Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Trouble connecting wireless
Hi there, i have a Belkin G+ router that is hooked up to my desk top and works fine via a Ethernet cable, but my dell laptop can see my connection when i activate the wireless but i am unable to connect to it or the web can anyone help.
Hino
  • smoorc Sep 02, 2008
    Just to add to my ISP is unwired, and i have tried to connect to the modem with security enables or disabled.
    President:
  • 2,961 Answers
First thing to do is to dissable the ethernet connection in network connections on your notebook so as the ip address does not conflict.
assuming it's XP and assuming DHCP is enabled in the router settings, right click on your wireless conection in network connections, properties>TCP/IP line, highlight it and then click properties again, then ensure obtain an ip address automatically is ticked, apply and ok, close window.
If neccasary run the wireless network wizard in new connections in network connections.
Open internet explorer>tools>internet options>connections tab and ensure that 'never dial a connection' is ticked, ok and close IE.
Open IE and click refresh a few times.
Posted on Sep 03, 2008
My Dell desktop using Windows XP can't connect to my Belkin 5720 router but my laptop still works?
This sounds like a hardware failure, but just in case go to your computer Control Panel-Network Connections(Network and Sharing Center for Vista and above), and check your Network adapter settings. If your Network card is not showing, you may have a driver issue, or a bad NIC (Network Interface Card). It shouldn't matter that your router says" wireless hardware not detected", because you are hardwired from the computer to the router. I would check to see if you may have turned off, or blocked Ethernet connections on your router, I would then change my Cat5 (Ethernet) cable, and finally open the desktop and change out the NIC (Network Interface Card).
Mar 24, 2012 | Belkin Computers & Internet
My internet is greatly reduced with Belkin N1 vision wireless (before the hook-up it was 15mbps now only 5mbps), I have tested by hooking directly from the modem to the computer and got 15mbps. Before N1,...
When you only get 5 mbps are you connecting to the new router wirelessly or via the ethernet cable? If it is wirelessly then try connecting with an ethernet cable and see if you still get 5 mbps. If so then try resetting the router (the procedures for this will be explained in the manual) and re-test. Wireless connections can slow down due to obstacles such as thick walls or other obstacles of that type. If all else fails return the unit and try another.
Mar 08, 2011 | Belkin N1 Vision Wireless Router
I have a wireless network. the desk top s connected via an ethernet cable. When he desk top computer in another room is connected wirelessly, I cannot connect wirelessly with my laptop or vice versa. ...
Since already you have a computer which is working fine using a wired connection , please click here to reset the wireless settings of your router and to connect to your all other wireless computer.
Thanks in advance!
With regards,
Prema.
Jan 06, 2011 | Buffalo Technology WHR-G54S Wireless...
Belkin router
Hi Friend,
When you are tring to connect in wireless it will ask for password,please follow the below steps and get the security key of your Router
Step 1:Connect the Modem to Router (in the Port named Modem) and take another ethernet cable abd connect one end to the Router(in the port named Wired) and other end to any one of your computer
Step 2:Open an internet explorer and type 192.168.2.1 and click on Enter button in the keyboard
Step 3:Now you will be able to see the belkin router setup page
Step 4:On your left hand side click on Security,it will prompt for a login password,leave it blank and click on Submit.
Step 5: In this page you will be able to see the security key or PassPharse,please make a note of it and type the same when its asking for security key
Regards,
Aysaam
Jun 07, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Desk top/ethernet to linksys router not recognizing.
First connect that desktop to linksys with ethernet cable.
then set ip property to network adapter .
Set ip address ,subnet mask and gateway ip to ip property.
Set ip address as the ip of network like if router ip is 192.168.1.1 so set ip like 192.168.1.15
set subnet mask as same as your other computer.
Set default gatway ip as your router ip.
Then you can connect internet.
Let me know if you need more assistance.
Thanks.
Nov 06, 2009 | Linksys Wireless-G WRT54G Router
Set up
No. You do not need to have a computer connected via a CAT5 (Ethernet) cable to the router for a laptop to access the wireless signal.
However, to set up the router to broadcast that wireless signal or to alter some of the wireless security settings you will have to connect directly to the router with a CAT5 (Ethernet) cable.
If you need assistance connecting to that wireless connection, let me know. I have some instructions which can help retrieve the security information from the router so you can connect to the Internet via the wireless signal.
Mar 20, 2009 | Belkin (F5D7230-4) Router (587009)
Wireless connection set up
Are you trying to hook up the laptop wirelessly to the pc? because then the pc would need to have a wireless card as well....sounds like I need more info, but if you are trying to do what I think you are, you should just get a wireless router instead, hook the pc tower directly to it via ethernet cable, and then setup the laptop to connect to the router. The router would hook to your dsl or cable router....what service do you have?
Mar 10, 2009 | Dell Dimension 3100 PC Desktop
Connecting a cpi to the internet ?
1) You can use a PCMCIA card (for example a Dell Fast Ethernet 10/100 Base-TX by 3Com) with a 'dongle' to connect to the ethernet cable via an existing card slot on the left side.
2) You can get a docking station set-up (i.e. Latitude 'C/Dock') which comes with the ethernet cable connection. ...pretty affordable used on the 'net.
3) If you has a wireless router you could hook a wireless USB adapter tp connect wireless to yout router.
jmjrfeller
Dec 28, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
I am trying to hook up a belkin router to a desk top, gateway. with no success been on the phone with belkin for 4 hours, unsuccessful
i hope your not talking about the wireless router.....
unplug your computer from the modem, and link the modem's Ethernet port to your router's WAN port (this is important). Once you have that in place (and you may see a WAN status light come on), plug your computer into one of the other Ethernet ports using another Ethernet cable and see if you can get a connection........
Mar 12, 2008 | Computers & Internet
Wireless connection problem
Hello:
Ok...I am a bit confused. You must have a modem to connect to the internet...whether you are broadband (cable/DSL/wireless), Dial-up or T-1 or higher (TSU/DSU).
This is how it should run once you are sure you have the modem...
Modem....to router...pc to router. If you have no router...then plug ethernet cable from your modem to your NIC card on PC.
You will have to make sure your network card is working (check for flashing green light and one solid green. Then you can goto COntrol panel and run the wizard to connect to the internet...it should work.
What kind of router do you have? Also, what is the model number of your modem?
Let me know if I can help further.
Good luck my friend.
SeekPCRepair
Feb 09, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
113 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
