Question about Konica Minolta DiMAGE Z3 Digital Camera
What precautions should be taken when using the camera in a cold enviroment?
    Master:
  • 425 Answers
In cold environments (winter outdoor, highlands), battery performance decreases extremely. We recommend keeping spare batteries in a warm place, such as the inside of a coat. (Batteries can recover their power when they warm up.) When taking the camera from a cold to a warm environment, place it in a sealed plastic bag to prevent condensation from forming. Allow the camera to come to room temperature before removing it from the bag.
Posted on Sep 13, 2005
What precaution should be taken while wearing eye lens?
Following precaution should be taken:
1. Shake your lens case containing the storage solution
2. Slide the lens out of its case and into the palm of your hand. Rinse thoroughly with the appropriate contact lens solution.
3. With the fingers and thumb of your other hand, simultaneously pull up on your upper eyelid and down on your lower eyelid.
4. Gently close your eye, roll your eyes in a complete circle to help the lens settle, and then blink.
I personally used a contact lens to look attractive in front of people. If you are also interested in wearing eye lens than I would suggest you Bright Eyes Contact. They provide the good quality prescription lens that helps you to look attractive. They also provide various offer time to time.
Jan 05, 2018 | Cameras
When a photo is taken the image is over lit and whited out. Help!
If your camera suffered a hard impact or was smooshed by something it needs repair. Otherwise, here are a couple of suggestions before that;
- reset all features and settings to default settings. Your manual should guide you to do this.
Test camera with dark and light enviroments, as well as with and without flash.
If the problem still remains, try a reliable camera repair company. Teleplan Camera Repair will give you an immediate online quote and they also clean your camera as part of the repair.
Jul 22, 2010 | Canon PowerShot A450 Digital Camera
My printer says it needs to get to room temp but has been saying this for 24hrs
I am not sure what enviroment you are in.
If you are in a cold building, yes this could be true.
Some machines have what they call a "Q", or a comptometer type of electical component built right in the cirucit board. This is a temperture type of componet that works in a certain range of enviroment tempertures. If the area is too cold, it will open up this computent and the machine will not work.
Garages, storage buildings, wearhouses are examples of these places where extreem cold conditions can occur.
If this is not the case in some machines, other causes may need to be explored.
A failed main board, software corruption-software may need to be reloaded by a technition and machine values be added correctly.
Oct 01, 2009 | Brother Office Equipment & Supplies
I have a Digital JVC Camcorder with mini DV with failure code...
That come on because of a humid condition or moisture on the head drum of the camcorder. This is usually cause by going fro a hot enviroment to a cold enviroment. This prevents tape damage or destruction as the tape will stick to the head as it spins. You can open the cassette compartment and use a hair dryer on a low setting for a couple of minutes to get rid of the moisture or just leav the cassette door open for about an hour or until the warning clears.
Aug 19, 2009 | JVC GR-D50 Mini DV Digital Camcorder
The phone automaticly scrolls through volume, calls,contact list,makes calls randomly activates camera and I am unable to hear callers ..when i try to turn it off it starts to shut down then powers back up...
has your phone been left in extreme heat, or been in an a/c enviroment and taken out in heat.
if left in heat it will damage it
if taken from cold to hot it could have moisture inside
remove battery and leave open in a/c
Jun 28, 2009 | Samsung SPH-m520 Cell Phone
My ac stops blowing cold when i move from a stop
It is a door or flap that is closing, in fact it is the blend door located inside the environmental station, remove the lower console cover, small black cover at the center bottom of dash touches the floor, look for a white square box with an electrical connector, take out the 3 screws that hold the white box (stepping motor) in, use an inspection mirror and look at the door drive end (part that the stepping motor inserts into) this is the blend door drive, it is probably broken, the door is availiable at most Ford dealers for around 55 dollars, tp replace it, you will have to remove the whole dash complete with the instrument cluster, radio, enviro controls, etc. then you can remove the top of the enviro station, and replace the door, hope this helps, let me know....I just had to do mine.
Jun 05, 2009 | 1999 Ford F150 Regular Cab
Loading to youtube with enviro camera
You tube accepts wide video file formats such as .wmv, .avi, .mov, .mpg transferred from most digital cameras. The problem you have, the video you upload might not from those video formats. So youtube may not recognize or upload it. What you really need is to convert your video to a format which can be uploaded to youtube like MPEG4 (recommended). Alive MP4 Converter program allows you to convert AVI files or whatever formats to MPEG4 which can be uploaded to youtube. Else, use another updated web browser to open youtube and upload it there.
Jan 04, 2009 | YouTube Videos
D50 (CHR) problem, I think temperature related.
Hello the same problem...
what is it in final? Card problem?
Jan 02, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Casio EX-S600
Try out your "Best Shot" modes and see if you have a high sensitivity mode on that model. It works great for low lit areas. Other than that there isn't any kind of "auto light" that I know of on that model.
Jul 12, 2007 | Casio Exilim Card EX-S600 Digital Camera
Digital camera care
Use these camera care tips: • Store everything together in a case for easy transport. Use a good padded case and strap. Not only do cases protect the camera but, as with most of HP's digital camera cases, they often have built-in pockets for batteries and memory cards. • Use lens caps to protect lenses when you're not using your camera. No exceptions. • Clean your camera and lenses often with a soft cloth. The autofocus, exposure, and viewfinder windows need to be clean for correct operation. Your camera likes weather that’s not too hot and not too cold. Weatherproof your camera with these ideas: • Let your camera case kick back under a light-colored towel when you're under the hot sun. • Keep your camera warm under your coat when it's chilly outside. • Bad weather and stormy seas can make for inspiring photographs. But if you don't take precautions, you'll have a wet digital camera with sand in every crevice. To protect your camera from water, cover it with a plastic bag. Just make a hole for the lens to poke through and secure it with a rubber band. Voil?: a little rain jacket!
Sep 08, 2005 | HP Photosmart 945 Digital Camera
Konica Minolta DiMAGE Z3 Digital Camera Logo
Top Konica Minolta Cameras Experts
Computer Links
Steven Wander
Steven Wander
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
