Question about ASUS P5QC Motherboard - Intel P45, Socket 775, ATX, DDR3/DDR2, Audio, PCI Express 2.0, Gigabit LAN,
ASUS Asus P5QC Motherboard
I have biult a new PC P5qc Intel 9550 ddr3 ram etc all compatiable and connected in right slots etc. The green light on the mother bord comes on but no fan activity atall or harddrive + no beeps. Tested my PSU seperatley with the old paper clip trick and it works so am lost for ideas? Any help greatly apprecaited, thank you.
Edward
  • edwardfuller Sep 03, 2008
    Thks a mill for advice dlundmark I'll try when I get home. Guessing my CPU or motherbord is caput! Boohoo for me. Ill post either way on how it turns out.
  • 797 Answers
Hello edwardfuller:
Do the same as you did, only this time remove all plug in boards and if there is anything connected to the mother board such as extra fans, speakers, and so on, remove all.
The board will detect any shorts, or overloads or problems in cards and so on , and will not turn on.
If it still will not work, check your memory sticks.
Remove all memory and place one at a time in the first slot, and then proceed to turn on and test.
By elimination, you can find the problem.
If all fails, then something may be wrong with the mother board.
take care, hope this will help,
Posted on Sep 02, 2008
  • Dave Lundmark
    Dave Lundmark Sep 02, 2008
    Hello edwardfuller:
    In addition, make sure that the cpu is correctly connected.
    Make sure that the cpu is working and has not quit.
    If something is wrong with the cpu, the system may not start.
    take care,
  • 341 Answers
When you say you used a paper clip to test the power supply,what do you mean by that?
Posted on Nov 26, 2008
Why cant i get my 4x 2gb ddr2 800 to work on my asus p5qc mobo? it will run fine with just 4gb 2x ddr2 800 but when i add the other 2x ram i get black screen at boot
Be sure to check which slots you are putting them in, stay within the same colors as to which needs to be put in.
This may be why, looks like your using DDR2
DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel. Ensure to install the DDR2 1066MHz DIMMs ONLY on the BLACK slots!
This may be the case for all speeds of DDR2
http://www.asus.com/Motherboards/Intel_Socket_775/P5QC/
Jul 16, 2011 | ASUS P5QC Motherboard - Intel P45, Socket...
Hi , my name is Nitin and the problem i am facing with my PC is that it gets restarted after every 10 to 15 minutes while playing games and it starts disk checking everytime it restarts. This happens even...
The following tip is not for the same model, but for the same kind of symptoms :
http://www.techsupportforum.com/hardware-support/motherboards-bios-cpu/183116-asus-p5p800-p4-3-0ghz-random-reboots.html
Dec 18, 2010 | ASUS P5QC Motherboard - Intel P45, Socket...
Can i boot from usb port on asus p5qc mother board
only if it shows in bios under boot devices and it is enabled.
Jul 23, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
ASUS P5QC refuses to boot
This is a known issue with Asus motherboards. I got 2 in my shop with the same problem. While I didn't have your model I'll assume the issue is on that board as well.
Clear cmos with the jumper on the motherboard. This resolves the issue with no video.
There should be a 2 pin jumper, your motherboard manual will show you where its located.
Good Luck
Mar 27, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
Qvc said my ram isnt on the list
From the Asus website - "DDR2 1066MHz DIMMs work only on the black slots for one DIMM perchannel. Ensure to install the DDR2 1066MHz DIMMs ONLY on the BLACKslots!"
Your motherboard only has two black slots. You can install larger capacity sticks of RAM in those slots, but you can only use two. Most likely you are getting the incorrect reading because you have four installed.
Jan 26, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
Asus p5qc not working
The motherboard is dead most likely, if the cpu fan is running ? the hdd can be heard running ? the cd/dvd device is active ? then the motherboard is toasted. what is the system ?
compdoctor2005@btinternet.com
Nov 16, 2008 | ASUS P5QC Motherboard - Intel P45, Socket...
Windows fail to boot
How much power is the power supply? Could be the power supply not having enough power for your rig.
Sep 23, 2008 | ASUS P5QC Motherboard - Intel P45, Socket...
ASUS P5QC Motherboard - Intel P45, Socket 775, ATX, DDR3/DDR2, Audio, PCI Express 2.0, Gigabit LAN, Logo
417 people viewed this question
Top ASUS Motherboards Experts
Brian Sullivan
Brian Sullivan
David
David
Tony
Are you an ASUS Motherboard Expert? Answer questions, earn points and help others
