Question about Maytag Neptune MAH5500B Front Load Washer
Front load washer doesn't spin
The spin cycle on my front load Maytag washer stopped spinning. I had just finished a load and on the next load I smelled a faint burning smell and then the spin cycle stopped working. The washer is about 10 years old and has worked just fine up until now.
All of the other cycles work fine. Would appreciate any assistance.
  • 1 more comment
  • HJMTBI Sep 16, 2008
    I have the same problem, the rinse cycle works fine, water enters, the motor does it's back and forth motion the pump turns on and empties the washer and the washer continues with the back and forth motion instead of going into the spin.
    Jack
  • Anonymous Oct 08, 2008
    I love the solution #1 gives... check your plug... wow. Okay, Here is what i did. I had the same problem... I pulled off the front panel, then the front panel which houses the washer and dryer dials. When i let the panel hang free (ie from the wiring harnesses, it started to spin like it was supposed to. I therefore deduced that the harness which holds about ten different wires, and plugs into the back of the washer dial box, has a loose wire connection.... My dad always said, "cheapest to most expensive". I then checked the wires in the harness to ensure they were firmly secure in the plastic harness and cleaned each connection. From there, you can deduce whether you need a new washer dial switch...
  • Anonymous Mar 26, 2014
    washer cycles through correctly until it comes to the "spin" cycle. E 25 comes up on display and washer will not spin.
  • 750 Answers
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Posted on Oct 04, 2008
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
Maytag Neptune MAH-1 front load washer won't spin in some cycles I use often. it spins at the end of the cycle and in cycles I do not use often. it spins in the spin cycle when I run that cycle
sounds like the timer is not advancing is certain cycles? timers have contact points that can burn and seize up sticking close and not allowing the next cycle to move
Mar 16, 2015 | Maytag Washing Machines
Spin cycle does not engage
UPLOADING OR FRONT LOADING WASHER..........CHECK ITS BALANCE LEVELS.
Feb 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
Cylce stops after 1st drain before spin out
I have kenmore washer front load H2 after 1st circle of wash it stop and start beeping with code F11. My email address is anarfi1212@ live.com
Jan 21, 2010 | Kenmore HE2 Plus Front Load Washer
Maytag Front Load Washer - SD error
hi there,
it appears that you have a door switch problem. the door latches on these machines are equiped with a mechanical switch and if this switch disengages in any way, the machine thinks that the door is open, even if it's not.
the code that you see is actually a "dS", which stands for door switch.
check the door latch, which is where the door switch is located.
thanks.
Sep 26, 2008 | Maytag Neptune MAH6700A Front Load Washer
SPIN CYCLE
need more information is it top load or front
Nov 19, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
642 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
