Question about Canon Office Equipment & Supplies
TRANSMISSION REPORTS ARE COMING OUT OF THE BACK OF MACHINE INSTEAD OF FRONT AS USUAL MACHINE NO L380S
  • 2,016 Answers
There is a paper delivery selector switch on the front of the machine just below the control panel. Setting the switch one way delivers printed paper out the front. In the other direction, the paper will feed out just above the paper tray on top of the machine.
Posted on Sep 02, 2008
Coming from a law firm legal department background, I have been known in the past to run off too many docs on the printer/copier a kill trees. I am working very hard to start "greening" my...
Most faxes and MFP (multi function printers) can be set not to print the confirmation page with every fax. All these settings and many more can be found it the User Reference manual that came with the printer if you can't find yours one is available here:
http://www.fixya.com/support/p378618-hp_officejet_6110_all_in_one_inkjet/manual-3613
Page 37 "print reports" is what you're looking for
Nov 16, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I'm getting an error mesage: ECM error on my Sharp AR-M207 fax machine. How can I fix it?
ECM (Error Correction Mode) is a feature common in most fax machines today. It helps to minimize errors while transmitting faxes over noisy phone lines.
1) Be sure you have the latest version of the drivers installed
2) Turn the fax off, then unplug for 10 minutes, turn on and try again. This should clear up anything in the printer/fax memory
3) Check if your phone line is unsually noisy when you tried to send the fax(es) that gave you the error message. If this is the case, a sucessful fax transmission will be almost impossible. You may have a faulty phone line or an improper installation. Either of these two should be fixed by your phone company. Also, most phoen companies can test your phone line (for fre) remotely to check for abnormally high noise levels.
Please, report back if you need further assistance.
My ID: alexocuello_
Mar 31, 2010 | Office Equipment & Supplies
Can a clutch in a 2002 eclipse be replaced without removing the motor
Yes, it can; you just have to remove the transmission and front suspension instead. The front suspension so you can get the axles out of the transmission and so it has a place to come out. Usually, you can slide the transmission out of one of the wheel wells to work on it.
Mar 26, 2010 | 2002 Mitsubishi Eclipse
How can I print a fax confirmation on a specific outgoing fax
Checking a report for the transmission result (?TX Report? function) A report containing the transmission results can be printed. The machine can be set to either print or not print the transmission report or to print it according to the machine setting or only when a transmission fails. To print the transmission report 1 Press the [Fax/Scan] key to display the Fax mode screen. 2 Touch [FAX Menu]. 3 Touch [TX Report] on the Set 1 tab. 4 Select how to output the report, and then touch [Enter]. ? Default: The transmission report is printed according to the previously specified method. For details, refer to ?Specifying report output settings (Report Settings)? on page 10-48. ? ON: The transmission report is printed with each transmission. ? If TX Fails: The transmission report is printed only if the fax could not be sent. ? OFF: The transmission report is not printed, regardless of the transmission result.
Aug 10, 2009 | Minolta bizhub 200 Copier
Unable to recieved any faxes or confirmation reports
Probably the back up battery is dead, and has been set back to default settings.
I can't help you with the method of setting, but it has switched to "manual receive", instead of "automatic", and "tx report" (transmission report) is off.
....and "no" you can't install a new battery yourself, and depending on the model, I doubt it's worth having repaired
Apr 02, 2009 | NEC Office Equipment & Supplies
Transmission report
Press the DATA REGISTRATION button and press SET. Push the DOWN ARROW to REPORT SETTINGS and press SET to TX REPORT and press the SET key to make the change press the DOWN ARROW until it says OUTPUT YES and press SET. Press the orange CANCEL key when done.
Apr 02, 2009 | Canon LaserClass 7000 Plain Paper Fax
Hi how do I turn of tx and rx reports on faxcentre F110/
The machine can print a transmission (confirmation) report after each transmitted fax. This report indicates whether or not the fax has reached the intended recipient. Four different settings are available for the transmission report:
  • With: a report is printed when the fax transmission was successfully sent or when it is completely abandoned. There is only one report for each fax sent.
  • Without: no transmission report is automatically printed, however, the machine will save all fax transmissions that took place in memory. The faxes sent can be viewed by printing out a transmission log (report).
  • Always: a report is printed after each successful or interrupted transmission.
  • On Error: a report is printed only if the transmission failed or is abandoned.
NOTE: With each transmission report from memory, a reduced version of the first page is automatically reproduced.
To modify the report type setting:
  1. Press the [OK] button directly below the Display Screen. '1 Installation' and '2 Fax' will be displayed.
  2. Press [2], [5] on the numeric keypad. ‘25 >Send Report’ will be displayed.
  3. Press [OK]. The transmission report screen will be displayed.
  4. Press the up or down arrow button directly below the Display Screen to select a transmission report setting, then press [OK]. ‘25 Send Report’ will be displayed.
    NOTE: As the up and down arrow buttons are pressed, the menu will scroll through the available choices and move the greater than symbol (>). Stop when the greater symbol is in front of the appropriate selection.
  5. Press the [Stop] button on the Control Panel. The 'Date / Time' screen will be displayed
Dec 11, 2008 | Xerox FaxCentre F110 Plain Paper Laser
I have a canon L380s Fax with a paper feed problem, the paper pick-up tyre constantly rotates, causing, obviously! paper jams. I had the side off but can't quite work out how the planetary gear clutch...
There is a soloniod arm on the lower left side of the machine that hook on the feeding clutch.Check the soloniod for any problems.
Please rate me!
Nov 04, 2008 | Office Equipment & Supplies
Transmission Verification Report
HI Shelia. THere is a button marked as "function" on your fax machine and got to "set up". Press that and select the "print out" group. When you get in there you will see "reports"... select that and it will let you get into your reports mode. Make sure you have transmission turned off. You can set it up to print out every 50 faxes...that seems to work best for most people. You may have to dig around in those menus...but its in there. I just don't have one sitting in front of my right now. If you still can't find it, email me back and I will look monday when I am back at the shop.
Nov 16, 2007 | Brother IntelliFAX 2800 Laser Fax
Washing Machine trouble
The easiest way to solve this without taking the machine apart is to tilt the machine back and look under it.
Above the transmission and clutch you will see the brake assembly. It is a little aggrevating to get to with the cabinet on, but you can spray it with some silicone lube and it will help this problem. You may have to spray it then put into spin, stop it and spray again. After it spins and stops a few times it will usually smooth out.
Nov 05, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
old marine
old marine
