Question about Sony Cyber-Shot DSC-P72 Digital Camera
Faulty Memory Stick
I have a Sony DSC-P72, I have 3 memory sticks, 2 are working fine, the 3rd stick gave me trouble in the camera (I kept getting error codes)after approx. 70 pictures. I inserted the memory stick into a Memorex reader and it does not see it, therefore I cannot unload the photos. I have been using the stick for about 1 year, this is the first time I have been unable to unload the photos onto PC. Any help or ideas would be greatly appreciated. Thank you.
    Sergeant:
  • 255 Answers
See if you can download the photos through the USB cable. Then try reformatting it in the camera. Otherwise, I probably would get rid of it. Memory is cheap enough, and it's not worth the risk to keep around an unreliable memory card.
Posted on Sep 13, 2005
SOURCE:
Memory Stick error
Hello!
Following types of memory sticks are compatible with the Camera model DSC-V1:
Memory stick: 32/64/128 MB
Memory stick Pro: 256 MB/512 MB/1 GB/2 GB.
Mark 2 Memory stick Pro: 1/2 GB.
However, in order to use Memory Stick Duo or MagicGate Memory Stick Duo media with the Camera, a dedicated adapter (MSAC-M2) must be attached.
Follow the steps given below to troubleshoot the Camera that is not recognizing any compatible memory sticks:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C186797
Furthermore, you may try resetting the Camera to the original factory settings by pressing and holding the Reset button for 30 seconds.
If the issue persists even after performing all the above mentioned steps then the Camera is required to be diagnosed and serviced.
Aug 22, 2009 | Sony Cameras
Memory sticks "MEMORY STICK ERROR" for SONY DSC-S30/S50
this camera doesnt take mem stick pro. has to be the original lavender sticks.msh-ms128 is the model # only goes up to 128 mb. only stick that will work with that cam.
Jun 01, 2009 | Sony Cyber-Shot DSC-S30 Digital Camera
Can't use the video function of my SONY CYBERSHOT DSC-T500
Please reduce memory stick size as 8 GB is too much for it and 2 GB would be fine in DSC-T500
Feb 10, 2009 | Sony Cybershot DSC-T200 Digital Camera
Maximum Memory Stick size I can put into my Sony DSC-N1
Unfortunately, there is no way to change the internal card reader in the camera to accept higher density memory cards. You can find the memory stick compatibility list here: https://esupport.sony.com/perl/support-info.pl?&info_id=12 . Scroll down to the Cybershot N Series camera list. The maximum capacity memory stick is 4 GB memory stick pro or M2 Memory stick Pro. For the Memory Stick Duo, it looks like those have a maximum capacity of 2 GB.
I hope this helps.
Apr 14, 2017 | Sony Cyber-shot DSC-N1 Digital Camera
Memory Stick error c:13:01 My old 512 MB memory stick is working fine. However, recently I brought a 2 GB memory stick and when I put it inside, the camera (Sony DSC S40 cyber shot) shows: MEMORY STICK...
Is your new 2GB memory stick is original from Sony or after market? some of them will not detect in CAM because the contact on MS were not touched iside the slot of CAM
Reinsert your 512 MB MS if it work fine then change your 2MB MS
Good luck
Nov 30, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Memory stick
128MB or 256MB Memory Stick will be fine for DSC-P73
Jul 29, 2008 | Sony Cyber-Shot DSC-P73 Digital Camera
Vidoe option on camera used to work, but now: 640(fine) is not available
Hi
I think to work on 640 fine you need a much higher memory stick, I use a 2gb in mine and it is fine (that is when the camera works) .You get 24 minutes or more on the 2gb stick and that is at 640 fine.
Jul 10, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Problem accessing memory stick
I had the same problem. I bought a 2 gig memory pro-duo with the adapter and it gave me that error even though it fit just fine. I then tried a 512 memory stick and a 1 gig memory stick and neither one worked it gave me the C:13:01 error code. So I found out the hard way that the camera will not read it. The Sony DSC-S85 will not take memory above a 128. Try the Lexar 64MB memory stick. I just bought 4 and they work perfectly fine.
Nov 02, 2007 | Sony Cyber-Shot DSC-S85 Digital Camera
Which memory stick ?
Several of the Sony cameras require a high speed memory stick for 640 x 480 30fps movies. Here is a clipping from the Sony P150 specifications: "MPEG VX Fine with Audio (640 x 480 at 30fps), (MPEG VX Fine requires Memory Stick PRO media)"
Sep 08, 2005 | Sony Cyber-Shot DSC-P150 Digital Camera
Sony Cyber-Shot DSC-P72 Digital Camera Logo
54 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
