Question about Microsoft Windows Server Standard 2003 for PC
Couldn't open the hard Drive folders....
Hi vrabhilas,
Am using windows 2003 Server Enterprise Edition. While, i double click the hard drive folders, i mean (C, D, E or F:/), the "Open With" Dialog box opens and asks for choose the program you want to open. For your kind reference i've attached you the snap-shot of the dialog box.
Thanks,
Arun
    New Friend:
    Problem Solver:
  • 9 Answers
Hi sir,
i think you have an autorun.inf file residing at your local drives. this probably infected by a virus.
go to control panel >folder option> click View> choose "Show Hidden Files and Folders" and uncheck Hide Protected Operating System Files, this will show hidden autorun.inf file. In your explorer, right click your local disk and click explore, this will show all your files and folders of your drive, navigate autorun.inf file, if found delete it.
note: it has an associated file called vbsscript file...if found also delete it..do the same with the other drives. empty recycle bin and restart.
Winsor
Posted on Sep 04, 2008
Hi ,I have HP Pav DV6 with windows 7.But I want to install windows server 2003 & its not allowing me.I want to make it dual boot,Plzz help.I need to do it urgently...
Please understand that Windows 7 uses different startup files and procedures so it is expected that the original Windows Windows 7 system cannot be booted if you install a new dual boot Windows Server 2003 system. If you would like to install Windows Server 2003 on another partition, please do that first. After that, Windows Server 2003 will boot but WIndows 7 not. However, we can try the following method to make Windows Vista work again: Insert the Windows 7 disk into DVD-ROM. Click Start, click Accessories, right-click the command-prompt shortcut, and then click Run as Administrator. Type the following command at a command prompt and press Enter: Drive:\boot\Bootsect.exe /NT60 All In this command, Drive is the drive where the Windows 7 installation media is located. Note The boot folder for this step is on the DVD drive. 4. type the following commands at a command prompt and press Enter. Note In the commands below, Drive is the drive where Windows 7 is installed. Drive:\Windows\system32\Bcdedit /create {ntldr} /d "Windows Server 2003" Drive:\Windows\system32\Bcdedit /set {ntldr} device partition=x: (Note: x: is the drive letter for the active partition. For example, if 2003 is installed on C drive, device partition=c: ) Drive:\Windows\system32\Bcdedit /set {ntldr} path \ntldr Drive:\Windows\system32\Bcdedit /displayorder {ntldr} /addlast
5. Restart the computer.
Jun 08, 2011 | Computers & Internet
Tip
How to back up using Ventrilo
<p>Ventrilo is an application that a web server and you can chat with other registered users. Ventrilo is often used in games will allow players in multiplayer games, real-time interaction. Some users have programmed several Ventrilo server setup on the machine. Ventrilo safe is copying a specific file on the backup device. This ensures that your server settings, copy the file, you do not recover your hard drive. <br /> <p><br /> <p>1. Click the Windows Start button. Click Open "Computer" from an Explorer window. Double-click the C drive to a list of folders on your computer to see. <br /> <p><br /> <p>2. Double-click the Documents and Settings folder. "This is a folder with the profiles and preferences of the user. Each user has a separate folder. The folder is labeled with the user. Double-click your user name in the list of folders. <br /> <p><br /> <p>3. Double click "Application Data", double click on "Ventrilo". This folder is the file "ventrilo2.ini. This includes all settings for Ventrilo. Right click on the file and choose Copy. <br /> <p><br /> <p>4. Click the Windows Start button and click My Computer. Right-click the drive where you want to copy the settings Ventrilo. This may be a CD or DVD, or you can use on an external hard disk. Click "Insert" to back up your settings in Ventrilo to create. <br />
on Jun 22, 2011 | Computers & Internet
Isa server firewall service stop
if you want to start the firewall service -go to control panel--- administrative tools---services---windows firewall----select it and double click on it---press START and select automatic then apply and ok. After this ----start----control panel----select windows firewall-----double click on it------select on----then apply and ok.Firewall services will be started.You can check now or you can restart the window before checking.
Jun 07, 2011 | Microsoft Windows Server 2003 Enterprise...
How do I get the at sign on this turkish keyboard
Should be shift and key 2
how to add the Turkish keyboard to your computer running Windows and how to utilize this new keyboard layout.
There are six letters in the Turkish alphabet that are not in the English alphabet, namely '?, ?, ?, ?, ?, ?'.
For writing these letters without going into the hassle of using the alt codes or copy-pasting from some other location, you can simply add the Turkish keyboard layout to your Windows computer system.
Using the same keyboard, the layout will change a little to let you allow to type the Turkish letters.
Windows XP and Windows 2000 Users
Go to start/control panel
Here, if you see Date, Time, Language, and Regional Optionsdouble click on it and continue with Add other languages.
Select the Languages tab in the window that will show and click on the button that says Details...In the Settings tab of the window that comes now, click the button that says Add... In the drop-down box titled Input Language, select Turkish. In the drop-down box below that, named Keyboard layout/IME, select Turkish Q and click OK. Click OK until all the windows we opened are gone.
In the control panel, if you don't see Date, Time, Language, and Regional Optionsicon but there is an icon titled Regional and Language Options, double click that. Select the Languages tab in the window that will show and click on the button that says Details...In the Settings tab of the window that comes now, click the button that says Add... In the drop-down box titled Input Language, select Turkish. In the drop-down box below that, named Keyboard layout/IME, select Turkish Q and click OK. Click OK until all the windows we opened are gone.
These instructions apply for the following versions of windows:
• Microsoft Windows Server 2003, Enterprise Edition
• Microsoft Windows Server 2003, Standard Edition
• Microsoft Windows XP Home Edition
• Microsoft Windows XP Professional Edition
• Microsoft Windows Small Business Server 2003 Standard Edition
• Microsoft Windows Small Business Server 2003 Premium Edition
• Microsoft Windows 2000 Professional Edition
• Microsoft Windows 2000 Server
Windows 98, and Windows Me Users
Go to Start/Settings/Control Panel/Keyboard
Click on the Language tab here, and then click the button Add.
Now, from the list of languages you see, select Turkish. Say OK until all the windows we opened are gone.
Nov 18, 2010 | A4tech X-Slim KL7MU
Hi , We are having 2 windows servers with identical configuration, and also we are using the windows 2003 with vendor application, We installed 8 GB of RAM in both server , But I could only 4 GB amount...
Hi
To reply your query in short. If you have any of the following versions of server it would support the maximum RAM upto 4 GB.
Windows Server 2003 R2 Standard Edition
Windows Server 2003, Standard Edition SP1
Windows Server 2003, Standard Edition SP2
Windows Storage Server 2003
If you are using : Windows Server 2003, Web Edition
It will support only 2 GB of RAM
For your information to get a complete information about Memory Limits for Windows Releases. Please visit the following site:
(msdn.microsoft.com/en-gb/library/aa366778.aspx)
If you find it useful please do not forget to rate this solution.
Jul 14, 2010 | Microsoft Windows Server 2003 Enterprise...
I have an Ml 110 G5 Server, But i could not find the VGA driver for the Win Xp , kindly assist thanks Justin
Hi, I m really sorry to say that but you have a Server Product and its built to run Windows Server Series on it (or Linux / Novell Netware).
This is the list of compatible Server list
Microsoft Windows Server 2003 Microsoft Windows Server 2003 for 64-bit Extended Systems Microsoft Windows Server 2008 Essential Business Microsoft Windows Server 2008 Foundation Edition Microsoft Windows Server 2008 R2 Microsoft Windows Server 2008 Small Business Microsoft Windows Server 2008 W32 Microsoft Windows Server 2008 x64 Novell NetWare 6.5 Red Hat Enterprise Linux 4 (AMD64/EM64T) Red Hat Enterprise Linux 4 (x86) Red Hat Enterprise Linux 5 Server (x86) Red Hat Enterprise Linux 5 Server (x86-64) SUSE Linux Enterprise Server 10 (AMD64/EM64T) SUSE Linux Enterprise Server 10 (x86) SUSE Linux Enterprise Server 9 (AMD64/EM64T) SUSE Linux Enterprise Server 9 (x86)
Here is the link for Drivers
Try to use the Driver for Windows 2003.
It has a Matrox VGA as I know. If you know which Matrox series you have, then Browse here for the Drives: Matrox Graphics Support. Make sure that you choose the Exact Driver software which suites the System.
Note: Not every product has the Driver Software for Windows XP.
Please rate the answer! Thanks for contacting Fixya!
Jun 19, 2010 | HP Compaq ProLiant ML110 G4 Server
I am trying to download PCAnywhere 12.0 to windows 7 and it tells me they are not compatible
That is correct Symantec list supported operating systems and Windows 7 is not compatible..
System RequirementsWindows 2000 Professional/Server/Advanced Server
Windows XP Home/Professional (32-bit and 64-bit)
Windows 2003 Server Standard/Enterprise (32-bit and 64-bit)
Windows Vista Ultimate/Business/Enterprise/Home Premium/Home Basic (32-bit and 64-bit)
Windows 2008 Server
Internet Explorer 6.0 or later
Regards
Nov 10, 2009 | Symantec pcAnywhere 12.0 Host & Remote...
My server can't boot
Hi ,
You have not mentioned which Operating System . If its for 2003 follow the steps.
To install the Recovery Console as a startup option:
  1. While Windows is running, insert the Windows Server 2003 CD in the computer's CD or DVD drive.
  2. Click Start, and then click Run.
  3. In the Open box, type the following line, where drive is the drive letter of the computer's CD drive or DVD drive that contains the Windows Server 2003 CD, and then click OK: drive:\i386\winnt32.exe /cmdcons
    To install Recovery console as a startup option for Windows Server 2003 x64 edition, type the following line: drive:\amd64\winnt32.exe /cmdcons
  4. Click Yes when the message appears, to install the Recovery Console.
  5. When you receive the message that states that the Recovery Console is successfully installed, click OK.
  6. To use the Recovery Console, restart the computer, and then use the ARROW keys to select Microsoft Windows Recovery Console in the Please select the operating system to start list.
uparrow.gifBack to the top How to Remove the Recovery Console loadTOCNode(2, 'summary'); As a precaution, do not remove the Recovery Console. However, if you want to remove the Recovery Console, you must do so manually.
To remove the Recovery Console, follow these steps:
  1. Restart the computer.
  2. Click Start, and then click My Computer.
  3. Turn on the Show hidden files and folders option (if it is not already turned on). To do so, follow these steps:
    1. On the Tools menu, click Folder Options.
    2. Click the View tab.
    3. Click Show hidden files and folders, click to clear the Hide protected operating system files (Recommended) check box (if it is selected), and then click OK.
  4. Double-click the drive letter that represents the hard disk on which you installed the Recovery Console.
  5. Delete the Cmdcons folder from the root folder, and then delete the Cmldr file. To do so, follow these steps:
    1. Right-click Cmdcons, and then click Delete. Follow the instructions that appear on the screen, and then click Yes to confirm the deletion.
    2. Right-click Cmldr, and then click Delete. Follow the instructions that appear on the screen, and then click Yes to confirm the deletion.
  6. Remove the Recovery Console entry from the Boot.ini file. To do so, follow these steps.
    WARNING: Incorrectly modifying the Boot.ini file may prevent your computer from restarting. Make sure that you delete only the entry for the Recovery Console.
    1. At the root folder, right-click the Boot.ini file, and then click Properties. Click to clear the Read-only check box, and then click OK.
    2. Open the Boot.ini file in Notepad.
    3. Locate the Recovery Console entry, and then delete it. The Recovery Console entry looks similar to the following line: C:\cmdcons\bootsect.dat="Microsoft Windows Recovery Console" /cmdcons
    4. On the File menu, click Save, and then click Exit to quit Notepad.
  7. Change the attribute for the Boot.ini file back to Read-only. To do so, right-click Boot.ini, and then click Properties. Click to select the Read-only check box, and then click OK.
Oct 12, 2009 | Acer Altos G710 Server
Redhat es5
This model was found not to be 64bit but 32bit.
May 18, 2008 | HP Compaq ProLiant DL380 G4 Server
Microsoft Windows Server Standard 2003 for PC Logo
105 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
