Question about Dyson Vacuums
Suddenly power switch off, replace fuse stil same
  • 25 Answers
Dyson vacuums have a cut of switch on the motor when the motor gets hot it will cut out you need to clean both cyclone and filters and try again if you don't have any success then it is looking like replacement motor or replacement cut out switch
Posted on Sep 06, 2008
Sears kenmore vacuum 116.23401211C hardly used, suddenly no power at all. Cannot find manual, appears to be no fuse or reset on this model? Thx!
There is no fuse there is no reset either. If it doesn't run most likely the vacuum cleaner suction motor is defective or the power switch.
Feb 16, 2017 | Kenmore Vacuums
It was working fine and then all of a sudden stopped. The power switch still lights up but the motor doesn't run. What could be wrong?
you didn't state your model so I can't be specific to your model. It could be a loose wire, reset switch, bad motor, worn motor brushes, fuse, switch, etc.
You'll have to check to insure power is making it to the motor and if so why the motor isn't running.
May 01, 2016 | Vacuums
Edward hoover
If you changed fused, check power cord voltage or switch
Feb 24, 2014 | Numatic Vacuums
Power just stopped, will not turn on
this could be anything from a bad wall socket to a broken wire maybe a burned out switch or a fuse you will have to get a diagram on it and find out if it has a power fuse sorry hope this helps
Jan 29, 2014 | Vacuums
No power to vacuum - internal fuse? switch?
I would contact a local vacuum cleaner repair shop and ask this question.
Apr 20, 2017 | Dirt Devil Featherlite Bagless Upright...
Does the trivac 1100 have a fuse? My machine has suddenly stopped.I have checked the fuses in the plugs and also made sure that power is at the wall socket. I can see what loks like a fuse holder in the...
an attached photo would be better to explain this
I don't feel its the fuse
normally the fuse is inside the vacuum.
the problem you facing could be your power cable broken somewhere inside, if not this then something inside the vacuum
could be the motor itself
Oct 23, 2017 | Philips Vacuums
Hoover Alyx 2000w, no power. Help!??
Its a possibility then that if the fuse has been replaced that the cable inside has either come apart or you have a broken switch. If its only a year then you should be covered automatically with Hoover's guarantee.
Mar 05, 2009 | Hoover F5411 SteamVac Jr. Canister Vacuum
No motor action when the power is ON
I have the same problem with mine -- precisely the same model BSG 81335UC. It feels like the power button switch isn't working properly.
Dec 31, 2008 | Bosch BSG81360UC Premium Health Guard...
Steam Vaccum won't switch on
it sounds like your thermal fuse went out and u have to open it up ant test the fuse with a multimeter...I had the same problem and had to replace the thermal fuse...I ordered a fuse(sf188e) from ebay...cut the old one out and soldered in the new one...hope this helps.
Dec 30, 2008 | Euro-Pro Shark Steam Mop - Gray/ Purple...
H3000 doesn't start.
No fuses. The only thing in the circuit is the switch, so it's probably that. Good-luck.
Kirk Thompson
San Juan,PR
Oct 28, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Vacuums Logo
906 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
