Hi
Dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
Hi
Daniel
Hi
Daniel
Hi
Daniel
