Question about Konica Minolta DiMAGE Z3 Digital Camera
Is it possible to use the built-in flash on condition that the wide converter is attached?
    Master:
  • 425 Answers
Yes, it is. Please note the following: *1: It is not recommended to use the built-in flash in the macro mode because vignetting appears. *2: When the focusing range (from the front of filter to the subject) is within 36cm, vignetting appears. Test recording is recommended.
Posted on Sep 13, 2005
My 1995 F350 Powerstroke "Shutters"
VIBRATION - DRIVELINE RESONANCE/VIBRATIONBETWEEN 1400 AND 2000 RPM WITH CONVERTER
Clutch ENGAGED DURING MEDIUM TO HEAVY
THROTTLE CONDITIONS - VEHICLES WITH 7.3L DI
TURBO ENGINE AND TRANSMISSION BUILT PRIOR
TO 11/13/95 (5L13)
^ TRANSMISSION - E40D - DRIVELINERESONANCE/VIBRATION BETWEEN 1400 AND 2000
RPM WITH CONVERTER
Clutch ENGAGED
DURING MEDIUM TO HEAVY THROTTLE
CONDITIONS - VEHICLES WITH 7.3L DI TURBO
ENGINE AND TRANSMISSION BUILT PRIOR TO
11/13/95 (5L13)
FORD:
1995-1996 E-350, F-250 CREW CAB, F-350 CREW CAB
Article 96-26-21 is being republished in its entirety as part of a consolidated 7.3L diagnostic aid booklet.
ISSUE
Some vehicles with transmissions built prior to 11/13/95 (5L13) may exhibit a driveline resonance/vibration between 1400 and 2000 RPM with the torque convertor engaged. This may be caused by the torque converter.
ACTION
Prior to torque converter replacement, refer to the following Service Procedure for details to verify conditions.
SERVICE PROCEDURE
1. Verify the resonance/vibration does not occur in neutral and is most noticeable between 1400 and 2000 RPM with the converter clutch engaged during medium to heavy throttle conditions. Also watch for the vibration to diminish at engine speeds lower than 1400 and higher than 2000 RPM. If the concern meets all of these conditions and the transmission has a built date prior to 11/13/95 (5L13), replace the torque converter. Refer to the appropriate Service Manual for removal and installation procedures.
2. If the vibration concerns do not meet the conditions, check for non-factory installed items that could affect driveline and verify proper installation. Also refer to the appropriate Service Manual, Section 05-00 for diagnosis and testing.
107118085
Aug 22, 2011 | 1995 Ford F250
Is the Wide angle converter (Nikon Wc-E68) compatible with the D3000?
No. The converter is intended for certain point&shoot cameras. It is designed to fit in front of the much smaller lenses. The D3000 has interchangeable lenses, so you can simply remove whatever lens you have on it and attach a wide-angle lens.
Feb 14, 2011 | Nikon WC-E68 0.70x Lens Converter
How can I get the firmware for utilizing the telephoto converter / wide-angle converter
The firmware for telephoto converter/ wide-angle converter is included in the attached CD-ROM. Please update it if you have DiMAGE series 7i to A1. Please confirm the firmware version and update it if you have DiMAGE A2 and its version is 1.10. DiMAGE A200 users do not need the firmware updating.
Sep 15, 2005 | Konica Minolta DiMAGE A200 Digital Camera
How can I get the firmware for utilizing the telephoto-converter / wide-converter.
The firmware for telephoto-converter/ wide-converter is included in the attached CD-ROM. Please update it if you have DiMAGE series 7i to A1. Please confirm the firmware version and update it if you have DiMAGE A2 and its version is 1.10. * Tele Converter ACT-100 and Wide Converter ACW-100 will be available at the end of March, 2004.
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
Is it possible to use filters?
A 52mm (in diameter) filter is attachable on this model. Please note the following: *1: The adaptor ring (sold separately), ZCA-300 is needed. *2: Filters cannot be used with the wide converter. *3: When the 8mm or thicker filter or some filters over another are attached, vignetting may appear. Test recording is recommended.
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Is the wide converter attachable?
Wide converter can be attached by using the dedicated adaptor ring ZCA-300 and will provide equivalent to 26mm angle of view in 35mm film. The closest subject distance: Normal Recording mode: 70.5 cm (from CCD), 60 cm (from the front of wide converter) Macro mode : 20.5 cm (from CCD), 10 cm (from the front of wide converter) *1 Set the Lens acc. to Wide Converter. in the setup menu. (Optical zoom will be fixed at wide-angle end.) *2 Built-in flash can be used when attaching a filter, but shadowing may occur at the bottom of the image. In this case, use of program flash 5600HS(D), 3600HS(D), 2500(D) (sold separately) is recommended. *3 Filter with 52mm in diameter can be attached to the adapter ring.
Connect an flash and aftermarket bracket
When using an external flash with the C-8080 Wide Zoom, you will need the appropriate flash cable with your flash and aftermarket bracket. The Hot Shoe Flash Cable (FL-CB05) mounts to the C-8080 Hot Shoe and the opposite end attaches to the aftermarket flash bracket’s flash shoe or to a standard tripod attachment thread (1/4x20).
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
Connect an external flash
For off camera flash with the C-5060 Wide Zoom, you will need the appropriate flash cable with your flash and aftermarket bracket. Please use the following information as a reference: FL-CB05 Shoe Mount TTL Flash Cable (item #200707) - this cable mounts to the Hot Shoe on the C-5060 Wide Zoom; and the opposite end attaches to the aftermarket flash bracket's flash shoe or to a standard tripod attachment thread (1/4x20).
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Shadow on image when using built-in Speedlight
The built-in Speedlight on many Nikon cameras is designed to be a convenient way to either light up a dark subject or to add fill light to a daytime scene. The built-in Speedlight cannot replace a full size, external speedlight which should be used when more power or coverage are needed. Because the built-in Speedlight is compact and close to the camera it cannot be used under all conditions. When using a lens that is physically very long, a subject that is very close, or a wide lens hood it is possible that a shadow may be cast upon the subject. Notice, in the sample below, the round shadow in the bottom center of the photo. When the lens is too long or the coverage is too wide with a close subject a shadow of the lens itself is cast. In figure "A" below the lens is casting a shadow. Switching (or zooming) to a shorter lens (figure "B") prevents the shadow and allows even illumination. If your lens, subject, or lens hood choice create a shadow, an external flash (either on the camera's hot-shoe or connected to the camera by a wire or wirelessly) should be used to fully light the subject.
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Konica Minolta DiMAGE Z3 Digital Camera Logo
26 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
