Question about Samsung SyncMaster 753S 17" CRT Monitor
Monitor problem when i see the one samsung 951mg 17" color monitor . when power on the monitor, the display is coming but syncing the monitor . what is the solution? pls reply to me.
    Problem Solver:
  • 18 Answers
Try running your OS on safe mode then reconfigure your monitor on the display settings and adjust the screen resolution to sync your monitor with your video card.
Posted on Oct 02, 2008
Display not working but system functioning
tried with other monitor just to ensure if the problem is only with in the monitor. if the same problem, the cause it could be the inverter board for screen back light which has component being shorted.
Aug 15, 2012 | Samsung SyncMaster 713N 17" LCD Monitor
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
Samsung sync master 740N no display. Flickered started then the display goes after its been on for a short wile. Could this be a problem with the capacitors?
Yes, look for two 1000uf capacitors on the power supply PCB near the output cable to the main PCB. They will have swelling and discolouration. Replace those and should fix your problem.
Oct 06, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Why my display show plug and play monitor instead SyncMaster 732nw?
U NEEDS TO INSTALL MONITOR CD COMES ALONG WITH MONITOR. THEN IT SHOWS SYNC MASTER. AND THE COLOR SETTINGS WILL BE ALIGNED AUTOMATICALLY.
Apr 17, 2010 | Samsung SyncMaster 713BM 17" LCD Monitor
Hello My PC monitor/CRT 17 inch. not getting
check the signal cable bend it in on condition and look what difference in color occurs if so then replace the cable if not that fault then ther is a dry solder on the base of monitor find out and clear it
Apr 05, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
Hi, I am having Samsung LCD sync master 943nwx, after power on momentarily display is coming and going,
it may simply be a lose connection with the monitor cord. or the monitor cord may to be replaced.
Jul 12, 2009 | Samsung 15.3" LCD Monitor
Monitor problem
Appreciate the "Ask Me".
I am assuming that you have more than just familiarity with electronic components and circuitry, the use of a DVM and a soldering iron. Further, that you have access to a service manual.
Width problem is basically insufficient horizontal deflection, then analysis would have to be in the horizontal section. Areas to initially focus on:
  1. 12V line and pin 29 of IC401;
  2. 110 V peak to peak at collector of Q403, if yes check Q 402 & 404 as well as T401;
  3. other components that affect the horizontal size are:
  • IC201
  • Q 405, 406, 407 & 408;
  • D409
  • L401
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 06, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor shutoff
Hi, do you mean, when you power on the lcd monitor, then the display come for a while, then no display? May i know the power led light is still on or what's the led color lit? If the color of led still maintain the GREEN light, then you may have a inverter or lamp problem. If this is the problem you need to repair or change the inverter board or ccfl lamp. For more details, you can go to this site http://www.fastrepairguide.com to get some repair idea.
Aug 25, 2007 | Samsung SyncMaster 760 VTFT (White) 17 in....
Blinking power button
It could also be because there is a problem with the display controller in the computer. Try to hook up another monitor to this computer and see if it comes up. If it does not work with another monitor, the computer will need servicing. If the display does come up, the Samsung monitor will need service. Good Luck
Jun 20, 2007 | Samsung SyncMaster 170 T 17 in. Flat Panel...
Samsung SyncMaster 753S 17" CRT Monitor Logo
94 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
