Question about Konica Minolta DiMAGE Z3 Digital Camera
Is it possible to use filters? - Konica Minolta DiMAGE Z3 Digital Camera
    Master:
  • 425 Answers
A 52mm (in diameter) filter is attachable on this model. Please note the following: *1: The adaptor ring (sold separately), ZCA-300 is needed. *2: Filters cannot be used with the wide converter. *3: When the 8mm or thicker filter or some filters over another are attached, vignetting may appear. Test recording is recommended.
Posted on Sep 13, 2005
SOURCE:
After replacing filter, ICE dispenses ok, water not. FED from same water filter.
Check for water at the connection under the door. If you have water the tube in the door if possibly frozen. If not, its possible you have a bad water valve, But you need to check to make sure first, don't spend money on parts before checking. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 15, 2016 | Refrigerators
How do I change the filters in my Bizhub C360?
what sort of filter is it. ozone filter then see this video for possible location it is a different model but it might be a similar setup on your machine. http://www.youtube.com/watch?v=ZQtatt-6gTM
If it is the dust filters on the toner cartridges then
http://www.youtube.com/watch?v=cNOlf43vdRE
Oct 27, 2014 | Konica Minolta Bizhub C360
Trouble troubleshooting
Dirty fuel filter, clogged injector(s) water in fuel, dirty air filter. try fuel additive to clean injectors and remove water. replace air filter, fuel filter. possible could be the injector pump, would have to do a pressure check on fuel rail.
Aug 14, 2014 | Cars & Trucks
Runs ruff , will rev up, and if I turn it off and take the battery cable off it will runn good for a few kilometers, also put new fuel filter on when this started
Check the air filter. GM's mass air flow sensors are very sensitive to aftermarket and dirty air filters. I would recommend buying one from the dealer (or ACDelco is the same) if the filter needs to be changed. Also possible that the MAF sensor is defective.
It's also possible there is a vacuum leak somewhere, check all hoses and brake booster.
There are other possibilities, but these are just some quick checks without going into too much detail.
Jun 08, 2011 | 2000 Chevrolet 3500
2002 ranger 3.0 vulcan with 90k miles has been running sluggish, mostly on highway. Just no power. I am original owner and I know this is no rocket, but somethings wrong. No codes, new plugs and wires at...
Could be a handful of possibilities: When was last service - tune up and filters changed? Sluggish on highway suggests possible fuel filter. For the record filters, plugs etc should be changed every 30k. From what you're telling us, you've been running on borrowed time.
Jan 03, 2011 | 2002 Ford Ranger Regular Cab
Oil leak from cover around/above the oil filter. It is coming from above the plate where the filter is screwed against. Need help before I seek parts.
it is possible. although inferior oil filters have been known to do the same thing. for that matter inferior mechanics too. run and see if you see drips from the casing of the filter. it IS ALSO POSSIBLE TO HAVE WHAT THEY CALL "DOUBLE GASKET". SO GO GET A NISSAN OIL FILTER, PULL OFF THE OLD ONE AND CHECK FOR THE PRESSENCE OF 2 GASKETS OR O RINGS.
Nov 02, 2009 | 2006 Nissan Armada
Hi, went through the process of using sand filter cleanser & degreaser , the glass bottle shows clear water , I know that cannot be possible ,It actually has never showed real dirty water before either...
Sounds like you may have a bad spider gasket in your multiport valve or possibly a weak spring. Do you ever notice water coming out of the backwash while your system is set to filter? Another possibility is your screen on the air relief tube inside the filter is not in place, this will allow debris back into the pool but not alot, most if it would get filtered. Also, make sure your multiport valve is installed correctly and is set to the proper mode. There is a recirculate mode that will allow everything to bypass the filter. The label may even be incorrect.
Sep 10, 2009 | Hayward PRO SERIES 27" SAND FILTER W/1.5"...
Scratched Low pass filter on the sensor ! Nikon d60
all filters are available on Ebay or from a good camera supplier
Jul 27, 2009 | Nikon D60 Digital Camera
Occasionally, the car will not accelerate during a turn no matter how hard I push on the gas peddle. What could be the trouble?
There are many possible causes for this kind of problem.
1. Clogged fuel filter - just change your fuel filter
2. Dirty air filter - replace it or just clean it with compressed air
3. faulty throttle position sensor - this will be the extreme case but usually its just the fuel filter or air filter.
4. Used up fuel pump - its also possible that you fuel pump has given up
5. Bad spark plugs - check the spark plugs, see if they are still okay
Jun 27, 2009 | 2003 Nissan Altima
Konica Minolta DiMAGE Z3 Digital Camera Logo
56 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
