!st draw lift motor failure, is there a small wrench in the lower left hand corner of the control panel when you initial turn it on, before using it? Touch the small wrench it will take you to another screen, then open the front door and close it. that will reset the machine, Also check to make sure there is no paper stuck behind the draw. make sure sure the paper is properly installed in the 1st draw. Does the the metal plate below the baper in the first draw lift OK by hand? if the code comes back the chance is the 1st draw lift motor is bad worse case the control board that controls the whole machine is bad. just don't use the 1st draw. Try this site they mite have parts.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: codigo sc 440 aficio 350 (fotocopiadora
Hello sir; SC-440 means main drive motor locked ,suggestion; 1, check the connector isn't connected, 2, replace main motor.
SOURCE: cs pro minolta copier displays a code co6
Open close the front door if that does not work and the code comes back check you scanner cable underneath the large glass for the documents
SOURCE: i have a Minolta CS Pro EP 1031 Printer that makes streak marks
Drum cleaning blade has gone bad. Especially true if the streaks seem to get progressively worse as you run multiple copies. In other words run 10 copies. If the last one out is worse than the first one out it is the drum cleaning blade. Cheap part...around $25
SOURCE: I have a Minolta cs pro 2080 copier, shading on copies
3 possible causes:
1) The optics are dirty thus making your copy darker. The test for this is to manually lighten the copy using the exposure control on the panel of your copier. Lighten the copy several positions and see if the copy gets better. If it does then the optics need to be cleaned.
2) The copier is overtoned. This means that the toner to developer concentration is to high. This will require a trained technician to lower the toner ratio and then recalibrate the toner/developer ration using the F8 mode.
3) If the shading gets much worse as you run say 10 copies in a row then the drum cleaning blade would be the cause. So run 10 copies of something and compare the first copy out with the tenth copy out. Do you see a dramatic difference in the amount of background or "shading"?
Good Luck and thank you for using Fixya.
SOURCE: ERROR CODE CO5OO FOR MINOLTA CS/PRO 2080 ????
This is a lamp error, check that is not burned, or the thermal fuse.
1. Press the soft initialization on the right side of the control panel.
2. When the dot appears on the LCD after reboot, press the number 3 key.
3. The mode will change to the initialization screen.
4. Choose the selection for trouble reset.
5. After reboot the code will be cleared.
Warning: Be advised that with fuser codes, some RISKS are involved, PLEASE SEEK PROFESSIONAL HELP to reduce these risks.
Thank you and good luck!
