Question about Raymarine Smartpilot Autopilot St6002 S1g Hydraulic Inboard Pack
St6000 the linier drive unit has moved now the rudder centre point on the display shows it is not centered when it is how do i adjust the display to show center again thanks steve
    Problem Solver:
  • 18 Answers
The linear drive should have an adjustment screw on the arm so that it can be adjusted to show when the rudders are central. you will need to centre upm the rudders then loosen the screw and adjust until the guage shows the centre position. May take some fiddling to get right cause sometimes when you centre it the guage won't read correctly in the port or starbord directions (won't go all the way over). May need to re-position the whole unit.
Posted on Sep 19, 2008
When my rudders are straight the unit shows them hard to Port how do I adjust it?
transducers for rudder controls are a tricky item , just an experienced guess here , but if display is that far off (not just a few degrees) I say your problem is likely not an adjustment but instead a wire connection problem or a wet or defective transducer on the steering shaft , many a time I seen these get submerged in a bilge that got a little too high and then corroded up and failed to work (and ive seen this happen on 32 footers too 260 footers )
Feb 02, 2016 | Boating
I AP 35 Setup
ensure you are setting correct rudder value.
Aug 14, 2008 | Simrad AP35 GPS Receiver
Drive unit error navpilot 511
That errors means the autopilot is trying to move the rudder but it thinks its not moving. If you can manually move the rudder in standby mode with the green or red buttons on the 511, then the problem is typically with the rudder feedback unit. i.e. the rudder is moving but the only way the pilot knows it is if the signal changes from the rudder feedback unit.
If you can't make the pump work with the arrows (or anything else) then the problem lies with the pump. Check 12VDC to the pump and the connection to the processor.
Apr 03, 2014 | Boating
Rudder reference unit
Hi, the first thing I would do is check the wiring from the course computer to the feedback, on both ends and also check the rudder feedback mechanical link to the rudder.
It is possible that the problem is in the course computer but a problem with the feedback wiring or the feedback itself is much more likely. If the wiring looks ok and the mechanical connection looks ok, I would then check the feedback potentiometer to make sure it moves smoothly when the rudder moves. You can check it with an ohm meter. Depending on what it reads, you can then replaces the feedback or do further troubleshooting. The feedback is a just a 5k ohm potentiometer. Here are instruction on how to test a potentiometer.
95% of the time, problems like this are problems related to the feedback and not the course computer. I don't know if there is a reset for the computer, I would have to call the factory and ask, the manuals don't mention it. If it turns out that you do need a new feedback, I just so happen to have a new one in my shop.
Feb 18, 2012 | Boating
I can't find a replacement spool TF065 for my ST6000 trimmer/edger. My husband passed away, and there is no spool in the trimmer. Home Depot says there is none. You just wind it on by hand. I have...
Unfortunately, the manufacturer no longer carries the TF065 for the ST6000 trimmer/edger. No substitute is listed. The TF065 is no longer in stock at any of the parts stores that I checked. The Parts List and direct order information is available here: http://servicenet.dewalt.com/Products/Detail?productNumber=ST6000 .
You can try other Service Centers in your area to see if they have any spools remaining in stock. Use the Service Center lookup tool here http://www.dewalt.com/Find-Service-Center.aspx .
I wish that I had better news for you.
Jul 26, 2011 | Garden
Problem: Autopilot does not engage. This is a new problem as it was working quite recently. Model: Simrad NSE8/AP24 with AC42 Autopilot Computer. Attempts to engage the autopilot result in an...
jimtippettau:
Which drive are you using with the AP24, is it just a hydraulic pump on a powerboat, like our RPU80, or is it a hydraulic linear drive (like our HLD-2000) or draglink drive (like our DD-15) on a sailboat?
Mar 24, 2011 | Simrad AP24 AUTOPILOT DISPLAY UNIT
MOT POW SWAPPED, this is the message which appear just like that. the autopilot is working last 5 years, i have checked the wires connections, all is set as the diagram. one thing: my rudder has some...
Check if rudder reference unit is installed as before ,it seems that the pilot sense that the rudder is turning the wrong way. check when giving +10 command the
rudder turns to increase the heading,if yes, it could be the wiring of the rudder reference unit or it was installed the wrong way after service on the rudder.
Is rudder position indicating correctly?
Jun 24, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
My furuno autopilot 511 has a rudder reference unit which worked and then stopped displaying rudder position. I assumed it broke and replaced it. I still get no display. How can I clear the unit. I had a...
the rudder setup needs to be done. follow prompts, very common to be screwed up, read directions carefully and make sure that if it says steer hard starboard, it is hard starboard before you proceed! 847-746-0100
Jun 01, 2010 | Furuno NavPilot 511 GPS Receiver
Autohelm ST 6000
Check the installation manual for initial setup,if system worked before ,check rudder reference unit for broken wire loose connection or defective unit (it is a potentiometer resistance shoud change smoothly with position)
May 21, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
Trying to calibrate smartpilot, and controller shows large right rudder deflection. Repositioning the feedback piston has no effect on rudder readout. deflection is beyond the calibration range of -9. If I...
It sounds like the rudder feedback has a dead spot in the center of it. The replacement part numbers:
Rotary (inboard engines): M81105
Linear (outboard engines): M81188
Feb 15, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
Raymarine Smartpilot Autopilot St6002 S1g Hydraulic Inboard Pack Logo
254 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
David Burbee
David Burbee
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
