drain pump has failed and now it's leaking. The pump is right there in front, the big round white thing. It's connected to the motor by 2 clips. It'll be one of two types of pump... this one or this one <----notice the difference in hose connections?
It's easy to replace, just make sure that the machine is completely empty when you remove the hose or have a shop-vac handy when you do.
And don't forget to rate my solution as "FixYa", deal?
SG
Apr 17, 2009 | Kenmore Washing Machines
THE LEAK IS UNDER WASHING MACHINE,THE BOTTOM, IN THE FRONT ABOVE THIS MOTOR THING.
Leaking water pump, replace pump.(The cabinet has to come off to do this,if you are not comfortable doing this call a repairman).Price will be probably about 90. total
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Sears 90 Series Washing Machined throws ground fault during spin.
pvatki, I am a licensed electrician and the NEC (national electrical code) does not require a clothes washer to be on a ground fault circuit interrupter. Replacing your gfci with a standard duplex receptacle will fix the problem you are having.
Dec 29, 2008 | Kenmore 15864/15862 Top Load Washer
Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Mar 09, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
145 people viewed this question
Fordexpert
Archaeology
Archaeology
reliableservice
