Washing Machines Logo
Posted on Aug 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oven locked code f11 help - Washing Machines
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 86 Answers
  • Posted on Aug 03, 2011
Anonymous
Expert
Level 2:
Mentor:
Answers
86
Questions
0
Helped
21548
Points
253
If you are looking for oven help I would suggest you post your question in the fixya oven category and not here in the 'Problem with the Washing Machines' category as you did.
You may also find this tip helpful.
http://www.fixya.com/support/r9980085-receive_best_kitchen_range_repair_help
1helpful
F11 error code
I appreciate the post, dan moore!
From the information you have provided your Frigidaire range is displaying an "F11" error code. Typically, the "F11" error code stands for a shorted keypad. This could be a false error code and the best way to clear any false error codes is to disconnect power from the range for at least ten minutes. If you continue to get an "F11" error code you may need to replace your EOC (Electronic Oven Control), I would recommend having a professional technician come out to properly replace any electrical component to avoid personal injury. Hope this information is helpful to some degree. -Matt
HOW DO I GET TOO THE TROUBLE SHOOTING PAGE FOR A OVEN
Hello friend, thank you for your post!
I understand that you need troubleshooting steps for an "F11" error code. "F11" stands for a shorted keypad and one step for troubleshooting is to reset your range. You can reset your range by flipping the household circuit breaker off for ten minutes. If that does not help correct the "F11" code I would recommend you reach out to a professional for proper diagnosis because it could an issue with your EOC (Electronic Oven Control) or wiring harness. I hope this is helpful. -Matt
How to fix frigidaire wall oven beeping error message f11
Good Morning Friend,
I understand that your Frigidaire wall oven is beeping and showing an F11 error code. Typically an F11 error code states that there is a shorted key, or a button has been detected as pressed for a long time. I suggest hard resetting your appliance, by cutting the power at your homes circuit breaker for 3-5 minutes. While you are resetting your oven, make sure to wipe down the control panel. The panel is very sensitive and could be detecting something that has splashed or spilled onto it, even dust. When you bring power back to your appliance you will need to start by setting the clock. Turn your oven on any cycle at any temperature. If you are still receiving an F11 error code, I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
7helpful
Kenmore gas range F11 error code
The "F11" fault code indicates a shorted button on the electronic oven control. This means the oven control board will likely need to be removed and replaced. You could disconnect power, wait 30 seconds and reapply power. If "F11" returns upon power-up, replace the electronic oven control board (EOC). but if i had your model number i could nail it right on the head with a fix...
4helpful
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
CODE F90
I have the same problem. my model number is Kenmore 970-556322. the whole stove is not working.
Oven door is not locked but got the message "door locked" on the control panel and won't allow reset via clear/off. and it shows F11 and F90 on the display, and the machine keep on beeping the whole day, tried to unplug and restart it next day, but didn't work.
Please help!
13helpful
3answers
Oven door locks and un locks code F90
The F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board.
It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
2helpful
2answers
Could you tell me what F11 code means?
F11 error code means there is a problem with the Control panel. Could be melted wiring, etc, since you left the oven standing. However, you can try unplugging the device from the power socket for about 5 minutes and reconnect. If the error goes away, then well and good; if not, you may have to replace the panel control.
Top Washing Machines Experts
john h
