Question about Zebra Eltron P330i Card Printer
Polaroid - 75 ID Card Printer
Hi
I am trying to connect my Polaroid - 75 ID Card Printer to my pc, the wizard keeps on saying that I have to have the Eltron Card Printer p310cm software to do this. Can I download this software off the internet or should it have come with the Printer? If not either can I purchase this software at a store?
Darlene
5 Suggested Answers
SOURCE: Eltron 2844 CTP Printer on Ubuntu
I got it working by selecting the Zebra manufacturer, EPL2 driver.
Posted on Apr 27, 2009
  • 31 Answers
SOURCE: Ribbon cuts or stick over Id surface when printing with Eltron
Turn the heat settings down in the driver. Clean the printer with the available cleaning card. Have the printer serviced.
Posted on Jan 31, 2010
SOURCE: I need drivers Eltron Zebra
Hi I solve this problem with a program called CardFive this program provides several drivers inside when you install it in Windows 7. I install CardFive 6.3. Note. this program don´t install a printer driver in Devices and Printers in Windows 7, only provides you a interface to print cards with your Eltron p310 and you can choose other printer models discontinued. My printer interface is parallel and works in Windows 7 With CardFive 6.3 pro.
Posted on Jan 17, 2011
  • 38 Answers
try download SEAGULL driver/software it solve my problem.
Posted on Oct 27, 2013
Help i can't find the driver for eltron plastic ID Card Printer P420 printer for windows xp
If you Google 'eltron p420 driver windows xp' you will see a number of possible sources listed. I am assuming you have not tried it that way, but if you have, apologies.
Take care, when you download from one of these sources, to have an up to date anti-virus program running. Also when you download, save the download file to a Temp directory and send it to a scanner site like VirusTotal.
http://www.howtogeek.com/howto/18993/beginner-geek-scan-files-for-viruses-before-using-them/
The reason for this is that XP is an obsolete OS which is no longer being patched by Microsoft, so the last version of it may have vulnerabilitites.
Apr 24, 2016 | Zebra P420i Double Sided Color Id Card...
I need drivers Eltron Zebra P310CM for Windows 7
Jan 14, 2011 | Zebra Eltron P310 Thermal Printer
My zebra p330i keeping on showing downloading data.It doesn't print from PC
Install the driver again.
go to the driver and send the command "R"
and "!SA"
if not working, flash the firmware. (www.zebra.com) have to be the especific firmware
http://www.zebra.com/id/zebra/na/en/index/drivers_downloads/firmware/results.html?productType=6
Nov 04, 2010 | Zebra Eltron P330i Card Printer
Jan 21, 2010 | Zebra Eltron P420C Printer
ELTRON 2622 thinking it's a fax
Turn off the printer and place your finger on the green feed button. With the button depressed, turn the printer back on. Let the light flash (ONLY!) four times and release the button. Printer will cycle through 2-3 labels. Press the feed button one more time.
You've just set the printer back to factory default and dumped whatever setting told it to act as a fax.
Aug 07, 2009 | Zebra ELTRON 2622 TT Printer
What does a Polaroid p85igc card printer use for a full color ribbon? Zebra p330i ymcko ribbon won't work.
The "i"suffix was introduced in around 2005 to try to stop patent infringements on the printer ribbons. They introduced a chip on the spool that feeds back to the printer. The chip has to be the correct coding for the badge of the printer. Zebra P330i printers are essentially the same as Javelin J330i and Polaroid p85igc but have three different part numbers for their YMCKO ribbon. You can run any monochrome ribbon on them because the mono ribbons have no chip.....not much profit for the brand owners. YMCKO however is not interchangeable. Find a Polaroid dealer for the full colour ribbon.
Jul 08, 2009 | Zebra Eltron P310 Thermal Printer
Printer problem
your problem may be in the serial /usb adaptor that you are using
any reason why you cannot connect the usb cable from the printer directly to a usb port on the computer
like any other printer
Mar 19, 2017 | Zebra Eltron Orion LP2443 Thermal Printer
How do I reset the card-print counter on an Eltron P420C
u select the properties and search for tabs like card count,details etc and reset thecount to 0.im not sure about this answer this may work or may not be.
Aug 26, 2008 | Zebra Eltron P420C Printer
Bad print heads
This is a continuing problem we have with our Fargo DTC550 printer. If you remove the printhead from the printer and look at the underside you will see a nick on the head in the same area you are getting a line on your card. Fargo claims we damaged the head due to not keeping the printer clean even though we clean at every ribbon change. I believe that the damage happens when a plastic debris (from the plastic card) gets between the card and the head. You must check your card stock to make sure there is no plastic debris on them. Bottom line, you have to replace the head and at the time it costs $700 per head.
Apr 30, 2008 | Fargo DTC550 Thermal Card Printer
Zebra Eltron P330i Card Printer Logo
504 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
