Question about HP LaserJet 3055 All-In-One Printer
Hp 3055 adf
Hi, our top scanner (adf) will not feed smoothly - jams. cleaned accessible rollers, how do you get in to main rollers?
regards gj.
ADF problem. I put original in ADF, give a"COPY" command (READY on display), but scanner get image from glass, no from ADF. Can help me somebody?
Posted on Oct 12, 2009
  • 138 Answers
Here's a link to the full service manual for your HP 3055. It's too large to post here (15MB) but I've hot linked it for you so you can download it to resolve your issue with the ADF. Look at pages 44 thru 46. Pay special attention to the rubber pad (separation pad) that is under the 2 roller peice as it is what keeps the doc feeder pulling one sheet at a time.
Hope that helps you. If so hit me with a FIXYA, If not send me a message or reply and I'll try and walk you through it.
http://h20181.www2.hp.com/plmcontent/NACSC/Printers/LaserJet/30328_020806/course/library/service/lj3050-3052-3055aio/Q6502_service_enww.pdf
Posted on Sep 03, 2008
Fi-6130z fujitsu scanner jamming repeatedly
Hello Meg,
To troubleshoot your scanner issue, yuo are advised to perform the steps provided below:
1.Remove all documents from the ADF paper chute.
2.Open the ADF while pressing down the ADF open lever. If your has the imprinter option attached, please open the imprinter and then open the ADF.
3.Remove the jammed papers from the ADF.
4.Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, then please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is resolved.
5. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the values, replace Pick roller or Brake roller see if the error is resolved.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Nov 26, 2013 | Fujitsu Fi6130z Sheetfed Scanner
Error J1
Hello Sharon,
When a document jam occurs, "J" and "1" will display alternately on the function number display panel of the scanner.Please perform the following:
  1. Remove all documents from the ADF paper chute.
  2. Open the ADF while pressing down the ADF open lever. If you are using fi-6130 with the imprinter option attached, please open the imprinter and then open the ADF.
  3. Remove the jammed papers from the ADF.
  4. Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, please check the followings:
resolved.
5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
Thanks & regards,
ScanCare
May 03, 2013 | Fujitsu Office Equipment & Supplies
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Doc.feder jam
Try cleaning the rollers in the ADF (Automatic Document Feeder).
It might temporarily solve the problem, but rollers do have a limited life time, so you will eventually need new ones.
Part info:
5851-3580 - Automatic document feeder (ADF) paper pick-up roller assembly
Price: $15.57
Dec 10, 2008 | HP LaserJet 3055 All-In-One Printer
There is a paper jam in the ADF... I have a hp 2840
The top cover piece at the left-hand end of the ADF just lifts up. Put your fingers under the edge where the paper feeds into the ADF reader and lift gently on only the plastic cover itself. It is hinged on the leftmost outside of the reader mechanism. Once that cover is lifted then the main feed roller is exposed, and it also just swings up out of the way to the left to provide easy access to the feed path. You will likely also have to lift up the entire ADF to gain access to the flat glass flatbed read platten area to access the remainder of your original.
Dec 08, 2008 | HP LaserJet 2840 All-In-One Printer
Paper Jam - ADF
Open ADF cover
Lift up Pickup roller Assy
remove spring from pickup roller assy
Remove pickup roller assy gently pull it towards you
Carefully remove green plastic diverter
note this is held in place by 4 plastic pins 2 on each side
look in the opening for foreign objects.
( I have found labels, money, paperclips, plastic pieces,jammed paper in this area)
Aug 20, 2008 | HP LaserJet 3055 All-In-One Printer
HP Laserjet 3055 with "scanner error 6 - turn off and on" error
hp laserjet 3055 by scanner error 6
Solution: I found a very small piece of paper between the glass and the scanner housing. The lamp's seen that and sent the error message. Nobody find that little stucked paper and the "IT expert" sad: need to buy a new machine because he can't repair it. So, sometimes the solution is very easy just need some attention. :)
Apr 27, 2008 | HP LaserJet 3055 All-In-One Printer
Is it worth it? Will this be a recurring problem?
Try cleaning off the roller with a lint free cloth. Here is the part HP LASERJET 3055 DOC FEEDER - ADF Pickup Roller Assembly - HP Part #: 5851-2559 which can be bought for $45 at places online.z8220.th.jpg
Jan 19, 2008 | HP LaserJet 3055 All-In-One Printer
Documate 510 scanner ADF problem
Hello.
I am a Support Engineer with Xerox Scanners.
If the feed rollers are worn out beyond the point of cleaning, you will need to have the scanner serviced or replaced.
Please contact us to discuss your service or replacement options by calling 800-648-0410.
Regards,
Xerox Scanners Support
Dec 07, 2007 | Xerox DOCUMATE 510 Flatbed Scanner
ADF document feed
Hi, The problem seems to be a piece of debris , paper stuck in the ADF roller assy. You can check this by opening up the adf cover and inspecting the paper path. I have seen where a very small peice can cause paper path problems to where something is blocking the paper> Good Luck!
Dec 03, 2007 | HP 5590 ScanJet Flatbed Scanner
HP LaserJet 3055 All-In-One Printer Logo
1,239 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
