Question about Maytag Atlantis MDE7400AY Electric Dryer
Belt replacement for a Maytag dryer - Model No. DE410
I need detailed instructions on replacing the drive belt for a Maytag dryer; model No.DE410.
  • 639 Answers
Peace Friend,
ngfam1 At your service!
There are many variables!
Every year thousands of people die trying to repair electrical appliances them selves!
You are worth more than that!
Bless you!
Only a trained laundry tech can make the electronic diagnoses.
Below I referred you to a great service nation wide!
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505 near me they only charge $75 service call which is reasonable in today s market!
Unfortunely, another point to consider!!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
*****PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF*****
Posted on Sep 02, 2008
Belt installation is too loose on Maytag dryer model # pye2300ayw? Trying to fix it need a diagram??
Hi and welcome to FixYa, I am Kelly.
If the belt is loose it is most likely stretched / worn and should be replaced:
The idler (item5) of this drawing:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46651&diagram_id=630165#d630165
See routing here: http://www.repair-help.com/kb/index.php?article=105
The drive belt is item 5 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46651&diagram_id=695560#d695560
The top must be opened and the front panel removed to install the belt.
Here is a link to step by step "how to" instructions.
http://www.ehow.co.uk/how_7277908_do-belt-maytag-pye2300ayw-dryer_.html
Make sure to inspect the rear drum rollers while you have the dryer open. Item 7 this link:
Flat drum rollers or hard to turn rollers will cause the new belt to fail prematurely.
Additionally if the front or rear drum seals are worn it can cause the belt to be loose. These are glued on with high temp adhesive.
The front seal is item 10 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46651&diagram_id=28505910#d28505910
The rear seal is item 2 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46651&diagram_id=28505913#d28505913
High temp adhesive: http://www.appliancepartspros.com/part_details.aspx?part_id=4284239
By replacing the items above your dryer will operate like new again and extend the life of your dryer by many years.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Maytag Dryers
Maytag model no: de410 Looking for manual
I need the 6 digit model number from your dryer.
May 28, 2008 | Dryers
Changing a dryer belt on a Maytag DE410
in some models you do it from the front the drum sits on 2 bogie wheels and the belt sits behind ,lift drum off bogie wheels and thread belt around pulley it should be on a spring tensioner and it allows you to swing pulley up or down try to thread belt around drum and replace drum back on bogie wheels.... in some dryers you may need to thread belt on drum and then onto pulley good luck
Dec 18, 2009 | Dryers
CHanging Belt Maytag DE410 Dryer Q#2: Opening Top
Pop the top ... usually held down with spring clips
Be careful of the finish ...
Let me know what happens ...
Post a comment here for additional information/instruction
thanks for your interst in FixYa.com
Dec 11, 2009 | Computers & Internet
Belt change on a Maytag DE410
Most of the time these models have screws in the back of the machine on the top lid. You'll need to get over behind the dryer to access this panel. You'll need a "star" type screwdriver (most come in a set). Remove the top lid to expose the drum. The belt will run around the drum and down around the safety cut out switch. This switch is most likely a teflon or plastic wheel that the belt loops around. After installing the belt, replace all of the screws and you're good to go!
Dec 11, 2009 | Dryers
Dryer quit spinning.
If the blower is working, then it's most likely the belt, a belt pulley or a tensioner spring.
Open the dryer, it will power off, and then spin the drum by hand. If it moves with little resistance, it's your belt.
Dec 11, 2009 | Maytag Dryers
Belt broke on Maytag dryer DE410. I purchased a
The squeak may be coming from the drum rollers, check them to see if they need lubrication.
I recommend that you use a good grade of machine oil to lube them such as 3 in One oil. Lube them at the shaft of the roller. Also check the rollers to see if they have flat spots on them, if they do then they will need to be replaced.
Recheck your location of the idler arm bracket with pulley to see that you have it in the right location and that the spring is also in the right location. Look for wear spots on the frame and idler arm and match them up.
Good Luck,
I hope this helps
Oct 12, 2009 | Maytag Dryers
I need detailed instructions on how to replace heating element of a Maytag DE410 electric dryer including diagrams...Dryer does not heat...
Very simple. Remove screws at the base and the front panel. The heater is on the bottom easily accessed. The re-string kit is way cheaper than the "mailbox" Start here:
Mar 04, 2009 | Dryers
Model DE590 dryer needs drum belt replaced. I need instructions on how to do it.
Your complaint is: "model DE590 dryer needs drum belt replaced. I need instructions on how to do it."
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site. You may need to enter your model number; DE590 to gain access to your information.
This link shows the belt and cost.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1246110&PPStack=1
This link shows the belt routing, use diagram E
http://www.repairclinic.com/0079.asp#DiagramE
This link shows disassembly, exploded view directions. http://www.repairclinic.com/0100_18.asp
All service is performed from the front except for the installing the belt back onto the idler pulley. That procedure is done through an 8" removable panel in the rear at the bottom.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 13, 2008 | Maytag Dryers
Replacing dryer belt on Maytag
i would take off the cover, it might be reg or star type screws and look at this page
http://www.partselect.com/ModelFrames.aspx?ModelID=64957&ModelNum=DG410&mfgModelNum=&ManufactureID=1&Selected=36056&Position=6&mfg=Maytag&Type=&Mark=6
Jul 10, 2008 | Dryers
Maytag Atlantis MDE7400AY Electric Dryer Logo
602 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
