Question about Konica Minolta DiMAGE Z3 Digital Camera
Is the wide converter attachable? - Konica Minolta DiMAGE Z3 Digital Camera
    Master:
  • 425 Answers
Wide converter can be attached by using the dedicated adaptor ring ZCA-300 and will provide equivalent to 26mm angle of view in 35mm film. The closest subject distance: Normal Recording mode: 70.5 cm (from CCD), 60 cm (from the front of wide converter) Macro mode : 20.5 cm (from CCD), 10 cm (from the front of wide converter) *1 Set the Lens acc. to Wide Converter. in the setup menu. (Optical zoom will be fixed at wide-angle end.) *2 Built-in flash can be used when attaching a filter, but shadowing may occur at the bottom of the image. In this case, use of program flash 5600HS(D), 3600HS(D), 2500(D) (sold separately) is recommended. *3 Filter with 52mm in diameter can be attached to the adapter ring.
Posted on Sep 13, 2005
SOURCE:
I have a FZ100 with aDMW-LA5 adaptor can the DMW-LW55 be fitted onto this camera using this adaptor?
I have a DMC-FZ100, DMW-LA5 adapter and an Olympus B-300 HQ 1.7x Tele Converter (instead of a DMW-LT55 - but that's another story). I also bought a DMW-LW55, thinking that I could fit it to DMW-LA5. However, looking at the LA5 Instructions, it says "(As of July 2010)The following types of lenses cannot be attached and used. Vignetting etc. may occur when taking pictures in wide)- Wide conversion lens DMW-LW55- ND filter DMW-LND55- MC protector DMW-LMC55"
This is very annoying considering that the LA5 is sold as THE adaptor for DMC-FZ100, DMC-FZ45, DMC-FZ40.
So what's the solution? A 52mm to 55mm step up filter ring? Will the wide angle lens be too close? Then there's the Panasonic DMW-LA2(E) It looks shorter than the LA5, but will there still be a vignetting problem? I am still seeking answers.
Mar 25, 2011 | Panasonic DMW-LW55 0.7x (DMWLW55) Lens...
Is the Wide angle converter (Nikon Wc-E68) compatible with the D3000?
No. The converter is intended for certain point&shoot cameras. It is designed to fit in front of the much smaller lenses. The D3000 has interchangeable lenses, so you can simply remove whatever lens you have on it and attach a wide-angle lens.
Feb 14, 2011 | Nikon WC-E68 0.70x Lens Converter
Video files in AVI format
use media converter free download
Nov 28, 2010 | Televison & Video
How can I get the firmware for utilizing the telephoto converter / wide-angle converter
The firmware for telephoto converter/ wide-angle converter is included in the attached CD-ROM. Please update it if you have DiMAGE series 7i to A1. Please confirm the firmware version and update it if you have DiMAGE A2 and its version is 1.10. DiMAGE A200 users do not need the firmware updating.
Sep 15, 2005 | Konica Minolta DiMAGE A200 Digital Camera
How can I get the firmware for utilizing the telephoto-converter / wide-converter.
The firmware for telephoto-converter/ wide-converter is included in the attached CD-ROM. Please update it if you have DiMAGE series 7i to A1. Please confirm the firmware version and update it if you have DiMAGE A2 and its version is 1.10. * Tele Converter ACT-100 and Wide Converter ACW-100 will be available at the end of March, 2004.
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
Is it possible to use filters?
A 52mm (in diameter) filter is attachable on this model. Please note the following: *1: The adaptor ring (sold separately), ZCA-300 is needed. *2: Filters cannot be used with the wide converter. *3: When the 8mm or thicker filter or some filters over another are attached, vignetting may appear. Test recording is recommended.
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Is it possible to use the built-in flash on condition that the wide converter is attached?
Yes, it is. Please note the following: *1: It is not recommended to use the built-in flash in the macro mode because vignetting appears. *2: When the focusing range (from the front of filter to the subject) is within 36cm, vignetting appears. Test recording is recommended.
What is included in Wide converter kit ZCW-300 ?
The wide converter kit includes: Wide converter, Adapter ring, Front and Rear cap, Case.
Wide angle adapter
I wouldn't worry about the adapter. I'm going to try ordering a telephoto converter this weekend.
Sep 06, 2005 | Panasonic Lumix DMC-FZ1 Digital Camera
Konica Minolta DiMAGE Z3 Digital Camera Logo
93 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
