Nokia C7 (8 GB) Smartphone Logo
Posted on Aug 03, 2011
C7 Nokia mobile I have is overheating even when it is not used. Also I have to charge the phone twice eventhough I am a normal user, where as the E66 which I had never had this type of problem. The touch screen doesn't work some time and it also hangs when we about to receive a call. can any one help
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
277
Points
5
Try to change the battery in it its charge life could be expired,
How to unlock phone nokia e66
HI whether your Nokia e66 mobile is locked to one particular network provider .Then you can easily unlock it using network unlock code ..You can purchase code from online providers like Classicunlocking.com who render unlock code for all mobile models at reliable cost ....You first check that whether the code is available for your country and network provider ..If yes then pay for it and unlock your mobile.
2answers
E66 nokia reset lock code
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
I forget the restore code of e66
NOKIA C7 WONT SWITCH ON HELP!!!!
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
I need unlock code for nokia c7 movistar spain locked
u can get the unlock code for your nokia c7 model from by using this link http://www.theunlockarena.com/
following instructions makes u easy to unlock your mobile
1 - Switch on your Nokia C7 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C7.
3 - Compose #pw+CODE+1#.
4 - The Nokia C7 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia C7 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia C7
Each Nokia C7 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia C7 mobile phone using the form above.
2helpful
My nokia c7-00 switched off many times and dont switch on again
Actually it seems like majority of Nokia C7 users are facing the same problem. Even i am too facing exactly the same problem. But i gave my device to care center and hope that they fix it. Or else i will like to switch to different brands. It is very disappointing and the nokia's statement Connecting people is now turning to Disconnecting people. And as far i know the same problem exist in the case of Nokia N8. Anyone who is wishing to buy any of these mobile please drop your idea and turn to some other brand .
10helpful
2answers
I have forgot the Lock-Code from My Nokia E66 !!! Please help me! I need the Mastercode...my Nokia E66 is fully locked!!! IMEI: 352942022719907 THANK YOU VERY MUCH FOR EVERY HELP!!!!!
I have forgot the Lock-Code from My Nokia E66 !!! Please help me! I need the Mastercode...my Nokia E66 is fully locked!!! IMEI: 35796033026071 THANK YOU VERY MUCH FOR EVERY HELP!!!!!
1helpful
I lost my nokia e66 security code
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
